楼主: maybeloveu
[基础教程] 利用smtp+qq邮箱方式推送消息(长期可靠快速跨平台安卓)
发表于 2019-10-12 18:28:59 | 显示全部楼层
太厉害了
发表于 2019-10-12 22:49:55 | 显示全部楼层
gxfx
0..0..0..0..GXFX感谢分享
发表于 2019-10-13 20:47:43 | 显示全部楼层
大神 不管用outlook 还是163 都提示 无法连接服务器呢
SMTP server not found (smtp-mail.outlook.com:587). Please check the IP address or hostname of your SMTP server
  File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 138, in connection_is_valid
    server = self.connect()
  File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 124, in connect
    mail = smtplib.SMTP(self._server, self._port, timeout=self._timeout)
  File "/usr/local/lib/python3.7/smtplib.py", line 251, in __init__
    (code, msg) = self.connect(host, port)
  File "/usr/local/lib/python3.7/smtplib.py", line 336, in connect
    self.sock = self._get_socket(host, port, self.timeout)
  File "/usr/local/lib/python3.7/smtplib.py", line 307, in _get_socket
    self.source_address)
  File "/usr/local/lib/python3.7/socket.py", line 707, in create_connection
    for res in getaddrinfo(host, port, 0, SOCK_STREAM):
  File "/usr/local/lib/python3.7/socket.py", line 748, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
但在终端 ping smtp.163.com 或者outlook.com 都是通的
发表于 2019-10-13 23:11:31 | 显示全部楼层
自问自答 已经确定是docker里dns的问题 但现在就是没办法 让docker里的dns 一直有效
发表于 2019-10-13 23:24:52 来自手机 | 显示全部楼层
谢谢分享!
发表于 2019-10-14 09:30:13 | 显示全部楼层
谢谢分享,回复看看
发表于 2019-10-14 15:55:01 | 显示全部楼层
看看这个,正好要用到邮件推送。
发表于 2019-10-19 15:07:45 | 显示全部楼层
邮箱推送学习中
发表于 2019-11-11 20:41:38 | 显示全部楼层
学习一下怎么发邮件来提醒
发表于 2019-11-17 23:42:50 | 显示全部楼层
感谢分享。。。
GMT+8, 2025-9-18 03:08 , Processed in 1.066464 second(s), 10 queries , MemCached On.
