查看: 1052|回复: 2
[智能音箱] 求救!小米AI音箱第一代连不上网 通过TTL更新 就无限跑代!
发表于 2024-10-17 18:33:00 | 显示全部楼层 |阅读模式
U-Boot 2015.01 (Jul 24 2018 - 10:41:17), Build: jenkins-Mico_s12a_ota_publish-141
DRAM:  256 MiB
Relocation Offset is: 0ef17000
register usb cfg[0][1] = 000000000ff89180
NAND:  nand id: 0xc8 0xd1
128MiB, SLC, page size: 2048, OOB size: 64
NAND device id: c8 d1 80 95 40 7f
NAND device: Manufacturer ID: 0xc8, Chip ID: 0xc8 (Gigadevice ESMT SLC 128MiB 3.3V 8-bit F59L1G81MA (2Y))
oob avail size 6
Creating 1 MTD partitions on "ESMT SLC 128MiB 3.3V 8-bit F59L1G81MA (2Y)":
0x000000000000-0x000000200000 : "bootloader"
ESMT SLC 128MiB 3.3V 8-bit F59L1G81MA (2Y) initialized ok
nand id: 0xc8 0xd1
PLANE change!
aml_nand_init obmul=1,oobfree.length=8,oob_size=64
oob avail size 8
bbt_start=20 env_start=24 key_start=32 dtb_start=40
nbbt: info size=0x400 max_scan_blk=24, start_blk=20
nbbt : phy_blk_addr=20, ec=0, phy_page_addr=0, timestamp=1
nbbt free list:
blockN=21, ec=-1, dirty_flag=0
blockN=22, ec=-1, dirty_flag=0
blockN=23, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1092: page_num=1
aml_nand_scan_rsv_info 1095
nbbt valid addr: 280000
aml_nand_bbt_check 1230 bbt is valid, reading.
aml_nand_read_rsv_info:397,read nbbt info to 280000
nenv: info size=0x10000 max_scan_blk=32, start_blk=24
nenv : phy_blk_addr=24, ec=242, phy_page_addr=0, timestamp=485
nenv free list:
blockN=25, ec=241, dirty_flag=1
blockN=26, ec=-1, dirty_flag=0
blockN=27, ec=-1, dirty_flag=0
blockN=28, ec=-1, dirty_flag=0
blockN=29, ec=-1, dirty_flag=0
blockN=30, ec=-1, dirty_flag=0
blockN=31, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1092: page_num=32
nenv valid addr: 310000
nkey: info size=0x8000 max_scan_blk=40, start_blk=32
nkey : phy_blk_addr=33, ec=0, phy_page_addr=0, timestamp=2
nkey free list:
blockN=32, ec=0, dirty_flag=1
blockN=34, ec=-1, dirty_flag=0
blockN=35, ec=-1, dirty_flag=0
blockN=36, ec=-1, dirty_flag=0
blockN=37, ec=-1, dirty_flag=0
blockN=38, ec=-1, dirty_flag=0
blockN=39, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1092: page_num=16
nkey valid addr: 420000
ndtb: info size=0x20000 max_scan_blk=44, start_blk=40
ndtb : phy_blk_addr=40, ec=0, phy_page_addr=0, timestamp=1
ndtb free list:
blockN=41, ec=-1, dirty_flag=0
blockN=42, ec=-1, dirty_flag=0
blockN=43, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1092: page_num=64
ndtb valid addr: 500000
tpl: off 8388608, size 8388608
Creating 6 MTD partitions on "ESMT SLC 128MiB 3.3V 8-bit F59L1G81MA (2Y)":
0x000000800000-0x000001000000 : "tpl"
0x000001000000-0x000001800000 : "boot0"
0x000001800000-0x000002000000 : "boot1"
0x000002000000-0x000004000000 : "system0"
0x000004000000-0x000006000000 : "system1"
0x000006000000-0x000008000000 : "data"
aml_key_init 170
MMC:
uboot env amlnf_env_read : ####
aml_nand_read_rsv_info:397,read nenv info to 310000
In:    serial
Out:   serial
Err:   serial
[store]To run cmd[amlnf dtb_read 0x1000000 0x20000]
sub cmd dtb
new argv[1] dtb_read
do_dtb_ops(): argc 4
arg 0: amlnf
arg 1: dtb_read
arg 2: 0x1000000
arg 3: 0x20000
do_dtb_ops() read
amlnf_dtb_read: ####
aml_nand_read_rsv_info:397,read ndtb info to 500000
do_dtb_ops(): 131072 bytes read : OK
      Amlogic multi-dtb tool
      Multi dtb detected
      Multi dtb tool version: v2 .
