查看: 5381|回复: 13
[经验分享] LD2410 ESPHome 原生支持方法 (升级2024.5.0后可换官方方法)
发表于 2024-5-21 00:44:41 | 显示全部楼层 |阅读模式
官方原址说明
https://esphome.io/components/sensor/ld2410.html
我用的是D1 mini
board根据自己实际情况修改
uart:
  rx_pin: D7
  tx_pin: D8
这里的rx和tx需要修改
以及
  - platform: gpio
    pin: D6
这里的pin
esphome:
esp8266:
  board: d1_mini
  restore_from_flash: true
# Enable logging
logger:
  level: ERROR
  baud_rate: 0 #disable logging over uart
# Enable Home Assistant API
api:
ota:
wifi:
  ssid: !secret wifi_ssid
captive_portal:
uart:
  rx_pin: D7
  tx_pin: D8
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
ld2410:
  uart_id: ld2410_uart
  throttle: 1500ms
  - platform: ld2410
    moving_distance:
    still_distance:
    moving_energy:
    still_energy:
    detection_distance:
    g0:
      move_energy:
        name: g0 move energy
      still_energy:
        name: g0 still energy
    g1:
      move_energy:
        name: g1 move energy
      still_energy:
        name: g1 still energy
    g2:
      move_energy:
        name: g2 move energy
      still_energy:
        name: g2 still energy
    g3:
      move_energy:
        name: g3 move energy
      still_energy:
        name: g3 still energy
    g4:
      move_energy:
        name: g4 move energy
      still_energy:
        name: g4 still energy
    g5:
      move_energy:
        name: g5 move energy
      still_energy:
        name: g5 still energy
    g6:
      move_energy:
        name: g6 move energy
      still_energy:
        name: g6 still energy
    g7:
      move_energy:
        name: g7 move energy
      still_energy:
        name: g7 still energy
    g8:
      move_energy:
        name: g8 move energy
      still_energy:
        name: g8 still energy
binary_sensor:
  - platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
    out_pin_presence_status:
      name: out pin presence status
  - platform: gpio
    pin: D6
    device_class: motion
    filters:
      delayed_off: 1s
switch:
  - platform: ld2410
    engineering_mode:
number:
  - platform: ld2410
    timeout:
    max_move_distance_gate:
      name: max move distance gate
    max_still_distance_gate:
      name: max still distance gate
    g0:
      move_threshold:
        name: g0 move threshold
      still_threshold:
        name: g0 still threshold
    g1:
      move_threshold:
        name: g1 move threshold
      still_threshold:
        name: g1 still threshold
    g2:
      move_threshold:
        name: g2 move threshold
      still_threshold:
        name: g2 still threshold
    g3:
      move_threshold:
        name: g3 move threshold
      still_threshold:
        name: g3 still threshold
    g4:
      move_threshold:
        name: g4 move threshold
      still_threshold:
        name: g4 still threshold
    g5:
      move_threshold:
        name: g5 move threshold
      still_threshold:
        name: g5 still threshold
    g6:
      move_threshold:
        name: g6 move threshold
      still_threshold:
        name: g6 still threshold
    g7:
      move_threshold:
        name: g7 move threshold
      still_threshold:
        name: g7 still threshold
    g8:
      move_threshold:
        name: g8 move threshold
      still_threshold:
        name: g8 still threshold
button:
  - platform: ld2410
    factory_reset:
    restart:
    query_params:
text_sensor:
  - platform: ld2410
    version:
    mac_address:
select:
  - platform: ld2410
    distance_resolution:
      name: "distance resolution"
    baud_rate:
    light_function:
    out_pin_level:
      name: out pin level
发表于 2024-5-21 07:23:10 | 显示全部楼层
我的d1mini一直都不能用 tx_pin: GPIO01
  rx_pin: GPIO03  我都是用0-2,从2024年初的版本都不能用,10几个d1mini,我感觉这个一直都是通病
yjl 手机认证
发表于 2024-5-21 09:55:04 | 显示全部楼层
好文,收藏备用
总为浮云能避日,长安不见使人愁
发表于 2024-5-21 12:33:29 | 显示全部楼层
这个不是很久以前都支持吗?都用了好久了哦
发表于 2024-5-21 12:35:40 | 显示全部楼层
为什么不能用  tx_pin: GPIO1  rx_pin: GPIO3
发表于 2024-5-21 14:05:44 | 显示全部楼层
针脚是有定义的啊
我不生产技术,我只是技术的搬运工。
发表于 2024-5-21 14:08:15 | 显示全部楼层
zxyny1989 发表于 2024-5-21 14:05
针脚是有定义的啊
这个芯片对应的tx和rx就是这个,为什么不能用呢,其他的esp设备,也是这样设置的。我搞不懂,为什么用D7D8
发表于 2024-5-21 14:17:27 | 显示全部楼层
楼主火星了
 楼主| 发表于 2024-5-21 18:08:02 | 显示全部楼层
请问你是水星还是木星
 楼主| 发表于 2024-5-21 22:49:18 | 显示全部楼层
bugensui 发表于 2024-5-21 14:08
这个芯片对应的tx和rx就是这个,为什么不能用呢,其他的esp设备,也是这样设置的。我搞不懂,为什么用D7D ...
可能是因为
GPIO0:如果被拉低,则启动失败
GMT+8, 2025-9-18 04:19 , Processed in 0.716499 second(s), 11 queries , MemCached On.
