楼主: xiaomiku01
[插件集成] 移动爱家(原和家亲)接入HA 集成发布
发表于 2024-10-24 13:46:54 | 显示全部楼层
我登录之后,分享给我的老家的摄像头没有啊
toil 手机认证
发表于 2024-10-24 14:09:13 | 显示全部楼层
和家亲这个逆向把签名搞出来工作量应该挺大的
发表于 2024-10-24 23:40:27 | 显示全部楼层
牛逼啊
发表于 2024-10-27 23:51:21 | 显示全部楼层
今日 插件 提示 更新
更新后 还是没有实体!!
发表于 2024-10-28 09:15:09 | 显示全部楼层
可以把视频保存到本地吗,那就可以不用他那个云存储了
发表于 2024-10-29 21:24:30 | 显示全部楼层
老密码错,但实际正确的。
发表于 2024-10-30 14:29:40 | 显示全部楼层
hac 无法安装?
发表于 2024-10-31 14:56:42 | 显示全部楼层
怎么账号密码对 就是连不上啊
发表于 2024-10-31 15:03:53 | 显示全部楼层
xxlxmd 发表于 2024-10-31 14:56
怎么账号密码对 就是连不上啊
又重新启动了一次 好了
发表于 2024-10-31 15:05:28 | 显示全部楼层
xxlxmd 发表于 2024-10-31 15:03
又重新启动了一次 好了
OK 登陆了 没有实体
2024-10-31 07:04:22.853 INFO (MainThread) [custom_components.hass_hjq] 01JBGP5RH9N8BPRNXXNAZ2FCD1
2024-10-31 07:04:22.981 DEBUG (MainThread) [custom_components.hass_hjq.hjqapi] {"msg":"OK","code":0,"data":[],"configArray":[{"configId":"1","link":"https://base.hjq.komect.com/dh-appactivity/ncovemc/","logo":"http://video.komect.com/upload/picture/campaign/campaign.jpg","state":"0","title":"新手引导","type":"1","content":""},{"configId":"2","link":"","logo":"","state":"1","title":"闪屏页","type":"2","content":""},{"configId":"3","link":"","logo":"","state":"1","title":"welcome","type":"3","content":"下午好,快来看看新动态吧~"},{"configId":"4","link":"https://video.komect.com","logo":"http://video.komect.com/upload/picture/2018-12/29/original/17894323355662681645056_original_549x549.jpg","state":"1","title":"官网地址","type":"4","content":""},{"configId":"6","link":"","logo":"","state":"1","title":"可配网设备类型","type":"6","content":"["CMTF1","G26C","HDC-55-SW","U30.","U50","Q1","CMTP7C","Q1Pro","HDC-51","HDC-55","HDC-61","DS-2PT2D20IW-ZHY","DS-2CD2225C-ZHY","FJ04MLWJ-CM","HDC-51-SW","G33P","CS-MT1-2EHY","CS-MT2-2EHY","DS-2CD2325CV3-ZHY","U11","U50-4G","FJ04MLTZ-CM","CM3Y","CM2P-S","H8","T21","G30P","DS-2CD2325C-ZHY","C16","D1","视洞U60","视洞U60-POE","V3A","V3B","B1-W","U60-POE","U60","CMCC-V2-001","CS-MY2-2WHY","DS-2CD2T2HY-LP1","CMSXJ25A","CMSXJ26A","CMDR001W","U101C","U101","A22E","D809","D1-RH","MC300P-W","MC300Y","C16-RH","HDC-56","HDC-50","Bullet+4s","CS-C5W","CS-MY3-3WHY","B5-W","W5-W","C2120-10-I-P-ZJYD","LYC20-Pro","LYC20-Note","LYC20-4G","G56P","ZX-Q1","ZX-Y31","DS-2CD2T2HY-LP3","GST-P310-CM","GST-G460-CM","GST-G360-CM","B7-W","KEMY","DS-2CD264HY-IPF1","SD-H300","JNC-i1-CM1","WJA-G400","2221111","mdztest1","Zh_test","mdztest2","mdztest3","Zh_test1","大华P4M","大华P4Z","UP300-HY","LYC25-Note","GM6","LY300QJ-4R4B","LY300QJ-2R4B","JNC-O1-CM1","AW3CCM00","CS-MT5-3EHY","CMCC-V7A","CMCC-C5","SC2230","SC2220","H3C+TC3111","TC2101","12222","12223","GT3Q","CM3Y-N","CM3CY","AI-CM3Y","CM4TPA","CM4QPA","AI-CM4TPA","LYC30-Note","w20536","C73","M510","EF5054","LYC40-Note","I9Max","Speed 