楼主: zbsyouran
[硬件DIY] 闲鱼10块钱包邮的鸿雁带计量半成品插座改ESPHOME + Tasmota
发表于 2024-12-24 22:43:49 | 显示全部楼层
前几天闲着没事也买了块这个板子,根据楼主的描述仔细看了下板子,这板子是采用HWL8012来检测功率,HWL8012是个将电压电流的模拟信号转为脉冲信号给下面的单片机来检测功率的芯片,有三个输出脚分别为CF、CF1、SEL,其中CF1脚是由SEL脚来切换输出检测电流和电压的脉冲信号,CF脚输出有功高频脉冲,这板子只利用了其中CF通过隔离光耦输出到esp8266,估计设计时为了节约隔离光耦成本另两个脚是空置的,但esphome到HLW8012的语法必须要这三个引脚,所以楼主用了几个没用的引脚来分配给它。找了个以前闲置的德力
substitutions:
  voltage_divider: "1991"  # 电压分压比
  current_resistor: "0.000694"  # 检流电阻
# HLW8012传感器配置
  - platform: hlw8012
    current_resistor: ${current_resistor}  # 检流电阻值
    voltage_divider: ${voltage_divider}  # 电压分压比
    cf_pin:
      number: GPIO14  # CF 引脚
      mode: INPUT
      #inverted: true  # 在这里直接反转信号
    cf1_pin:
      number: GPIO2  # CF1 引脚
      mode: INPUT
    sel_pin:
      number: GPIO0  # SEL 引脚
      mode: OUTPUT
    power:
    voltage:
    current:
    update_interval: 10s
# 开机时间WI-FI信号及信号强度
  - platform: uptime
    update_interval: 300s
    internal: true
  - platform: wifi_signal
    update_interval: 30s
    internal: true
    entity_category: "diagnostic"
  - platform: copy
    source_id: wifi_signal_db
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    unit_of_measurement: "Signal %"
text_sensor:
  - platform: wifi_info
    ip_address:
      icon: mdi:ip
  - platform: template
    lambda: |-
      uint32_t dur = id(uptime_s).state;
      int dys = 0;
      int hrs = 0;
      int mnts = 0;
      if (dur > 86399) {
        dys = trunc(dur / 86400);
        dur = dur - (dys * 86400);
      if (dur > 3599) {
        hrs = trunc(dur / 3600);
        dur = dur - (hrs * 3600);
      if (dur > 59) {
        mnts = trunc(dur / 60);
        dur = dur - (mnts * 60);
      char buffer[40];  // 增加缓冲区大小
      snprintf(buffer, sizeof(buffer), "%ud %02uh %02um %02us", dys, hrs, mnts, dur);  // 使用 snprintf
      return {buffer};
    icon: mdi:clock-start
    update_interval: 60s
# GPIO开关配置
switch:
  - platform: gpio
    pin: GPIO15
    restore_mode: ALWAYS_ON
    on_turn_on:
      - output.turn_on: Orange_led
    on_turn_off:
      - output.turn_off: Orange_led
  - platform: gpio
    pin: GPIO13
    on_turn_on:
      - output.turn_on: blue_led  # USB开启时点亮status_led
    on_turn_off:
      - output.turn_off: blue_led
# LED和按钮配置
output:
  - platform: gpio
    pin: GPIO12
    inverted: true  # 反转信号
  - platform: gpio
    pin: GPIO05
# 按钮配置
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO04
      #inverted: true
      mode:
        input: true
        pullup: true
    internal: true #此按钮不在HA中显示
    on_multi_click:
    - timing:  #单击
        - ON for at most 1s
        - OFF for at least 0.5s
      then:
        - switch.toggle: relay
        - logger.log: "[Single Click] toggle relay"
    - timing:  #双击
        - ON for at most 1s
        - OFF for at most 0.3s
        - ON for at most 1s
        - OFF for at least 0.2s
      then:
        - switch.toggle: usb
        - logger.log: "[Double Click] toggle usb"
    - timing:  #长按
        - ON for 1s to 3s
      then:
        - switch.turn_off: usb
        - switch.turn_off: relay
        - logger.log: "[Single Long Click] both off"
time:
  - platform: sntp
里面的位置正好够尺寸
里面的位置正好够尺寸
掏出个USB孔
掏出个USB孔
随便整了个按键
随便整了个按键
发表于 2024-12-25 11:01:45 | 显示全部楼层
把玩了下发现这个东西实用性不是很大,没有外壳去买个外壳要十多块钱,改到插座里用体积又太大,海鲜市场上10元左右的功能接近的多得去,而且体积小塞插座里也很方便。
带电量hlw8012检测芯片引脚完整能检测电压电流
去掉一个口正好塞下保留原来的电源开关
去掉一个口正好塞下保留原来的电源开关
发表于 2024-12-30 02:59:55 | 显示全部楼层
还是十几块的和家亲带计量比较香 有的能用tuya接入 有的能博联接入 有的能和家亲接入 比较完美的还是博联接入
发表于 2025-4-25 19:34:20 | 显示全部楼层
准备试试
发表于 2025-7-6 15:49:25 | 显示全部楼层
鸿雁有没有直接接入homeassistant的方法?就像小米的hacs那样的
发表于 2025-7-24 22:12:30 | 显示全部楼层
并且还有16A型号可选,16A那个本身带hlw8012计量芯片,但是原厂PCB没有布置走线,但升级官方固件后却支持计量功能,只是不显示,推测是后续版本硬件做了改进以适应计量固件,这个16A要想实现计量功能需添加一个光耦飞线即可   大佬 16a  怎么飞线
发表于 2025-7-24 22:50:37 来自手机 | 显示全部楼层
感谢大佬无私奉献
GMT+8, 2025-9-16 03:16 , Processed in 0.117096 second(s), 12 queries , MemCached On.
