查看: 6483|回复: 13
[基础教程] 普通音箱接入homeassistant,播放本地nas音乐教程
发表于 2024-5-1 09:02:30 | 显示全部楼层 |阅读模式
将普通音响通过D1mini接入homeassistant,并播放nas中的音乐,并通过自制的无线开关控制(任意可以接入ha的开关都可以)
实现效果如下:
主要有一下几个步骤:
1.将D1mini刷入音响固件,并正确接线,配置好音响信息。这个可以参考Mrdiy大神的步骤,照着来不难。具体操作看:https://www.instructables.com/MQ ... -Play-MP3-TTS-RTTL/,这个
2.将nas中的音乐挂载到Alist,之前写了一个帖子可以参考。比如我的音乐存放在:“/volume1/music/经常听/”,挂在到alist为:“nas music/经常听”,不会配置的看下图:
3.在nr中将我的流导入:
        "id": "65eae738d91f64a3",
        "type": "inject",
        "z": "fdf7dc26597ae619",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 350,
        "y": 400,
        "wires": [
                "3c8c7825f90a5f3b"
        "id": "93c7b2b927b14214",
        "type": "http request",
        "name": "",
        "method": "POST",
        "ret": "obj",
        "paytoqs": "ignore",
        "url": "http://192.168.1.222:5244/api/fs/list",
        "tls": "",
        "persist": false,
        "proxy": "",
        "insecureHTTPParser": false,
        "authType": "",
        "senderr": false,
        "headers": [
                "keyType": "other",
                "keyValue": "Authorization",
                "valueType": "other",
                "valueValue": "XXXXXX"
        "x": 680,
        "y": 400,
        "wires": [
                "833c3b5c444f548b",
                "fe52ae74185a932e"
        "id": "3c8c7825f90a5f3b",
        "type": "function",
        "name": "function 50",
        "func": "msg.payload = {"path":"/nas music/经常听","password":"","page":1,"per_page":0,"refresh":false}\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 510,
        "y": 400,
        "wires": [
                "93c7b2b927b14214"
        "id": "833c3b5c444f548b",
        "type": "function",
        "name": "function 51",
        "func": "var zongshu = msg.payload.data.total;\nvar randomNumber = Math.floor(Math.random() * zongshu);\nvar song_name = msg.payload.data.content[randomNumber-1].name;\n\nmsg.zongshu=zongshu;\nmsg.random = randomNumber;\nmsg.name=song_name;\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 870,
        "y": 400,
        "wires": [
                "a4f751bd5147ca60"
        "id": "a4f751bd5147ca60",
        "type": "switch",
        "name": "",
        "property": "name",
        "propertyType": "msg",
        "rules": [
                "t": "cont",
                "v": "mp3",
                "vt": "str"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 1010,
        "y": 400,
        "wires": [
                "992a2b4398a5dc2f"
                "df258a16334b7523"
        "id": "32c83ecc50e35841",
        "type": "mqtt in",
        "name": "",
        "topic": "/mrdiynotifier/status",
        "qos": "2",
        "datatype": "auto-detect",
        "broker": "15e9ca6a44eb2b20",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 390,
        "y": 280,
        "wires": [
                "a502c264232b0900"
        "id": "0c920a6280c04f49",
        "type": "mqtt out",
        "name": "",
        "topic": "/mrdiynotifier/play",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1430,
        "y": 380,
        "wires": []
        "id": "992a2b4398a5dc2f",
        "type": "function",
        "name": "function 52",
        "func": "\nvar name = encodeURI(msg.name);\nmsg.payload="http://192.168.1.222:5244/d/nas%20music/%E7%BB%8F%E5%B8%B8%E5%90%AC/"+name;\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1210,
        "y": 380,
        "wires": [
                "0c920a6280c04f49",
                "fc79be3ba922821c"
        "id": "df258a16334b7523",
        "type": "link out",
        "name": "不是MP3就重新请求",
        "mode": "link",
        "links": [
            "ea373363454b30cb"
        "x": 1105,
        "y": 460,
        "wires": []
        "id": "ea373363454b30cb",
        "type": "link in",
        "name": "link in 7",
        "links": [
            "df258a16334b7523",
            "5b1f3f7e12124dd3",
            "160e354de1a6bc9c",
            "c57947f6b27e0c0a"
        "x": 415,
        "y": 440,
        "wires": [
                "3c8c7825f90a5f3b"
        "id": "a502c264232b0900",
        "type": "ha-sensor",
        "name": "D1mini_player状态",
        "entityConfig": "bcd483331e52fdeb",
        "version": 0,
        "state": "payload",
        "stateType": "msg",
        "attributes": [],
        "inputOverride": "allow",
        "outputProperties": [],
        "x": 610,
        "y": 280,
        "wires": [
        "id": "1112acc17e85cf88",
        "type": "ha-wait-until",
        "name": "",
        "server": "459a05598e74e156",
        "version": 2,
        "outputs": 1,
        "entityId": "sensor.d1mini_player",
        "entityIdFilterType": "exact",
        "property": "state",
        "comparator": "is",
        "value": "idle",
        "valueType": "str",
        "timeout": "",
        "timeoutType": "num",
        "timeoutUnits": "seconds",
        "checkCurrentState": true,
        "blockInputOverrides": true,
        "entityLocation": "data",
        "entityLocationType": "none",
        "x": 860,
        "y": 520,
        "wires": [
                "156cb526d4306d4a"
        "id": "5b1f3f7e12124dd3",
        "type": "link out",
        "mode": "link",