6X","Smart-D1A-230-P","SK-A390","PD88-S3","ZXHN K713","KIPC-X131P","C75","H3C TC3111","IPC33LD-CMCC-V2","IPC23LD-CMCC-V2","D1C","SK-A490","TAI6000L/93","A33E","G67P","XPFN","GK-C14V76","CMSXJ37H","FC21-13KPX","D3F","EF1143","JA-H35","CMCC-V7B","G69P","F10","A33E-4M","TAI6000W/93","T61P","DF2001-A01","XFD300-M","NM100","TAI2000W/93","EF1054","TAI6250W/93","AP6PCM03","TAI6200W/93","XFP300-M","XFD400-M","KML-F121Y","AR2CCM02","KOMI-K5pro","NM200","CMSXJ47H","KC-2301E","PD88-S2","Uface-NCP3N001","MQ20","KC-2401C","Y300","Newsmy100","DS-2CD2T4HY-LP4","P1","XM-5XD","DS-2CD222HY-IP2","5678vb","fnciew","XHF-H502S","ZN-YLB100-IR","SK-A491","和家亲 HDC-57","JA-PJ3031-POE-YD","JA-PJ2331-POE-YD","HDC-52","JA-HSD2031","C3C","Q400","CMTD28A","HDC-57","C01-Q3M01","CA041-A","XHF-H505","XHF-H503","CX1U","SD-H100","FG-YT102Y","CS-MP1-2WHY","FG-QJ101Y","PZ-S6","XHF-H601","Q55","WJA-G408","WJA-G406","J001","SC3030","测试品牌 摄像头测试仪器","Y1","KIPC-J531Y","ZN-YLB200-IR","ZN-YLB300-IR","CMCC-C1","ZXHN K743","Newsmy200","CM3TP-N","CM4TP-N","CM3QP-N","yy306","OC440C","Smart-D2R-240-P","XFZD300","XFA400-M","S100","HJ300N-B","HJ300W-B1","HJ300W-B2","H30W","CS-MT7-4EHY","Bell 19S","KL201","SD-H110","VHD-Y300","C76","U-CQ18","H30N","VCM210","J002","EQUES-13","ZS510C","ZXV10 S100V","zyz01","G51M","C41-P","P41","G-FCJ300","CMSXJ48H","CM3DB","MD5LM","CY3B","SM-B52Q-M","XDH-2A-B1","HCC-25B30-W","MQ15M","CM3Y-WB","CAMERA-ZH","CAMERA-ZH2","BPLAKG400","BPLCKG400","tesyinzhu","LT30C","P62","DS-2CD8A47HY-FGZ1","BW-410","BW-420","rr308","DS-2FH1521B-OW/F","ZNVD-296C-IR","ZH_CAMRA","ZNVD-495C-IR","HCD-18B20-WY","HDC-S400","KC-2341E-W","HCC-18B30-WY","C1P","CTD-300W-1","Uface-B340-AW","XM-4XD","GX-P2103-FH","JL110","C22","KC-2311E","KL101","C10","GX-S2103-FH","NTS31","TG_S7B01","CMYZ47H","Smart-D2S-24A-P","Uface-DR_typhon01","JNC-O1-CM2","IPC-PT42-EP-W","XHF506","PD88-S1","IPC-PT41-EP-W","S60","D60","SC-AP01","WJ01","C18","SC102","zyz test af","HC1000","NFS56-W","NFS56-Y","AD-CM400","AD-CM300","maoyan-pu","menling-pu","mdztest0615","P90","WD2401","WD2402","WD2403","CH-CSPAS01","1255","D4P","CTD-900M","SC-AC01","NZ-41A","IPC-Y32-WU-IR","SM-P26Q-M","IPC-Y31-WU-IR","IPC-PT31-EP-W","CMCC-V9A","GL-C14P0","CTD-300W","KC-3321E-W","CMCC-V8A","IPC-PT32-EP-W","IPC-Y42-WU-IR","F4C","ZXHN