楼主: JGhost
[基础教程] esphome网页在线烧录固件
发表于 2024-5-26 08:29:10 | 显示全部楼层
首次還是需要連接 USB to TTL 的
发表于 2024-5-26 08:52:21 | 显示全部楼层
我靠,我一直用这个的啊。
发表于 2024-7-15 22:51:29 | 显示全部楼层
jjcs 发表于 2024-5-25 19:05
对的。所以有些教程非蠢既坏
RAM:   [====      ]  43.2% (used 35360 bytes from 81920 bytes)
Flash: [=====     ]  51.5% (used 537473 bytes from 1044464 bytes)
========================= [SUCCESS] Took 5.05 seconds =========================
INFO Successfully compiled program.
esptool.py v4.7.0
Serial port COM3
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: f4:cf:a2:76:d1:60
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Flash will be erased from 0x00000000 to 0x00084fff...
Compressed 541632 bytes to 375954...
Writing at 0x00000000... (4 %)Writing at 0x00005f51... (8 %)Writing at 0x0000dd31... (13 %)Writing at 0x000142ab... (17 %)Writing at 0x0001a35d... (21 %)Writing at 0x00020649... (26 %)Writing at 0x000264bd... (30 %)Writing at 0x0002c47b... (34 %)Writing at 0x000323f5... (39 %)Writing at 0x00039445... (43 %)Writing at 0x0003e9d9... (47 %)Writing at 0x000442fd... (52 %)Writing at 0x00049af1... (56 %)Writing at 0x0004eb67... (60 %)Writing at 0x00053be3... (65 %)Writing at 0x00058d7e... (69 %)Writing at 0x0005e6de... (73 %)Writing at 0x00063dc5... (78 %)Writing at 0x00069225... (82 %)Writing at 0x0006e613... (86 %)Writing at 0x00073cb2... (91 %)Writing at 0x000784a2... (95 %)Writing at 0x0007eabe... (100 %)Wrote 541632 bytes (375954 compressed) at 0x00000000 in 8.9 seconds (effective 487.4 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
INFO Successfully uploaded program.
INFO Starting log output from COM3 with baud rate 115200
哥们 我第一次烧录用网站上的usb连接,我到这一步就卡住了,一直不往下走是为啥啊
jjcs 手机认证
57
发表于 2024-7-15 22:55:51 | 显示全部楼层
Flash: [=====     ]  51.5% (used 53 ...
按住boot烧录,固件生成web版本固件
发表于 2024-7-24 09:56:28 | 显示全部楼层
好滴 谢谢谢啦,解决了
GMT+8, 2025-9-15 03:32 , Processed in 0.625470 second(s), 12 queries , MemCached On.
