查看: 1291|回复: 2
升级最新版本出现问题
Awe7 手机认证
发表于 2024-8-17 21:52:24 | 显示全部楼层 |阅读模式
Welcome to the Home Assistant command line.
Waiting for Supervisor to startup...
System information
Error returned from Supervisor: System is not ready with state: setup
pve虚拟机 出现这个报错无法进入系统
root@homeassistant:/ # wgver
OS_NAME    : Home Assistant OS
OS_ARCH    : amd64
OS_VERSION : 12.4.1
OS_META_ID : 94aed02d94
FW_TYPE    : x86-64-vm
FW_MODEL   : x86-64-vm
BUILD_DATE : 20240815_145309
BUILD_ZONE : cn
ZONE_MODES : cn
USE_ZONE   : cn
以下是日志
root@homeassistant:/ # docker logs hassio_supervisor
[13:39:26] INFO: Using udev information from host
[13:39:26] INFO: Starting local supervisor watchdog...
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_uri.py:51: SyntaxWarning: invalid escape sequence '\w'
  _UNRESERVED = "[\w\-\.]"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3.py:265: SyntaxWarning: invalid escape sequence '\{'
  part_pattern = "^(\{0}|\{1})$".format(self.WILDCARD_ONE,
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp_simple.py:48: SyntaxWarning: invalid escape sequence '\w'
  _ALPHANUM_PATTERN = "\w"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp_simple.py:51: SyntaxWarning: invalid escape sequence '\d'
  _LANGTAG_PATTERN = "^([a-z]{2,3}(-([a-z]{2}|[\d]{3}))?)$"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_wfn.py:49: SyntaxWarning: invalid escape sequence '\!'
  _PUNC_NO_DASH = "\!|\"|\;|\#|\$|\%|\&|\'|\(|\)|\+|\,|\.|\/|\:|\<|\=|\>|\@|\[|\]|\^|\`|\{|\||\}|\~"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_wfn.py:77: SyntaxWarning: invalid escape sequence '\{'
  _spec1 = "\{0}".format(WILDCARD_ONE)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_wfn.py:78: SyntaxWarning: invalid escape sequence '\{'
  _spec2 = "\{0}".format(WILDCARD_MULTI)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_wfn.py:86: SyntaxWarning: invalid escape sequence '\w'
  _body1 = "\w|{0}".format(_quoted1)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_wfn.py:87: SyntaxWarning: invalid escape sequence '\w'
  _body2 = "\w|{0}".format(_quoted2)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_fs.py:50: SyntaxWarning: invalid escape sequence '\w'
  _UNRESERVED = "\w|\.|\-"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_fs.py:51: SyntaxWarning: invalid escape sequence '\!'
  _PUNC = "\!|\"|\;|\#|\$|\%|\&|\'|\(|\)|\+|\,|\/|\:|\<|\=|\>|\@|\[|\]|\^|\`|\{|\||\}|\~|\-"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_fs.py:77: SyntaxWarning: invalid escape sequence '\{'
  _logical = "(\{0}|{1})".format(VALUE_ANY, VALUE_NA)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_fs.py:78: SyntaxWarning: invalid escape sequence '\{'
  _quest = "\{0}".format(WILDCARD_ONE)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_3_fs.py:79: SyntaxWarning: invalid escape sequence '\{'
  _asterisk = "\{0}".format(WILDCARD_MULTI)
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp_anyvalue.py:35: SyntaxWarning: invalid escape sequence '\*'
2024-08-17 13:39:28.429 INFO (MainThread) [__main__] Initializing Supervisor setup
2024-08-17 21:39:28.473 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: qemux86-64
2024-08-17 21:39:28.476 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.fastgh.com/home-assistant/amd64-hassio-supervisor with version 2024.08.0
2024-08-17 21:39:28.477 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
2024-08-17 21:39:28.558 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2024-08-17 21:39:28.560 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-08-17 21:39:28.561 INFO (MainThread) [__main__] Setting up Supervisor
2024-08-17 21:39:29.458 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2024-08-17 21:39:29.496 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2024-08-17 21:39:29.497 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2024-08-17 21:39:29.498 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2024-08-17 21:39:29.498 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2024-08-17 21:39:29.499 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2024-08-17 21:39:29.499 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2024-08-17 21:39:29.500 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2024-08-17 21:39:29.500 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2024-08-17 21:39:29.500 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2024-08-17 21:39:29.501 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2024-08-17 21:39:29.604 INFO (MainThread) [supervisor.host.services] Updating service information
2024-08-17 21:39:29.607 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-08-17 21:39:29.678 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-08-17 21:39:29.721 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2024-08-17 21:39:29.736 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2024-08-17 21:39:29.736 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.wghaos.com/x86-64-vm-release-cn.json
2024-08-17 21:39:29.912 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.fastgh.com/home-assistant/amd64-hassio-cli with version 2024.07.0