K543","CMCC-V8B","SCQ1-40","ces","EF1024","ZD12","YW-D1","CMCC-V9B","ZS01-POE","P101C","FC22-14KPX","DH-HY-SP32-15P","BW-NT-L","XDH-21-A1","JNC-O3-CM1","ZS600C","GD01","HJ400W-B1","HJ400N-B1","HJ400N-B2","HJ400W-B2","YD401-FY","HM600","TC718","XFZA-400-PM","XD-SDD05-2102","XHF506S","kanhutest","TC818","ZCX-BW03","H610M","AMG-C1247","AMG-C224G","HM-AIPC-A3Q-FR-A","HM-AIPC-A4Q-FCR","HM-IPC-A4W","YD401-ZY","JL-AK30-D","HCG-35E404-UHY","R201M","EF9054","YD401-ZQ","ZNIPC-316DJ-IR","Y2W","G51MI","JA-Z40","PZ-Y8","CS-DL20VC","DAS-SE-Y20","JF-R3C","GOS-A41","GOS-Q41","GOS-Q31","GOS-Y33","JF-T4C-M","OC430C","tt3088","hfskjlfsk","IPC-TEST","CMSXJ57H","YD401-FQ","DH-SA3NA-B","NP-FY200","WS2CG-NB","HS2SA-NB","LH601-ZB","LH801-ZB","LH-301ZB","THP10-Z-V3","PW-920","PW-507S","PW508","HL_SRCO1XKBGL","HL_SRMO1XKBGL","HL_GWDG1TOGL","LZ-1956CI","LYSD20","LYGD20","LWL-7005","JGYX-25W","SS-IOT-LTSC","FC61-14KRW","SC5334","HJ400W-B3","HJ400W-B4","XFD301-M","HT01","JF-T4A-M","SD-H400","NL-C602","HJ400W-B","NL-C601","XFP301-M","pp3051","12341","NEWSMY100","MQ22","P1C","SC51213","CS-MY4-4WHY","SC-1","UM2RA2A","C139-AW","UNIUBI-IPC-D21-T","XHF-Y802","XHF-Y801","KL102","MZ-Y419","MZ-Y417","XHF-B701","CG-C308","CG-T308","HT02Q","MZ-Q401","YD4Q-CR-AF","YD3Q-F-AF","YD4X1","test0909","MZ-B421","V41","UM4QB3A","ZNIPC-317DJ-IR","CB-N41","CC-N31","W5M Max","JNC-O14313-CM","CB-G2L3MS","WD2405","WD2406","HW-6688","HM-E1330-M7IL","SC402-A2","XHF506P","HM-A140-M7FIL","HM-A130-M7FIL","HM-C140-M4FIIL","HM-E1330-M9IL","HM-E230-M7I-W","SC402","SDW301","CB-F41","CC-F31","MB8BF","TG_S5B01","TG_Z05","KL202","CB-B0D3MPS","KIPC-W632Y","0923m_test_1","0923m_test_3","CA043-B","P4Y","MZ-B429","MZ-B427","P4C","NEWSMY400","D3M","kv-3","ss2","XHF501S","KC-6302E-W","MZ-Q409","MZ-Q407","JM1111H","WS61","CS-M200-VWHY","SD-H390","kv-6","kv-7","EF9153","YD401-HY","YD401-HQ","AD-CM450","RW-518N","WS60C","NTS31-Y1","MZ-Y411","XHF-H513","SCQ3-40","SCQ3-30","NTS31-1","ID-P20","IPC-Y41-WU-IR","bb3012","HW-6689","LC2111","AD-CM301","HCG-32E404-UHY","LC2110","AD-CM401","KS-A2-M","Y31","CMCC-C8","GST-P468-CM","GST-G468-CM","GST-B468-CM","HM-A140-M9S1FI","HCC-15B30-W","LYC41-Note","LYC42-Note","LYC45-Note","LYC46-Note","ZXHN