查看: 7045|回复: 28
[基础教程] 鹿客V5Max通过xiaomigateway3插件接入homeassistant
发表于 2024-5-27 19:54:10 | 显示全部楼层 |阅读模式
前提:需要有个xiaomigateway3支持的小米多模网关,我是小米多模网关1代,安装好ha插件xiaomigateway3项目地址:https://github.com/AlexxIT/XiaomiGateway3
步骤:
在ha的config目录下新建xiaomi_gateway3.py
导入以下代码:
from custom_components.xiaomi_gateway3.core.devices import *
DEVICES = [{
    9877: ["Loock", "Loock Smart Lock V5 Max", "FCL201"],
    "spec": [
        BaseConv("action", "sensor"),
        BaseConv("key_id", mi="2.e.1020.p.4"),
        MapConv("method", "sensor", mi="2.e.1020.p.2", map={
            1: "mobile", 2: "fingerprint", 3: "password", 4: "nfc", 5: "face", 6: "Finger Vein",
            7: "Palm Print", 8: "key", 9: "one_time_password", 10: "periodic_password",
            11: "Homekit", 12: "coerce", 13: "Two Step Verification", 14: "Turntable",
            15: "manual", 16: "auto"
        MapConv("lock_action", "sensor", mi="2.e.1020.p.3", map={
            1: "lock", 2: "unlock", 3: "lock_outside", 4: "lock_inside",
            5: "unlock_inside", 6: "enable_child_lock", 7: "disable_child_lock",
            8: "enable_away", 9: "disable_away"
        MapConv("door_state", "sensor", mi="3.p.1021", map={
            16: 'Locked',
            20: 'Locked',
            24: 'Locked',
            28: 'Locked',
            32: 'Unlocked',
            36: 'Unlocked',
            40: 'Unlocked',
            44: 'Unlocked',
            48: 'Leaving The Door Open Timed Out',
            52: 'Leaving The Door Open Timed Out',
            56: 'Leaving The Door Open Timed Out',
            60: 'Leaving The Door Open Timed Out',
            64: 'Door Was Ajar',
            68: 'Door Was Ajar',
            72: 'Door Was Ajar',
            76: 'Door Was Ajar'
        MapConv("abnormal_type", "sensor", mi="2.e.1020.p.6", map={
            1: "Frequent Unlocking Failed By Multiple Methods",
            2: "Frequent Unlocking Failed By Password",
            3: "Frequent Unlocking Failed By Fingerprint",
            4: "Frequent Unlocking Failed By NFC",
            5: "Frequent Unlocking Failed By Face",
            6: "Frequent Unlocking Failed By Palmprint",
            7: "Frequent Unlocking Failed By Finger Vein",
            8: "Frequent Unlocking Failed By Key",
            9: "Door Lock Was Damaged",
            10: "Locked Unsuccessfully",
            11: "Unlock From Inside After Leaving Home",
            12: "Door Lock Was Reset",
            13: "Foreign Object Detected In The Keyhole",
            14: "Key Was Not Removed",
            15: "Door Lock Fingerprint Sensor Error",
            16: "Door Lock Mechanical Failure",
            17: "Door Lock Main Part Failure",
            18: "The Lithium Battery Temperature Is Too High",
            19: "Large Batteries Are Low",
            20: "Small Batteries Are Low",
            21: "Large And Small Batteries Are Low",
            22: "Large And Small Deplete",
            23: "Leaving The Door Open Timed Out",
            24: "Door Was Ajar",
            25: "Door Was Opened Forcefully",
            26: "Small Batteries Are Nearly Depleted",
            27: "Small Batteries Are Nearly Depleted And Large Batteries Low",
            28: "Large Batteries Are Nearly Depleted",
            29: "Large Batteries Are Nearly Depleted And Small Batteries Low",
            30: "Large Batteries Are Removed",
            31: "Large Batteries Are Inserted",
            32: "Small Batteries Are Removed",
            33: "Small Batteries Are Inserted",
            34: "Battery Low The Cat Eye Function And The Door Screen Are Suspended",
            35: "Ultrasonic Sensitivity Decreased"
        MapConv("position", "sensor", mi="2.e.1020.p.1", map={
            1: "indoor", 2: "outdoor", 3: "not tell indoor or outdoor"
        BaseConv("lock_timestamp", "sensor", mi="2.e.1020.p.5"),  # lock timestamp
        # doorbell
        ConstConv("action", mi="5.e.1006", value="doorbell"),
        BaseConv("doorbell_timestamp", "sensor", mi="5.e.1006.p.1"),  # doorbell timestamp
        # battery sensor
        BaseConv("battery", "sensor", mi="4.p.1003"),
        BaseConv("changing", "sensor", mi="4.p.1034"),
}] + DEVICES
保存后重启ha就可以了。
在集成里添加好xiaomigateway3,增加网关后会自动识别连接到该网关蓝牙的v5max
效果图
类似方法可以尝试自己写代码来支持其他蓝牙锁
方法:
1. 在这里https://home.miot-spec.com/,找到你米家支持的设备
2. 我在网上搜到的设备号9877, 这个具体怎么获得目前不太清楚。
3. 后面是根据miot-spec内的内容修改spec, 同一家厂商的话内容基本上是差不多的。
4. 后面就是不断试错了。
发表于 2024-5-27 20:38:07 | 显示全部楼层
PIC20240527203559001.png 这个不是本身就支持吗?
miot
发表于 2024-5-27 20:53:05 | 显示全部楼层
前两天刚问,太好了,非诚感谢!
发表于 2024-5-27 20:54:40 | 显示全部楼层
zro22 发表于 2024-5-27 20:38
这个不是本身就支持吗?
miot
miot走的不是本地,响应不太及时
 楼主| 发表于 2024-5-27 21:11:16 | 显示全部楼层
这个不是本身就支持吗?
miot
miot上的不及时且不太准确。对于需要依赖ha来做联动的来说非常不方便。本地蓝牙目前我还没有完整测试,部分情况下也存在延迟情况,暂不清楚原因。action sensor目前也只识别出doorbell,还有很多需要做。
发表于 2024-5-28 20:42:28 | 显示全部楼层
学习了,谢谢分享。赞
发表于 2024-5-30 23:37:33 | 显示全部楼层
这款锁有两块电池,如何再XMGW3中实现识别两个电池呢?
发表于 2024-7-7 08:56:56 | 显示全部楼层
它的监控能接入到ha吗
发表于 2024-9-15 15:52:48 | 显示全部楼层
你好请问这个action里面会有信息么
发表于 2024-9-15 20:22:23 | 显示全部楼层
我的鹿客X3-H,要修改哪些东西呢?
之前有个帖子也说接入鹿客,但问了没人回答
在小程序里显示型号YD-D3NF
GMT+8, 2025-9-18 04:20 , Processed in 1.010596 second(s), 13 queries , MemCached On.
