楼主: xuyong
[技术探讨] 亲邻门禁,有偿请大佬帮忙接入HA
scry
发表于 2024-8-19 11:58:29 | 显示全部楼层
ghostist 发表于 2024-8-19 11:33
有几个qadx.qinlinad.com的请求
其中3个域名后带/ad
有一个不带的 qadx.qinlinad.com/monitor/event
为什么你们都能抓到包,我抓登陆请求就是网络错误
发表于 2024-8-19 13:15:46 | 显示全部楼层
其中3个域名后带/ad
我点了8次开门,只有我发的那个请求,请求了8次,其他地址都只请求了三四次
发表于 2024-8-19 13:28:08 | 显示全部楼层
其中3个域名后带/ad
curl -X POST 'https://qadx.qinlinad.com/monitor/event' \
  -H 'Host: qadx.qinlinad.com' \
  -H 'Accept: */*' \
  -H 'qplatform: 1' \
  -H 'qvendor: APPLE' \
  -H 'Accept-Encoding: gzip, deflate, br' \
  -H 'Accept-Language: zh-CN,zh-Hans;q=0.9' \
  -H 'qsdkversioncode: 100' \
  -H 'Content-Type: application/json;charset=UTF-8' \
  -H 'Content-Length: 353' \
  -H 'User-Agent: App/3103 (iPhone; CPU iPhone OS 15_1 like Mac OS X)' \
  -H 'qchannel: Apple Store' \
  -H 'qversioncode: 3103' \
  -H 'Connection: keep-alive'  \
   --data '{
  "age" : 0,
  "adId" : "3fc4465d-df9e-4585-8b73-95a969d0db76",
  "communityId" : "10214",
  "time" : 1723570912,
  "type" : 1,
  "slotId" : "ADS-201210-11110485093",
  "userId" : 9364844,
  "adMode" : 0,
  "group_id" : "1",
  "city" : "南京市",
  "device" : "5CCA94B6-ECFC-46FB-A2BB-1372CA9055B3",
  "communityName" : "榴美颂",
  "gender" : 0
  --compressed
发表于 2024-8-19 15:19:45 | 显示全部楼层
https://www.oylong.com/others/re ... -open-door-app.html
插个眼,这个链接有大佬搞成功了,但是瞄了一眼感觉很复杂就没继续研究了,安卓的可以装个老版本的app,3.0.4无广告
发表于 2024-8-19 15:58:50 | 显示全部楼层
快刀青衣 发表于 2024-8-19 15:19
https://www.oylong.com/others/reverse-summary-of-packet-capture-in-the-neighbor-open-door-app.html
我用IOS下载了3.1.4版本,没有广告了,重新抓包,正确的请求如下
curl -X POST 'https://ulogs.umeng.com/unify_logs' \
  -H 'Host: ulogs.umeng.com' \
  -H 'SM-IMP: 1' \
  -H 'X-Umeng-Sdk: a/7.3.7 4.8.3/iOS/%E4%BA%B2%E9%82%BB%E5%BC%80%E9%97%A8/iPhone13,4/15.6.1 761BF03C7B457FD5F96866E8455B8279' \
  -H 'Accept: */*' \
  -H 'Msg-Type: envelope/json' \
  -H 'Cache-Control: no-cache' \
  -H 'Content-Type: ut/a4.8.3' \
  -H 'X-Umeng-UTC: 1724045469898' \
  -H 'User-Agent: app/1 CFNetwork/1335.0.3 Darwin/21.6.0' \
  -H 'Content-Length: 1889' \
   --data '
   V1.1
   5f8fa167fac90f1c19a7fef9
   @d3d7031460c6a548b510c52955242c4ca0908e07dfc4230e9f7a61e41c84c266     fÂØ
    ^xœ­VÍnãÈ~•€žS
Í&)’öÐIY²ØZI”e2^Í?‰"G¤M‰Až!@9å–K.ùA^fÁ¾EºIiÆd‘K “ê®®®úXUýUâȞ¤§*òJîæWeå{:þÕ'.ØûOU”Ü
/Cˆ’8P…ïqÙLå‡ùÜ
7à @Ф¨/
dYÖ/«‚6„pÄõ¸²"‡ê[k@†rûÀÌ=íŸ3îô8ÿù@*
»QyI¤Ê'º·¢ÛÀë¯=îjÇp^с:Æsjºi1 wŧ°6
ÍÈ„A8Jk
÷Es/&{ý¡±ðý †ÚѽÝE5ڌu’Ç‘v¥c1ÝL¡}'ܯìÐH³álÔ,¯çåGèDÎØ½U+ï:Olå£<{ù~uL¼ÐþŽ:¿ò*ê|„Ù0ª&m†£ºFôPÆÇ£
ÙP·Ði£úÛg´E#º<L6‰«ïê        B&So÷ ´Ë]73*gQ"´ ¢Ìx
–ñD4›mƒ5šZrœ[ž¸X¯Ü]¯q£ÍmŽÐ–îqŒb|œl©#­5»hß:Ù,3{±»€‹µ£›ñP[®€°°§™µÔp¬Ws
óMË®M}:ĺ~ÂÖö!