K745","SC403","SC403-A2","KIPC-X242P","JM2111H","D3L","HCD-GB4V01","NZ-41C","nn2051","1028","2143111","PKJ400-4R-4B","AIPC-A4Q-FCR","KML-W821Y","YIH70","Y42","RC6","BJ-X104KW","BJ-IP400KT","HCG-35E442-UHY","Y41","ASC5615","ZNIPC-317W-IR","ZX-Y32","HW-6699","HC104","UNIUBI-IPC-G220","UM4QA3","5476567","qwer123","HJ400N-B3","HJ400N-B4","SC103","CMSXJ37Z","GOS-A32","GOS-Q32","FT-Y3","HC-C20","NEWSMY300","CMCC-C9","H630M","MC8DD","FG-QJ103Y4","V51","Z51","MINI5","HC-C10","HC5334","LYC90","L01-OA-WVFC","JC-5200A","JC-5301A","JL-AK40-D","JY1","ETC806","T31","EF9053","ZNIPC-418DJ-IR","YXL-IPC401","C159-AW","UM3YB3","CS-MY6-4WHY","LYC50-AI","LYC51-AI","ZNIPC-418W-IR","SD-D210","WJA-G501","LYC21-Note","iQIYI-IC01","KS-A2-M2","AE-DC8012-C8","Y3-C","SC51303","HDC-50 test","WXX-01 test","HDC-52 test","JF-T5S-M","SC51304","Q41","WXX-002 test","AP6PCM03-A","LYC16-AI","LYC18-AI","HCC-25B342-UHY","HCG-35E443-UHY","D4M","YD401-CQ","ZXHN K545","WS62","LYC60","FC22-24KPX","C75-Y","Dazen-A6","JF-M4C-M","KIPC-K531W","C3M","WCD-YYS-Y001","SC68712","BW-810","NM3001","WCD-YYS-Q001","YT100","C30-CM","XFZAP401-M","KS-B2-M","WS62P","LYC16M","SRQJ400","JF-T3C-M","Y1-C","CAM400-IP","M9","SY3T2","KC-2411E","KC-2501D-A7","BSJ-AS800","SC4MG-A1","EBO AIR","SC34-AM","KLF-IPC40A","C35","YDS09","CMCC-V10","ZXHN K335","CG818","A35E","P5MPro","Uho-PT31-C","KLF-IPC401","SC14-AM","Dazen-A7","P31T","KIPC-K633Y","EM-N1331H-AP","LYL20-Note","LYL30-Note","U62","P33","T2041","CAMB300Y","SK-A492","CS-MY5-4WHY","ZNIPC-405DJ-IR","KIPC-X131K","SC504","UC240","HT-MH1000","XH-D3","CS-MT8-4EHY","XFD401-M","SRYT300","WJA-Q401","SC31304","TY101","SC4MY-A1","XLQ8G","QM3C","HCC-25B343-UHY","Uho-PT32-C","FX-T31","SK-A493","ZXHN K743A","DS-2CD7T46-DP1","DS-2CD2T4MW-WY1","WJA-G425","ID-P50","ID-P30","Q9123NU","T3142","W5MPro","MZ-Y401A","LY300YT-M","YX-C4-PQ-Y20","YX-R3-PR-Y20","XHF-Y401A","WD2601","WJA-Q40","AIPC-A340-M9AIL-PS","LYC50-PTZ","HW-N301","HW-W301","WD2407","C41-M","C17","PM6N-4G","MT615-D20WTT","DTS52","IPC4MPIRD04Z1P","NZ-42C","XFD410-M","JF-Y4M","XD617","WJA-Q41","WJA-G30","Y2","PM6L-4G","fsdg1","SmartEye-D1A-24A-P","SmartEye-D3X-24A-P","SD-H350","CMSXJ48Z","SIMBC400M","LC2213","KM400","S29","CMCC-C6","KIPC-C1Y","Z1-C","Uho-PT34-C","Uho-PT33-C","HC350","KLF-IPC403","SMC100","T3141","YX-C4-PY-Y30","KLF-IPC40D","SG-G400V3M","DC418","DH201-Y1","DH101-Y1","CMIOT-XYG2","WJA-G430","SC51214","IPC-T24S401-HY","YX-C4-PY-Y20","T2042","angelcare S200","angelcare