      Support 4 dtbs.
        aml_dt soc: xiaomi platform: s12c variant: v02
        dtb 0 soc: xiaomi   plat: s12   vari: v1
        dtb 1 soc: xiaomi   plat: s12a   vari: v01
        dtb 2 soc: xiaomi   plat: s12c   vari: v01
        dtb 3 soc: xiaomi   plat: s12c   vari: v02
      Find match dtb: 3
amlkey_init() enter!
amlnf_key_read key data len too much
aml_nand_read_rsv_info:397,read nkey info to 420000
[EFUSE_MSG]keynum is 2
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
Saving Environment to aml-storage...
uboot env amlnf_env_save : ####
aml_nand_save_rsv_info:656, nenv: valid=1, pages=32
release_free_node 61: bitmap=1fffff
release_free_node 74: bitmap=1ffff7
aml_nand_save_rsv_info:716,save info to 320000
aml_nand_write_rsv:520,write info to 320000
Err imgread(L252):Fmt unsupported!genFmt 0x0 != 0x3
resetting ...
AXG:BL1:d95c53:a4926f;FEAT:E0DC318C:2000OC:F;EMMC:800;NAND:0;READ:0;0.0;CHK:0;
sdio debug board detected
TE: 22916
BL2 Built : 14:27:07, Dec 14 2017. axg g56303a2 - xiaobo.gu@droid12
set vcck to 1140 mv
set vddee to 1070 mv
Board ID = 6
CPU clk: 1200MHz
DDR low power enabled
DDR3 chl: Rank0 16bit @ 792MHz
bist_test rank: 0 27 00 4f 35 10 5b 27 00 4f 38 11 5f 00 00 00 00 00 00 00 00 00 00 00 00 612   - PASS
Rank0: 256MB(auto)-2T-11
AddrBus test pass!
NAND init
chk page: 00000500
chk page: 00000540
chk page: 00000580
chk page: 000005c0
bbt blk:00000014
bbt page:00000000
0000000000000000000000000000000000000000000000000000000000000000
Load FIP HDR from NAND, src: 0x0000c000, des: 0x01700000, size: 0x00004000
Load BL3x from NAND, src: 0x00010000, des: 0x01704000, size: 0x00080000
NOTICE:  BL31: v1.3(release):a1a8551
NOTICE:  BL31: Built : 15:59:55, Nov  9 2017
NOTICE:  BL31: AXG normal boot!
NOTICE:  BL31: BL33 decompress pass
[Image: axg_v1.1.3268-b93dd79 2017-12-01 14:22:18 huan.biao@droid12]
OPS=0x42
19 a dc b6 fa 24 94 ac ef 14 fb dd bl30:axg ver: 9 mode: 0
bl30:axg thermal0
[0.014522 Inits done]
secure task start!
high task start!
low task start!
ERROR:   Error initializing runtime service opteed_fast
 楼主| 发表于 2024-10-17 18:34:11 | 显示全部楼层
求大佬们看看帮帮忙 本来是上不了网 现在是机都开不了了
发表于 2024-10-19 10:46:59 | 显示全部楼层
换版简单一点
GMT+8, 2025-9-15 03:28 , Processed in 0.505915 second(s), 15 queries , MemCached On.
