楼主: miracle
[经验分享] 根据FrankLv小米空气净化器添加教程,将配置文件修改成pack...
发表于 2017-7-12 23:27:53 | 显示全部楼层
支持!!!!!!!1
发表于 2017-7-13 13:44:34 | 显示全部楼层
谢谢分享~~~
发表于 2017-8-7 07:43:29 | 显示全部楼层
谢谢分享,这个packages很方便啊
有一个关于js文件的位置提醒:
原教程要求把js文件放在/home/pi/路径下,楼主的yaml文件中的js文件路径是/root/setup/config/bin/,注意与自己上传的js文件路径保持一致。
目前还是这些错误,开关也没有弄,另外,读取数据确实慢
2017-08-06 11:25:06 ERROR (Thread-9) [homeassistant.components.sensor.command_line] Timeout for command: node /home/pi/airpurifier.js 192.168.1.174 status-power
2017-08-06 11:25:06 ERROR (Thread-2) [homeassistant.components.sensor.command_line] Timeout for command: node /home/pi/airpurifier.js 192.168.1.174 status-mode
2017-08-06 11:25:06 ERROR (Thread-5) [homeassistant.components.sensor.command_line] Timeout for command: node /home/pi/airpurifier.js 192.168.1.217 status-power
2017-08-06 11:25:07 ERROR (Thread-6) [homeassistant.components.sensor.command_line] Timeout for command: node /home/pi/airpurifier.js 192.168.1.174 status-led
2017-08-06 11:25:07 ERROR (Thread-10) [homeassistant.components.sensor.command_line] Timeout for command: node /home/pi/airpurifier.js 192.168.1.174 status-temp
2017-08-06 11:25:07 ERROR (Thread-4) [homeassistant.components.sensor.command_line] Timeout for command: node /home/pi/airpurifier.js 192.168.1.217 status-mode
2017-08-06 11:25:09 ERROR (Thread-11) [homeassistant.components.sensor.command_line] Timeout for command: node /home/pi/airpurifier.js 192.168.1.174 status-hum
2017-08-06 11:25:09 ERROR (Thread-8) [homeassistant.components.sensor.command_line] Timeout for command: node /home/pi/airpurifier.js 192.168.1.217 status-led
2017-08-06 11:25:13 ERROR (Thread-11) [homeassistant.components.light.yeelight] Failed to connect to bulb 192.168.1.152, Living Room: A socket error occurred when sending the command.
2017-08-06 11:26:29 WARNING (MainThread) [homeassistant.components.input_select] Invalid option:  (possible options: 自动模式, 安静模式, 最爱模式, 关)
2017-08-06 11:27:16 WARNING (MainThread) [homeassistant.components.input_select] Invalid option:  (possible options: 自动模式, 安静模式, 最爱模式, 关)
2017-08-06 11:33:22 WARNING (MainThread) [homeassistant.components.input_select] Invalid option:  (possible options: 自动模式, 安静模式, 最爱模式, 关)
2017-08-06 11:37:25 WARNING (MainThread) [homeassistant.components.input_select] Invalid option:  (possible options: 自动模式, 安静模式, 最爱模式, 关)
发表于 2017-9-19 14:05:27 | 显示全部楼层
请问楼主,miio如何安装啊,我用sudo npm install -g miio 安装过程有warning,但是没有error,装完以后执行脚本会提示miio不存在。
发表于 2017-10-15 19:48:20 | 显示全部楼层
我是来学习的,,
发表于 2017-10-15 23:20:55 | 显示全部楼层
谢谢分享
发表于 2017-10-25 00:08:30 | 显示全部楼层
谢谢分享
发表于 2017-11-30 10:10:21 | 显示全部楼层
谢谢分享
发表于 2017-12-30 13:17:04 | 显示全部楼层
感谢分享!
发表于 2017-12-30 13:39:59 | 显示全部楼层
给力,支持两台小米净化器了
GMT+8, 2025-9-15 03:10 , Processed in 0.586696 second(s), 12 queries , MemCached On.
