楼主: FrankLv
[进阶教程] homeassistant中添加小米净化器与小米插座(js代码方法)
发表于 2017-9-6 16:08:45 | 显示全部楼层
谢谢分享~~~
nemo
发表于 2017-9-6 21:55:32 | 显示全部楼层
yeelight 和网关一起接要怎么弄啊
发表于 2017-9-7 22:48:26 | 显示全部楼层
小白问个白痴问题 CMD平台是什么意思?@FrankLv
发表于 2017-9-8 21:35:30 | 显示全部楼层
用hass.io系统的怎么添加啊。。。?
发表于 2017-9-18 15:37:56 | 显示全部楼层
请问下,为什么安装miio总是会报错呢
npm WARN prepublish-on-install As of npm@5, `prepublish` scripts will run only for `npm publish`.
npm WARN prepublish-on-install (In npm@4 and previous versions, it also runs for `npm install`.)
npm WARN prepublish-on-install See the deprecation note in `npm help scripts` for more information.
npm WARN lifecycle [email protected]~prepublish: cannot run in wd %s %s (wd=%s) [email protected] eslint . /home/pi/miio
/usr/bin/miio -> /usr/lib/node_modules/miio/cli/index.js
/usr/lib
└── [email protected]
发表于 2017-10-3 15:27:20 | 显示全部楼层
xiexie你的分享
发表于 2017-10-7 18:53:14 | 显示全部楼层
为什么我命令行手动启动hass可以正常使用,使用systemctl命令启动就会显示错误,无法读取参数也无法控制净化器
2017-10-07 18:43:20 ERROR (Thread-9) [homeassistant.components.sensor.command_line] Command failed: node /home/pi/airpurifier.js 192.168.31.159 status-hum
2017-10-07 18:43:21 ERROR (Thread-2) [homeassistant.components.sensor.command_line] Command failed: node /home/pi/airpurifier.js 192.168.31.159 status-aqi
2017-10-07 18:43:22 ERROR (Thread-3) [homeassistant.components.sensor.command_line] Command failed: node /home/pi/airpurifier.js 192.168.31.159 status-mode
2017-10-07 18:43:22 ERROR (Thread-11) [homeassistant.components.sensor.command_line] Command failed: node /home/pi/airpurifier.js 192.168.31.159 status-led
2017-10-07 18:44:21 ERROR (Thread-10) [homeassistant.components.sensor.command_line] Command failed: node /home/pi/airpurifier.js 192.168.31.159 status-power
2017-10-07 18:44:21 ERROR (Thread-6) [homeassistant.components.sensor.command_line] Command failed: node /home/pi/airpurifier.js 192.168.31.159 status-temp
发表于 2017-10-24 21:07:04 | 显示全部楼层
必须大力支持啊!
发表于 2017-12-25 13:43:24 | 显示全部楼层
同问,在hass.io系统下,如何安装小米wi-fi版插座?还有aqara窗帘电机。。望大神指教。谢谢!
发表于 2017-12-30 13:14:31 | 显示全部楼层
这个教程太给力了,感谢!
GMT+8, 2025-9-5 10:51 , Processed in 1.227038 second(s), 11 queries , MemCached On.
