查看: 1161|回复: 1
[进阶教程] 请教,升级后闲鱼绿米窗帘不失效了!
发表于 2024-11-23 17:55:27 | 显示全部楼层 |阅读模式
#餐厅窗帘
  - platform: mijia_curtain
    host: 192.168.1.69
    token: e4cb73939178a46cf36a9f06******9
    model: babai.curtain.bb82mj
    scan_interval: 30
原来使用自定义米家窗帘插件,可以搞定TB买的绿米窗帘,不知这几天升级了什么就不能用了,无反馈。重新获取token也不行。请大佬指教!日志如下:
此错误来自自定义集成。
日志记录器: custom_components.mijia_curtain.cover
来源: custom_components/mijia_curtain/cover.py:496
集成: Mijia Curtain (文档)
首次出现: 17:51:39 (12 次总计出现)
上次记录: 17:53:20
Get property current-position exception
Get property target-position exception
Get property motor-control exception
  File "/config/custom_components/mijia_curtain/cover.py", line 496, in get_property
    results = self.miotDevice.get_property_by(siid, piid)
  File "/usr/local/lib/python3.12/site-packages/miio/click_common.py", line 183, in _wrap
    self._fetch_info()
  File "/usr/local/lib/python3.12/site-packages/miio/device.py", line 153, in _fetch_info
    devinfo = DeviceInfo(self.send("miIO.info"))
  File "/usr/local/lib/python3.12/site-packages/miio/device.py", line 107, in send
    return self._protocol.send(
  File "/usr/local/lib/python3.12/site-packages/miio/miioprotocol.py", line 161, in send
    self.send_handshake()
  File "/usr/local/lib/python3.12/site-packages/miio/miioprotocol.py", line 74, in send_handshake
    raise DeviceException("Unable to discover the device %s" % self.ip)
miio.exceptions.DeviceException: Unable to discover the device 192.168.1.69
发表于 2024-11-23 21:12:24 | 显示全部楼层
窗帘ip地址变了吧 去路由器看一下
GMT+8, 2025-9-15 03:20 , Processed in 0.450008 second(s), 6 queries , MemCached On.