S100","ZG-AXQ128","DC428","LC2212","TF80CN","CG808","WJA-G31","S2","IPC-T24S402-HY","G-T4M","SC51604","IPC-T24S403-HY","OF201","WJA-G31D","tongbu","ZTIPC-C7-IR","KC-3401C-A1","KC-2411C-A1","SK-A498","CA045-B","YJQ8G","BC-M901","BC-M801","BC-T601","G-C4M","G-P4M","G-P3M","QH50CN","HJ400W-B6","YAY4001","YJQ4J","LYL40-Note","HC150","FQ02A","NEWSMY500","SK-A421","xiugia","3423546","3.2.322","654335","bb2051","123123","安防测试111","HC355","LYL41-Note","HJ400W-B5","UM4YC3A","ET-N3431H-DW","NL-VT100","EM-A1433H-AP","HJ400N-B5","LYC53-AI","SC405","SA1340","SA134A","SA3340","SA334A","SA5340","SA534A","SC3752","NSC04-Y","NSC04-W","CMSXJ56H","LYC54-AI","CBYD02","CTYD01","LS-Z4","ZT-668","CM512-1","KC-2411C-A3","LD2202","test001","LYM20","LYM20-Pro","C2150-LIV6-MHJ","C2150-SLU1-MHJ","KC-3421E-W","LY350AI","KC-5431C","KC-2411C-A5","IPC2400","IPC3400","SKY-KK-Z4WAI","JVS-M-C9L","G55M","TH81","SS201","ZTIPC-F05-IR","S905D3测试一体机","G25M","WH65","ZXHN K746","TOCO-X1-W-Q1","NL-C803","test002","SG-B400V3M","QYC401","QYC400","LC2208","G25MI","G55MI","SE-PTZC-1","KC-2411C-A7","KL-SA1001","FC22-54KPX","SE-BCC-2","AIPC-A340-M9AL-S","SS101","TH8300","KL-CA1002","FC22-64KPX","DS-QJD101-Y","SOAR-V01","SKY-KK-Z4AI","PINEWORLD L20","NSC04-Y1","NSC04-W1","YFT-810","HJ300W-B3","CS-MD3-3WHY","SC415","C342T","C2150-Up-MHJ","C3250-SIU-MHJ","C2150-SIU-MHJ","SIMP400M","3.2.1","C3050-LIV2-MHJ","C3050-LIV3-MHJ","SCA1000","KC-5412C","CS-MT6-4EHY","UHDC-72","SmartEye-D1A-24B-P","UHDC-71","SC3152","KB-C1430PM","CA-B4GG","CS-MY7-4WHY","R007","WJA-G45","TCL C1P1","HK-V023M-W","Uho-PT41-C","JA-CA43-PRO","CMCC-C9pro","HK-B124M","G62P","LYC20-HT","P36","ZTIPC-F06-IR","G25M-S","CG40","Q400F","CP40","XHF-DL10S","HCC-18B442-UHY","LYC61","TP629","NL-C804","TS229","WJA-Q43","HM2","LYC62","ZNIPC-407W-IR","EF1545-M","C341T","BL5","Uho-PT42-C","Uho-PT43-C","LCA100","TP628","TOCO-X2-W-Y1","SYT001","PP208","66325","DTS601","Q7FPro","L4C","XF90","D62","KECAM-28","UMPET01","XFMS-01A","PTLEye-D1A-C4A","WJA-YT02","NL-C903","TS228","NRS04A-W","D90","P60-KJB","A37E","YYCP9901","YYCP8801","P90-KJB","G23M-KJB","C2120-10-I-P-ZJYD-KJB","G23MI-KJB","G51M-KJB","S62","LYC28-Note","LYC28-Pro","U30-KJB","WJA-Q45","YB3Y","YB5Q","WD2603","WD2604","S101","HK-V033M-W","ikun980","LC2223","Y5","YFT-A5","YFT-A6","HCC-25B441-U1Y","HK-V3A3M-W","KECAM-27","JF-P3C-M","C242T","C241T","DH-HY-SAV849HA","test003","AW3CCM00-KJB","IPC100-WS","IPC200-TS","CS-MQ1-4EHY","G25MI-U","HJ400N-B6","CM2P-S-KJB","S101-H","YD3QP-KJB","CM300N-KJB","JF-Y4M-C","DL-FD1FC","TC618-KJB","WJA-G436","G67P-KJB","G53P-KJB","CMCC-V31S","HK-B064M","3242543","HJ300N-B1","CG858","XM-T511","JF-L2C","IPC2401","CG878","ZXHN