2024-08-17 21:39:29.927 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.fastgh.com/home-assistant/amd64-hassio-dns with version 2024.04.0
2024-08-17 21:39:29.934 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2024-08-17 21:39:29.939 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.fastgh.com/home-assistant/amd64-hassio-audio with version 2023.12.0
2024-08-17 21:39:29.948 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.fastgh.com/home-assistant/amd64-hassio-observer with version 2023.06.0
2024-08-17 21:39:29.957 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.fastgh.com/home-assistant/amd64-hassio-multicast with version 2024.03.0
2024-08-17 21:39:29.965 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
2024-08-17 21:39:29.967 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.fastgh.com/home-assistant/qemux86-64-homeassistant with version 2024.8.1
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp1_1.py:57: SyntaxWarning: invalid escape sequence '\w'
  _STRING = "\w\.\-,\(\)@\#"
/usr/local/lib/python3.12/site-packages/cpe/comp/cpecomp2_2.py:52: SyntaxWarning: invalid escape sequence '\d'
  _VALUE_PATTERN = "^([\d\w\._\-~%]+)$"
/usr/local/lib/python3.12/site-packages/cpe/cpe2_3_fs.py:97: SyntaxWarning: invalid escape sequence '\:'
  _parts_pattern = "^cpe:2.3:{0}\:{1}\:{2}\:{3}\:{4}\:{5}\:{6}\:{7}\:{8}\:{9}\:{10}$".format(
2024-08-17 21:39:29.997 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.4.1 / BootSlot B
2024-08-17 21:39:30.376 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
2024-08-17 21:39:30.376 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/fb59d657 repository
2024-08-17 21:39:30.376 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
2024-08-17 21:39:30.378 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/45df7312 repository
2024-08-17 21:39:30.379 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/e399101c repository
2024-08-17 21:39:30.380 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a889bffc repository
2024-08-17 21:39:30.380 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/d5369777 repository
2024-08-17 21:39:30.382 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/7eca76cc repository
2024-08-17 21:39:30.384 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
2024-08-17 21:39:30.384 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/b9a594eb repository
2024-08-17 21:39:30.384 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/243ffc37 repository
2024-08-17 21:39:30.858 INFO (MainThread) [supervisor.store] Loading add-ons from store: 245 all - 245 new - 0 remove
2024-08-17 21:39:30.933 INFO (MainThread) [supervisor.addons.manager] Found 12 installed add-ons
2024-08-17 21:39:30.952 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-mosquitto with version 6.4.1
2024-08-17 21:39:30.959 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/esphome/esphome-hassio with version 2024.7.3
2024-08-17 21:39:30.963 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-rpc_shutdown with version 2.5
2024-08-17 21:39:30.966 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-configurator with version 5.8.0
2024-08-17 21:39:30.969 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-vlc with version 0.3.0
2024-08-17 21:39:30.974 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/vscode/amd64 with version 5.15.0
2024-08-17 21:39:30.977 INFO (MainThread) [supervisor.addons.addon] No e399101c_ssh addon Docker image ghcr.io/hassio-addons/ssh/amd64 found
2024-08-17 21:39:30.977 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/hassio-addons/ssh/amd64 with tag 18.0.0.
2024-08-17 21:39:30.978 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/node-red/amd64 with version 18.0.5
2024-08-17 21:39:30.984 INFO (MainThread) [supervisor.docker.interface] Attaching to alexxit/go2rtc with version 1.9.4
2024-08-17 21:39:30.987 INFO (MainThread) [supervisor.docker.interface] Attaching to zigbee2mqtt/zigbee2mqtt-amd64 with version 1.39.1-1
2024-08-17 21:39:30.992 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-samba with version 12.3.2
2024-08-17 21:39:31.004 INFO (MainThread) [supervisor.docker.interface] Attaching to binaryify/netease_cloud_music_api with version v4.14.1
我使用了
docker restart homeassistant
可以进入系统进入系统内  无法加载 Supervisor 面板!
但因为hassio_supervisor 无法正常启动导致许多功能无法正常使用、
本想改下网关指向魔法网关的但是无法在网络设置 内网关。
网络适配器
配置集成所使用的网络适配器。目前此设置仅影响组播流量。需要重新启动才能生效。
使用大佬的ota未果
你们开了新帖没看到。才发现因为特殊原因,有些地区没办法升级os。
手工升级方法如下:
1、使用7681登录。
2、login
3、wget -O - http://ota.wghaos.com/upos | bash -
4、reboot
发表于 2024-8-19 20:12:12 | 显示全部楼层
开了新帖是在哪个帖子呢?
发表于 2024-8-20 13:33:23 | 显示全部楼层
你等官方更新吧。
这个是官方镜像容器内的问题
大概是官方镜像打包出问题了。
冬瓜haos对镜像没做太多处理(改多了兼容性不行,尽量原汁原味)。
这种容器镜像错误,只能等官方镜像升级修正
你过几个小时,用wgturbo clear清掉所有官方镜像
然后reboot,然后耐心等系统开机(会比较慢,需要下一堆镜像,确认你加速能用)
也可以
你可以用wgturbo autoscan -S 1 测试加速站(可以多测两次,因为第一次因为dns的问题可以测不准)
wgsys pstat core
wgsys pstat su
wgsys pstat cli
wgsys pstat ob
wgsys pstat mc
wgsys pstat audio
wgsys pstat dns
缓存镜像
wgha d su create 重建su服务
然后重启也可以
GMT+8, 2025-8-2 16:20 , Processed in 0.922920 second(s), 11 queries , MemCached On.
