查看: 9537|回复: 82
[硬件DIY] 改造智能插板可分控,海鲜市场捡漏
发表于 2024-11-7 12:18:26 | 显示全部楼层 |阅读模式
在闲鱼发现一款鸿雁的智能插板,原来是阿里智控app用不了了。,三口+usb可独立分控。买回家发现用的是esp8266模块,用esphome接入ha目前用起来没问题。
需要的可以试一试。
需要使用ttl编程器刷入固件。
电路板细节
ttl点位
更新 esphome 配置
esphome:
  friendly_name: "插排"
  name_add_mac_suffix: True
esp8266:
  board: esp_wroom_02
  restore_from_flash: True
logger:
  level: INFO
  baud_rate: 0
external_components:
  - source: custom_compents
ota:
  - platform: esphome
    password: !secret ota_password
substitutions:
  use_address: '192.168.31.97'
  switch3_restore_mode: 'RESTORE_DEFAULT_OFF'
  switch2_restore_mode: 'ALWAYS_ON'
  switch1_restore_mode: 'ALWAYS_ON'
  usb_restore_mode: 'ALWAYS_ON'
wifi:
  use_address: '${use_address}'
  # fast_connect: True
  reboot_timeout: 0s
  ap:
    ssid: "switch"
captive_portal:
mqtt:
  broker: !secret mqtt_broker
  # client_id: 95f0853b212540f0ba1b3d4337bee7ec
  username: !secret mqtt_user
  password: !secret mqtt_password
  discovery_unique_id_generator: mac
mdns:
  disabled: True
button:
  - platform: factory_reset
  - platform: restart
switch:
  - platform: gpio
    pin:
      number: GPIO13
    restore_mode: '${switch3_restore_mode}'
  - platform: gpio
    pin:
      number: GPIO12
    restore_mode: '${switch2_restore_mode}'
  - platform: gpio
    pin:
      number: GPIO14
    restore_mode: '${switch1_restore_mode}'
  - platform: gpio
    pin:
      number: GPIO15
    icon: "mdi:usb"
    restore_mode: '${usb_restore_mode}'
  - platform: template
    lambda: |
      return (id(switch1).state && id(switch2).state && id(switch3).state && id(usb).state);
    turn_on_action:
      then:
        - switch.turn_on: switch1
        - switch.turn_on: switch2
        - switch.turn_on: switch3
        - switch.turn_on: usb
    turn_off_action:
      then:
        - switch.turn_off: switch1
        - switch.turn_off: switch2
        - switch.turn_off: switch3
        - switch.turn_off: usb
output:
  - platform: esp8266_pwm
    pin:
      number:  GPIO4
      inverted: True
    frequency: 500 Hz
status_led:
  pin:
    number: GPIO16
    inverted: True
light:
  - platform: monochromatic
    output: led_blue
    internal: True
    effects:
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
          min_brightness: 0%
          max_brightness: 100%
  - platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
    name: "WiFi Signal dB"
    update_interval: 60s
    entity_category: "diagnostic"
binary_sensor:
  - platform: gpio
    pin:
      number:  GPIO5
      inverted: True
    on_press:
      then:
        - light.turn_on:
            effect: "Fast Pulse"
    on_release:
      then:
        - light.turn_off: light_led_blue
    internal: True
    # on_click:
    #   then:
    #     - switch.toggle: switch1
    # on_double_click:
    #   then:
    #     - switch.toggle: switch2
    on_multi_click:
      - timing:
        - ON for at least 20ms
        - OFF for at least 500ms
        then:
      - timing:
        - ON for 20ms to 200ms
        - OFF for at least 50ms
        then:
      - timing:
        then:
          - switch.toggle: switch3
      - timing:
        then:
          - switch.toggle: usb
      - timing:
        - ON for at least 1.5s
        then:
          - switch.toggle: all_switch
      - timing:
        - ON for at least 3s
        then:
          - button.press: restart_chip
      - timing:
        - ON for at least 5s
        then:
          - light.turn_on: light_led_blue
          - button.press: reset_factory_button
text_sensor:
  - platform: wifi_info
    ip_address:
      name: ESP IP Address
    ssid:
      name: ESP Connected SSID
    bssid:
      name: ESP Connected BSSID
    mac_address:
      name: ESP Mac Wifi Address
    dns_address:
      name: ESP DNS Address
参与人数 1金钱 +8 收起 理由
flim + 8
发表于 2024-11-7 12:33:18 | 显示全部楼层
能无损拆机不?是分控还是总控,给个配置文件呗
发表于 2024-11-7 12:37:43 | 显示全部楼层
谢谢分享学习了
 楼主| 发表于 2024-11-7 13:57:42 | 显示全部楼层
可以分控
发表于 2024-11-7 15:20:18 | 显示全部楼层
这排插好像挺贵
发表于 2024-11-7 15:39:24 | 显示全部楼层
之前30一个卖了三个
发表于 2024-11-7 16:04:39 | 显示全部楼层
求教程
发表于 2024-11-7 16:08:58 | 显示全部楼层
6666666666
发表于 2024-11-7 16:25:45 | 显示全部楼层
这个排插,以前京东用券30块钱能拿下来。但是我个人觉得质量不行,用上1年里面就有电流声。论坛上好像有帖子记录过这个事情。
发表于 2024-11-7 16:37:17 | 显示全部楼层
大佬牛逼 6666
GMT+8, 2025-9-17 03:13 , Processed in 1.186051 second(s), 15 queries , MemCached On.