K743S","IPBS8505","KL802","GC-F4P-CH","C2140-LIV-MHJ","WH6200","LYR25","C31-KJB","MC10","HK-B6A4M","LY-YDC4-YT15","DPDL- GC-300A","XF91","R36","L10-V","PTLEye-D3X-24C","PTLEye-D3X-24D","G25M-A","YP-C100","SC3355","CM-C4MO","ID-P33","WH6900","SCTF9042ZPGR","SCTF9041ZPGA","ML03","D12-18","U33","A90","C2152-SIR-MHJ","CMSXJ39H","Dlock S3","550W","A60","JF-T4S-M","ID-P80","ID-P66","U-CQ40G","NVR01","Q400G","Q800J","GR23-W","G55M-A","CESHIQW","DWL508","GC-Q4W-H","TM-22A","P204S-P","WH6800","XYS-D02401","SCTF9040ZMY","YB4Q-J","HK-T032M","H08","ID-P26","ID-P63","TC-C14YQ-DX","G25MI-A","G55MI-A","W7M","A62","LY-YDC5-QJ20-QAI","ZXHN K543S","JF-T4CJ-M","IPC3400-P","HJ400W-B7","GW23-4L-test","Q04-M","Y03-M","Y01-M","Q01-M","nanxiang01","HT-MH2000","JA-H45","Q02-M","CM4P-S","IPC3420-AT-LISHJQ","YDS10","NL-VT200","Y02-M","Q03-M","CM4CY","CMSXJ40H","ID-P35","CM4TPA-N","CM4Y-N","SC3352","ZXV10 C200","JC-7210Y","LS3101BK-WMY","WJA-G502","SC3350","CM301DB","JC-7310Y","KIPC-X131Q","6.3.21","HW2023-S8","P7M","SC3152A","PT43EC","XF70","SC3150","PTLEYE-B3S-G3MW","CM4TPAD","CL01","VQ2","Y2-C","JA-CA43-N","gg1024","NM4001","YK12-V","G20","IPL300","T241MC","卡尔KN8-test","A108M","CML252","ET-N3431H-PRO","输入型号,如ABCD","P63","XF60","testz01","YJQ4J-AI","YP-C800","test-rot20230331","LY-YDC4-YT30-QAI","LYC80-AI","MTCN100","CM4TPA-WB","GC-F4P-AB","TA8100","T243MC","T242MC","PT41EC","PT42EC","YB4Q-F","WJA-S301","N30","YM-M20S","T244SC","CMCC-V10S","JA-H2","T242EC","T241EC","WJA-G35","HC355A","R90","PT44SC","GW23-4L","XF71","LYC35-AI","LYC32-AI","LYC31-AI","T243EC","JA-PJ3051-POE-YD","MC406Y-G","B33","U63","R62","U90","PTLEye-D2T-24A","HJ200NC","XTBCW401","XTPCW401","VLOCK-OVD-TEST","JA-CA45","R63","PTLEye-D2T-C4A","HN-A306","HW-S01-S602H","MMS-CM01-Pro","HM514","CS-MQ1-NOTE","CMCC-L2V","HFH-35VY-U1","HHK-2419M","ZNIPC-507W-IR","ZNIPC-506DJ-IR","LY-QJ80-AI","SG-B400V6MC1","Dlock C3","P8","HJ400WBA1","HJ300NC","CR-Q1","LYC20AI-4G","KN8","NVR2108-CMCC","CM116C-GB","CMCC-V12","DPDL- GC-400A","CMSXJ55H","G26MI","G26M","Homibot-H001","ZXHN K745S","PTLCube-B4XX-MF","PTLCube-B4X8-MF","PTLCube-B4X4-MF","G56M","G63P-M","EBO SE","YK13-V","X7-CM","Vision_Test","HJ400NA2","GTVC-A101P","JA-PJ2041-POE","GTVC-A102P","S300-H","A63U-M","DS-2CD7A47 -EP3","GTVC-A301","Q05-M","HFH-36VY-U1","DS-7608N-E1-V3","DS-2CD7T45 -DP8","DS-2CD7A47 -EP2","CS-MG210V-WHY","XF80","XF10-16","ZXHN K945S","NM300","NVR300-08CC","NVR300-16CC","YTJ8553D-M","C3 