查看: 3379|回复: 14
[硬件DIY] 服务器CRPS电源取电板通过esphome接入homeassistant
发表于 2024-8-28 10:04:39 | 显示全部楼层 |阅读模式
手头有一个富裕的服务器电源,想做个取电板,百度了一下有大神做的是CSRS通过I2C接入esphome,本人尝试了一下利用CRPS上的I2C接入,失败了!不通用,而且本人编程小白,所以还是果断放弃,另辟蹊径
本板可以实现两路电源的通断控制;
3路电源输出电流、电压、功率、电能、监测;
温度监测
预留CRPS电源I2C接入接口,供后期大神接入
预留内置风扇的PWM控制接口,以便日后对内置控制控制的需求;
上电后延时自动开启电源,开启两路输出(可esphome自定义调整)。
先上效果图:
加个班,焊接:
装机:
OK啦:
打完收工!
附嘉立创打板文件和编程小白的代码,原件参数基本在板子上都标出来了
globals:
  # flash保存昨日抄表数(每天0点更新保存)
  - id: global_yesterday_energy
    type: float
    restore_value: yes
    initial_value: '0.000'
esphome:
  friendly_name: "crps-power"
  on_boot:
    priority: 600
    then:
      - delay: 5s
      - switch.turn_on: switch0
      - delay: 1s
      - switch.turn_on: switch1
      - delay: 1s
      - switch.turn_on: switch2
  comment: 服务器电源、功率监测、ONU和ROUTER通断控制、温度监测等
esp8266:
  board: esp01_1m
api:
  reboot_timeout: 0s
ota:
  - platform: esphome
    password: "143752f111a57aa407c64a6f10d5f408"
web_server:
  port: 80 # web端口
wifi:
  networks:
  - ssid:
    password:
  reboot_timeout: 0s
  ap:
    ssid: "crps-power Fallback Hotspot"
    password: "kp1uMJ8NFcRQ"
captive_portal:
i2c:
   - id: bus_a
     sda: GPIO4
     scl: GPIO5
     scan: true
time:
  - platform: homeassistant
    timezone: UTC-8
    on_time:
      - seconds: 0
        minutes: 0
        hours: 0
        then:
          - if:
              condition:
                time.has_time:
              then:
                - lambda: |-
                    id(global_yesterday_energy) = id(CRPS_energy).state;
  - platform: ntc
    sensor: resistance_sensor
    calibration:
      b_constant: 3950
      reference_temperature: 25°C
      reference_resistance: 10kOhm
    name: NTC Temperature
  - platform: resistance
    sensor: source_sensor
    configuration: DOWNSTREAM
    resistor: 27kOhm
  - platform: adc
    pin: A0
    update_interval: 60s
  - platform: uptime
  - platform: wifi_signal
    name: "CRPS WiFi Signal"
  - platform: ina3221
    address: 0x40
    channel_1:
      shunt_resistance: 0.02 ohm
      current:
        name: "CRPS Channel 1 Current"
      power:
        name: "CRPS Channel 1 Power"
      bus_voltage:
        name: "CRPS Channel 1 Bus Voltage"
      shunt_voltage:
        name: "CRPS Channel 1 Shunt Voltage"
    channel_2:
      current:
        name: "CRPS Channel 2 Current"
      power:
        name: "CRPS Channel 2 Power"
      bus_voltage:
        name: "CRPS Channel 2 Bus Voltage"
      shunt_voltage:
        name: "CRPS Channel 2 Shunt Voltage"
    channel_3:
      current:
        name: "CRPS Channel 3 Current"
      power:
        name: "CRPS Channel 3 Power"
      bus_voltage:
        name: "CRPS Channel 3 Bus Voltage"
      shunt_voltage:
        name: "CRPS Channel 3 Shunt Voltage"
  - platform: total_daily_energy
    name: CRPS Channel 1 energy
    power_id: power1
    unit_of_measurement: 'kWh'
    state_class: total_increasing
    device_class: energy
    accuracy_decimals: 3
    filters:
      - multiply: 0.001
    name: CRPS Channel 2 energy
    power_id: power2
    filters:
      - multiply: 0.001
    name: CRPS Channel 3 energy
    power_id: power3
    filters:
      - multiply: 0.001
  - platform: template
    lambda:
      return id(energy1).state + id(energy2).state + id(energy3).state;
    unit_of_measurement: 'W'
    lambda:
      return id(power1).state + id(power2).state + id(power3).state;
    unit_of_measurement: 'A'
    lambda:
      return id(current1).state + id(current2).state + id(current3).state;
    device_class: "energy"
    state_class: "total_increasing"
    icon: mdi:lightning-bolt
    unit_of_measurement: kWh
    lambda:
      return id(global_yesterday_energy);
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO15
      mode:
        input: true
        pullup: true
      inverted: true
    on_click:
      - min_length: 3s
        max_length: 5s
        then:
          - switch.toggle: switch0
      - min_length: 50ms
        max_length: 350ms
        then:
          - switch.toggle: switch2
  - platform: gpio
    pin:
      number: GPIO0
      mode:
        input: true
        pullup: true
      inverted: true
    on_press:
      then:
         - switch.toggle: switch1
switch:
  - platform: gpio
    pin: 2
  - platform: gpio
    pin:
      number: GPIO14
 #     inverted: true
    on_turn_off:
      then:
        - delay:
            seconds: 4
  - platform: gpio
    pin:
      number: GPIO13
 #     inverted: true
    on_turn_off:
      then:
        - delay:
            seconds: 3
Gerber_PCB1_2024-08-28.zip (147.25 KB, 下载次数: 6, 售价: 5 金钱)
物料清单
BOM_Board1_Schematic1_2024-08-28.xlsx (9.96 KB, 下载次数: 11)
aca
发表于 2024-8-28 10:15:29 | 显示全部楼层
看不懂...觉得很厉害...
Ari 手机认证
发表于 2024-8-28 10:41:20 | 显示全部楼层
太牛了吧,这板子用料
发表于 2024-8-28 11:54:22 | 显示全部楼层
发表于 2024-8-31 09:09:29 | 显示全部楼层
好厉害啊,真想学这个
发表于 2024-11-10 20:34:31 | 显示全部楼层
你好 !
 楼主| 发表于 2024-11-10 20:46:49 | 显示全部楼层
tanbobo 发表于 2024-11-10 20:34
你好 !有个 事情 想麻烦一下你!力创打版 羊毛已薅,但是 买元件的时候遇见一个问题 用几个的电容 电阻 都 ...
我也是业余爱好,不专业那总,我一般买一百个那种两元包邮的
发表于 2024-11-10 21:11:41 | 显示全部楼层
关键是 太多了
 楼主| 发表于 2024-11-10 21:21:43 | 显示全部楼层
一百个没多少,常玩电子常用元件不可少
发表于 2024-11-10 21:31:12 | 显示全部楼层
。。。100个才一两块,立创还免邮费
GMT+8, 2025-9-19 02:55 , Processed in 1.197095 second(s), 16 queries , MemCached On.
