查看: 1355|回复: 6
[硬件DIY] D1 MINI 烧录后搜索不到8266的WiFi信号
发表于 2024-8-12 10:26:40 | 显示全部楼层 |阅读模式
D1 MINI 烧录后搜索不到8266的WiFi信号 请大佬指导一下  接线是TX-RX RX-TX   GND-GND-D3  5V-5V
*************************** START ****************************
START TIME: 202408120902
CONNECT BAUD: 115200
set state: ESP_DL_SYNC
serial port opened
baud:115200
root baud:115200
===============BAUD : 115200===============CALL DEVICE SYNC
connecting...
0x3ff00050: 41720000
0x3ff00054: 02007e9f
0x3ff00058: c900b000
0x3ff0005c: 00500291
check_err_0: 0bcheck_err_1: 00check_err_2: 00check_err_3: 02check_err_4: 0b====================
EFUSE NORMAL MODE
CRC IN MODE 1:
crc_calc_res: 201
target crc val: 201
CRC IN MODE 1:
crc_calc_res: 114
target crc val: 114
EFUSE LOG:
EFUSE LOG:
REG0:41720000
REG1:02007E9F
REG2:c900b000
REG3:00500291
EFUSE NORMAL MODE
EFUSE CHECK PASS...48bit mac
50 02 91 7e 9f 41CUSTOM_ID: 0C 90 00 00 00 07 20 00
MAC AP : 52-02-91-7E-9F-41
MAC STA: 50-02-91-7E-9F-41
get mac res: 1
get flash id : 0x001660c4
manufacturer_id: 0xc4
device_id: 0x6016
com closed
Use time: 0 s
Download result: PASS
*************************** END ****************************
serial port opened
baud:115200
root baud:115200
connecting...
EFUSE NORMAL MODE
CRC IN MODE 1:
crc_calc_res: 201
target crc val: 201
CRC IN MODE 1:
crc_calc_res: 114
target crc val: 114
EFUSE LOG:
EFUSE LOG:
REG0:41720000
REG1:02007E9F
REG2:c900b000
REG3:00500291
EFUSE NORMAL MODE
get mac res: 1
device_id: 0x6016
Wrote 1024000 bytes at 0x00300000 in 6.6 seconds (effective 1250.3 kbit/s)...
Hash of data verified.
Leaving...
com closed
Use time: 8 s
START TIME: 202408120940
serial port opened
baud:115200
root baud:115200
connecting...
EFUSE NORMAL MODE
CRC IN MODE 1:
crc_calc_res: 201
target crc val: 201
CRC IN MODE 1:
crc_calc_res: 114
target crc val: 114
EFUSE LOG:
EFUSE LOG:
REG0:41720000
REG1:02007E9F
REG2:c900b000
REG3:00500291
EFUSE NORMAL MODE
get mac res: 1
device_id: 0x6016
com closed
Use time: 1 s
serial port opened
baud:115200
root baud:115200
connecting...
EFUSE NORMAL MODE
CRC IN MODE 1:
crc_calc_res: 201
target crc val: 201
CRC IN MODE 1:
crc_calc_res: 114
target crc val: 114
EFUSE LOG:
EFUSE LOG:
REG0:41720000
REG1:02007E9F
REG2:c900b000
REG3:00500291
EFUSE NORMAL MODE
get mac res: 1
device_id: 0x6016
Wrote 1024000 bytes at 0x00300000 in 6.5 seconds (effective 1250.9 kbit/s)...
Leaving...
com closed
Use time: 8 s
START TIME: 202408120955
serial port opened
baud:115200
root baud:115200
connecting...
EFUSE NORMAL MODE
CRC IN MODE 1:
crc_calc_res: 201
target crc val: 201
CRC IN MODE 1:
crc_calc_res: 114
target crc val: 114
EFUSE LOG:
EFUSE LOG:
REG0:41720000
REG1:02007E9F
REG2:c900b000
REG3:00500291
EFUSE NORMAL MODE
get mac res: 1
device_id: 0x6016
com closed
Use time: 2 s
serial port opened
baud:115200
root baud:115200
connecting...
EFUSE NORMAL MODE
CRC IN MODE 1:
crc_calc_res: 201
target crc val: 201
CRC IN MODE 1:
crc_calc_res: 114
target crc val: 114
EFUSE LOG:
EFUSE LOG:
REG0:41720000
REG1:02007E9F
REG2:c900b000
REG3:00500291
EFUSE NORMAL MODE
get mac res: 1
device_id: 0x6016
Wrote 1024000 bytes at 0x00300000 in 6.6 seconds (effective 1250.1 kbit/s)...
Leaving...
com closed
Use time: 8 s
发表于 2024-8-12 11:02:03 | 显示全部楼层
这个开发板不是直接用usb连电脑就能刷吗?干嘛要杜邦线外接?可以试试看直接用   https://tasmota.github.io/install/  这个网页刷,如果还不行,大概率是模块有问题了(我也遇到过)。
 楼主| 发表于 2024-8-12 11:13:15 | 显示全部楼层
tcwj2008 发表于 2024-8-12 11:02
这个开发板不是直接用usb连电脑就能刷吗?干嘛要杜邦线外接?可以试试看直接用   https://tasmota.github.i ...
网页刷机也是要杜邦线的吧
发表于 2024-8-12 11:15:46 | 显示全部楼层
秋流年 发表于 2024-8-12 11:13
网页刷机也是要杜邦线的吧
直接usb连电脑,你这个是开发板,不是那种模块
发表于 2024-8-12 12:35:58 | 显示全部楼层
usb可以直接刷,不知道跟3.3和5v有没有关系,我是usb直接刷的,没有用杜邦线
发表于 2024-8-12 15:50:43 | 显示全部楼层
能插Micro USB线就直接插电脑刷,没必要用杜邦线接ttl小板,多此一举啊
发表于 2024-8-13 08:31:13 | 显示全部楼层
甚至ota都能刷,太方便了
GMT+8, 2025-9-14 03:11 , Processed in 0.745590 second(s), 9 queries , MemCached On.
