查看: 6554|回复: 14
[经验分享] 合宙ESP32c3刷ESPhome和ESPresense 的配置和文件
发表于 2024-7-6 22:56:34 | 显示全部楼层 |阅读模式
合宙的ESP32c3物美价廉,自带通讯模块。但是刷ESPhome和ESPresense 的时候总容易出错。试了试容易错的原因在于要配置双IO 即flash_mode: dio ,而刷ESPresense 需要用到合宙的bootloader以及更改dio配置后重新编译esp32c3.bin
给一下ESPhome 和 ESPresense 的配置和文件,少踩坑
ESPhome配置:
substitutions:
  device: ble_gateway
  device_name: blegateway
esphome:
    platformio_options:
        board_build.flash_mode: dio
        board_build.mcu: esp32c3
esp32:
    board: esp32-c3-devkitm-1
    variant: esp32c3
    framework:
        type: esp-idf
external_components:
  - source: github://myhomeiot/esphome-components
logger:
    hardware_uart: USB_SERIAL_JTAG
    level: DEBUG
api:
  reboot_timeout: 1h
ota:
    - platform: esphome
      password: !secret ota_password
wifi:
    ssid: !secret wifi_ssid
    ap:
      ssid: "$device_name Fallback Hotspot"
      password: !secret ap_password
captive_portal:
web_server:
    port: 80
bluetooth_proxy:
  active: true
esp32_ble_tracker:
ble_gateway:
  on_ble_advertise:
    then:
      - homeassistant.service:
          service: ble_monitor.parse_data
          data:
            packet: !lambda return packet;
            gateway_id: $device_name
      - homeassistant.event:
          event: esphome.on_ble_advertise
          data:
binary_sensor:
  - platform: homeassistant
    entity_id: binary_sensor.ble_gateway
    attribute: discovery
    on_state:
      then:
        lambda: id($device_name).set_discovery(x);
text_sensor:
    attribute: devices
    on_value:
      then:
        lambda: id($device_name).set_devices(x);
  - platform: wifi_info
    ip_address:
      name: $device_name IP address
  - platform: version
  - platform: wifi_signal
    name: $device_name WiFi Signal Sensor
    update_interval: 60s
scerets
wifi_ssid: "xxxx"
wifi_password: "xxxx"
ap_password: "12345678"
ota_password: "12345678"
ESPresense:
命令
esptool.exe --port COM3 write_flash --flash_mode dio -z 0x0000 bootloader_luatos.bin 0x8000 partitions.bin 0xe000 boot_app0.bin 0x10000 esp32c3.bin
文件: esptool-win64.zip (861.95 KB, 下载次数: 105)
参与人数 3金钱 +37 HASS币 +20 收起 理由
leonardo86 + 5 高手,这是高手!
jjcs + 12 高手,这是高手!
+ 20 + 20 感谢楼主分享!
发表于 2024-7-7 09:15:57 | 显示全部楼层
感谢楼主分享,昨天刚踩了坑!!!
发表于 2024-7-7 09:26:34 | 显示全部楼层
还有刷ESPHome接LD2410,竟然不能用原生Tx和Rx,卧就槽了!真坑啊
scry
发表于 2024-7-7 09:52:04 | 显示全部楼层
应该usb串口芯片占用了串口1,导致esp的串口1没办法接别的设备
发表于 2024-7-7 09:58:58 | 显示全部楼层
确定是设计问题,还买了一个Mini版本的ESP32-C3就不用设DIO,原生串口也能用!也是醉了!
发表于 2024-7-10 22:14:10 | 显示全部楼层
为什么我没有遇到这个问题?第一次我直接web刷的,以后就ota了
附上代码
esphome:
  friendly_name: "${friendly_name}"
  build_path: build/$device_name
  on_boot:
    then:
      # - switch.turn_on: sw_hp
esp32:
  board: airm2m_core_esp32c3
  framework:
    type: arduino
# Enable logging
logger:
  #level: ERROR
  # baud_rate: 0 #disable logging over uart
# Enable Home Assistant API
<<: !include common/esp32_auto_off.yaml
web_server:
  port: 80 # web端口
ota:
  platform: esphome
#  password:
substitutions:
  config_version: 'v2022.07.23.001'
  #设备名称(多个dc1改成不一样的,API接入和ESPHOME容器会识别这个作为名称显示)
  device_name: "hp-mama"
  friendly_name: "主卧人在传感器"
  #如果SSID是隐藏的,设置为true
  wifi_fast_connect: 'false'
  #WiFi离线多久后重启设备,秒s/分钟min/小时h,不需要此功能设置为0s,建议设置0s,防止异常重启,或者设置的大一些
  wifi_reboot_timeout: 600s
  #与API服务端失去连接多久后重启设备,秒s/分钟min/小时h,不需要此功能设置为0s,建议设置0s,防止异常重启,或者设置的大一些
  api_reboot_timeout: 60s
wifi:
  networks:
  - ssid: !secret wifi_ssid1
  - ssid: !secret wifi_ssid2
  manual_ip:
    static_ip: 192.168.123.24
    gateway: 192.168.123.1
    subnet: 255.255.255.0
  reboot_timeout: 180s
  # Enable fallback hotspot in case wifi connection fails
  ap:
    ssid:  !secret wifi_ssid_AP
captive_portal:
# i2c:
#   sda: GPIO10
#   scl: GPIO12
#   scan: true
#   id: bus_a
uart:
  tx_pin: 4
  rx_pin: 5
  baud_rate: 256000
ld2410:
  throttle: 30s
顺便发个合宙俩板载led灯的最新代码,解决esp32C3报错的问题
output:
  - platform: ledc
    pin: #GPIO12  #D4
      number: LED1_BUILTIN
      ignore_pin_validation_error: true
    frequency: 2000
    # inverted: true
  - platform: ledc
    pin: #GPIO13  #D5
      number: LED2_BUILTIN
    frequency: 2000
参与人数 1金钱 +12 收起 理由
jjcs + 12 感谢楼主分享!
 楼主| 发表于 2024-7-10 23:12:50 | 显示全部楼层
附上代码
请教一下,刷了多个esp后,怎么看设备是在哪个房间呢
发表于 2024-7-12 11:14:10 | 显示全部楼层
附上代码
看版本的,有的板子设计就没坑。
发表于 2024-7-12 12:35:59 | 显示全部楼层
合宇AIR780E 能刷esphome吗?
jjcs 手机认证
57
发表于 2024-7-15 00:33:02 | 显示全部楼层
异想天开
GMT+8, 2025-9-14 03:05 , Processed in 0.332911 second(s), 16 queries , MemCached On.