—dY®&ÌQûéz ª…ƒ.¶·’m!€ÇÓÔnîSGC’eJöæ>›[T–9‘½ÑE;Njl-Ŷ>¾‹M„¾‰
>Íbvö·ÅñVÂÍ:Ö0¢¶3¬á
§‘méü|¼8ÙÍ0qâµh7ö{܋÷¸‡÷À§É%oc£8:Ž}_㌟.uãÎՆµs?=-ÇEyWÿïÛ_r·¨M
uÏ´¿3«WoeožŸ±V£QçÍÎq™Øp—Ú°jü
@¬*Ÿ}B«(^åšW™Œ¼P‘ØWú›¹eÕ½«œ‰y©?èóLžåì`y
)‹<jk­Ë}¡/³™•ô”rŸÿöçŸ~ó÷ÿñëŸ~÷G&.ô¬ª=.óè"€7 ¼ýoÍìØ>T¿XU9Õ¦¢ŁÙn—…‰!Ø3#”(øPé³Ã6™¯Ø¤H¶ ]žõ?Fû4Ú'Aõëºî/¢ý,Úϋ`¯åù¡ûFÍÓKÀN¨Ðû̓wžó}µý`rž_¾0ú²©>ãžò] ¼ü7ŸÅI%@ÝÀ“¨¡â«‚J‚P•‚0t        Q\H¢¢Hí‡q/ñªMQÕp7
3H˜»Ïýӏ¿ÿç¿û—Ïÿú[I”^¸îªf÷”!_XÜrÊÂ\ÔÅãÀ” ,+¿ä¡"2IJö,DÍîú–ìË뎤Ü6Ç-Û:
ÛÔVyBg TO–Ù÷ :¡"ø¢/xª" ™‡!‘Ä@ô ƒP„W}.¨%]±MŸŸ1Lßïò}À
½a¶¥P                ?Câ© ä=^%rHDž>"
SÂÐ~zä¼)w´Oô9š֐Y i¯:œGYGû :
räyöE´
ÎÃÖêÜÃmìÖep8{håô,ÙIç-)3È¿¶ÕÖÖ'ß må\e+(Šúé9{zñr?8Gõ"j
§;a¬p¢¬xßæì¥ÁôÙ–;w| é±Ý¹™”ººDéлEÛµ°|ñ²uGKçöFzv6õ…ò¦‹‡a=1h{¦iÇÎGò°ÎÃä¢34ÏaSÝ ÁI½=.\(^Ö
<ÅYÜi
)í9™~YKÞÐPõ³”õæé\-ywó•>oJIŒ‚-#²Ú²ûÄÑpbfSJÇégFêl JדÃgt¾ìGVgu( OÎòp7ë
>lZÞ        kÔ¦µ`-PšwªÙH?6J×PwÞí0ô³û“ Ó÷ÒêÐÌâí³Yÿ_Ú`kD{˜¦ÞX=ù†Z»ðXØBò5 ]+¸£­ü¿`±x%ÂY|n›ö×ܬ ?³ºüëã¯õâŒ
ðM,,3F'Ló3ã|…Žf“Ÿp“\³þÑÆ–Ö_ך&½À5¤‡k—&\Ô´]&xc$xŒ3ÛJ Ìl€Ðwí]§fg€
š–/<úœµ70% ¼¤ò® ÄAàû‚]?Tɀ        EH“¨²2€K        AˆçºtŸâCø¡¤xîõõ?š;)+
   @4e0fdb1409c9ea48071fd329582b7b4c449f9707c6cb730edd7593e4808b0000
            5b932995259ac1f1173d2d748f29c42a
  --compressed
scry
发表于 2024-8-19 16:40:09 | 显示全部楼层
curl -X POST 'https://ulogs.umeng.com ...
这是u盟的云log,没啥用,给开发者看的
发表于 2024-8-19 16:48:19 | 显示全部楼层
刚刚看了34楼发的链接,好像是做了防抓包处理
scry
发表于 2024-8-19 16:54:22 | 显示全部楼层
我抓登陆,会提示网络错误,这开门有反馈吗,建议从反馈入手,或者从登陆开始查,一般业务请求域名都是固定的
发表于 2024-8-19 19:56:44 | 显示全部楼层
你是对的,就是 http://cmt.comp.360os.com/adv/t/v1/report 这个接口,已经完成了加密解密,使用了RC4算法,密钥是 55191f3ff65aeca9998115db565b49cca8d43d8098fec107944cc2122d8ee5c8
scry
发表于 2024-8-19 20:19:49 | 显示全部楼层
a22218279 发表于 2024-8-19 19:56
你是对的,就是 http://cmt.comp.360os.com/adv/t/v1/report 这个接口,已经完成了加密解密,使用了RC4算 ...
大佬!这密钥咋弄出来的
GMT+8, 2025-9-16 04:52 , Processed in 1.297919 second(s), 11 queries , MemCached On.