Plus","DS-7616N-E1-V3","R40G","Q600J","VY-2","HSGQ-CW4000","LMS01 K50X","浪潮IPL220","SC31334","DZ-H300V","DS78","CS-MT1C","CS-MT2C","MC406Y","AI-CM4Y","A63U-M2","G63P-M1","G63P-M2","A63U-M1","AI-CM4WD","LY-QJ90-AI","LY-QJ91-AI","LY-YDC4-YT32-AI","HJ400NBA1","LY-YDC4-YT31-AI","ASM524","AHM524","WJA-T1","G56MI","ZHTEST01","LY-QJ50-AI","WJA-Q47","HN-V50Pro","SD-Z810","XFV1","ZN301","GD6518","JA-Z50","HS100","CMCC-V51S","CM3TPS","YD3Y-N","LYC16-RBT","L29","Xinghao","XD-SDD08-2303","QT1401","HSL67","GD6519","TD-U12","G62","K62","CS-MY1C","B62","HS102H","R33","Q06-M","LY-KSL-30Pro","F620","CS-MQ1C","KK400","S500-H","QJ02-M","LY-YT61-AI","AD63U-M1","AM63U-M1","LY-SM-YT60","LY-QJ81-AI","LY-QJ82-AI","LY-YT60-AI","CMCC-V71S","LY-YTS1-AI","S90","F33","LY-YT62-AI","C881D","SD-H600A","C681A","NEWSMY600","LY-SM-YT40","LY-TD-10","TC328","YP01-M","WD2606","ZXHN K545S","AI-CM4WS","AI-CM4CY","ZD-S60","Homibot-002","G30M","G30MI","DJ09","G60M","F3CM","CS-MY1C-Pro","s-29","L4A","G60MI","HJ400NA","HJ400WA","LY-YT45AI-PM","KTL-X29Y","CMSXJ601H","安防测试6.9.0","NL-C906","LY-SM-YT61","LY-YTS2-AI","T241CC","CS-MT1C-NOTE","QJ11-M","NVR300-32CC","TC828","CM232C-GB","C41-AI","PT41CC","R009","CS-MG300FVS-WHY","JA-Z51","JA-G4H40","SY-YT01","LYC10-Pro","SC-11B","SC-12B","SC-21B","SC-22B","SC-11A","SC-12A","SC-21A","SC-22A","CM4SQ-A","LY-YTS3-AI","AI-CM4WH","JA-Z52","SXT9018","test-test-001","摄像头USJS09191","AD-TD16","SC31215","LSKP8i23","L22","SC-31","ZKSLQ-0919OL","VT 40","C881B","Robot0304","ZXHN K745P","P3E","JA-Z2","ZXHN K545P","ZXHN K546S","ZXHN K746S","CMCC v71S","CMCC v51S","P41-AI","JA-H3","ZJHHY-P3E","TEST1","0808test11a","TEST2811","TEST281176","TEST2811346","TEST289046","TEST237046","ZJHHY-P2F","ZJHHY-HK-Q1","Nano-100","CMCC v31S","L33","K63","HT-PH163","ZJHHY-IPC","CA45-PRO","P234A-P","ZJHHY-P2","CMCC v10","ZJHHY-HK-U1","ZJHHY-Mini6","ZJHHY-F1s","ZJHHY-HK-D1","ZJHHY-HK100","ZJHHY-HK200","ZJHHY-5600-1","ZJHHY-YC251C","ZJHHY-H2E","ZJHHY-H1","ZJHHY-P3F"]"},{"configId":"5","link":"","logo":"","state":"1","title":"卡回放天数","type":"5","content":"1"},{"configId":"8","link":"","logo":"https://oss.komect.com/hjkhsld/upload/data/file/upload/video/forJQ_full_1.mp4","state":"1","title":"演示视频","type":"8","content":""},{"configId":"7","link":"","logo":"","state":"1","title":"支付配置","type":"7","content":"H5"}],"supportTransfer":0,"totalCount":0}
GMT+8, 2025-7-19 14:27 , Processed in 1.217186 second(s), 12 queries , MemCached On.