        "links": [
            "ea373363454b30cb"
        "x": 1405,
        "y": 480,
        "wires": []
        "id": "964294f2f1016a0c",
        "type": "comment",
        "name": "D1mini-player",
        "info": "",
        "x": 390,
        "y": 160,
        "wires": []
        "id": "9eb7ed31cedb42af",
        "type": "comment",
        "name": "播放",
        "info": "",
        "x": 330,
        "y": 340,
        "wires": []
        "id": "468436a9f17f97d7",
        "type": "delay",
        "name": "",
        "pauseType": "delay",
        "timeout": "30",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 700,
        "y": 520,
        "wires": [
                "1112acc17e85cf88"
        "id": "1c2f09261045f962",
        "type": "ha-switch",
        "name": "D1mini-player开关",
        "version": 0,
        "debugenabled": false,
        "inputs": 0,
        "outputs": 2,
        "entityConfig": "1ca8bde6237bf8a6",
        "enableInput": false,
        "outputOnStateChange": false,
                "property": "outputType",
                "value": "state change",
                "valueType": "str"
                "property": "payload",
                "value": "",
                "valueType": "entityState"
        "x": 390,
        "y": 220,
        "wires": [
        "id": "156cb526d4306d4a",
        "type": "api-current-state",
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "on",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "entity_id": "switch.d1mini_playerkai_guan",
        "state_type": "str",
        "blockInputOverrides": false,
                "value": "",
                "property": "data",
                "value": "",
                "valueType": "entity"
        "for": "0",
        "forType": "num",
        "forUnits": "minutes",
        "override_topic": false,
        "state_location": "payload",
        "override_payload": "msg",
        "entity_location": "data",
        "override_data": "msg",
        "x": 1150,
        "y": 520,
        "wires": [
                "5b1f3f7e12124dd3"
        "id": "baf139d33a7fb182",
        "type": "server-state-changed",
        "name": "",
        "version": 4,
        "exposeToHomeAssistant": false,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "sensor.d1mini_player",
        "entityidfiltertype": "exact",
        "outputinitially": false,
        "haltifstate": "playing",
        "outputs": 2,
        "output_only_on_state_change": true,
        "for": "10",
        "forType": "num",
        "forUnits": "seconds",
        "ignorePrevStateNull": false,
        "ignorePrevStateUnknown": false,
        "ignorePrevStateUnavailable": false,
        "ignoreCurrentStateUnknown": false,
        "ignoreCurrentStateUnavailable": false,
                "value": "",
                "property": "data",
                "value": "",
                "valueType": "eventData"
                "property": "topic",
                "value": "",
                "valueType": "triggerId"
        "x": 410,
        "y": 520,
        "wires": [
                "468436a9f17f97d7"
        "id": "3a4b092b606f2879",
        "type": "mqtt in",
        "name": "A无线开关",
        "topic": "espnow/topic",
        "qos": "0",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 340,
        "y": 720,
        "wires": [
                "4bf283517a0bb126",
                "ec844c5f740874c5"
        "id": "4bf283517a0bb126",
        "type": "switch",
        "name": "",
        "rules": [
                "t": "eq",
                "v": "A-1",
                "vt": "str"
                "t": "eq",
                "v": "A-2",
                "vt": "str"
                "t": "eq",
                "v": "A-3",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 3,
        "x": 550,
        "y": 720,
        "wires": [
                "160e354de1a6bc9c",
                "1af9a25873b49f54"
                "c57947f6b27e0c0a"
                "f2f7a29ae1c871b0",
                "9d6834fe15e5930e"
        "id": "160e354de1a6bc9c",
        "type": "link out",
        "mode": "link",
        "links": [
            "ea373363454b30cb"
        "x": 675,
        "y": 640,
        "wires": []
        "id": "1af9a25873b49f54",
        "type": "api-call-service",
        "name": "",
        "version": 5,
        "domain": "switch",
        "service": "turn_on",
        "areaId": [],
        "deviceId": [],
        "entityId": [
        "data": "",
        "dataType": "jsonata",
        "mergeContext": "",
        "mustacheAltTags": false,
        "queue": "none",
        "x": 860,
        "y": 640,
        "wires": [
        "id": "f2f7a29ae1c871b0",
        "name": "",
        "version": 5,
        "domain": "switch",
        "service": "turn_off",
        "areaId": [],
        "deviceId": [],
        "entityId": [
        "data": "",
        "mergeContext": "",
        "queue": "none",
        "x": 760,
        "y": 780,
        "wires": [
        "id": "9d6834fe15e5930e",
        "type": "mqtt out",
        "name": "",
        "topic": "/mrdiynotifier/stop",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 790,
        "y": 860,
        "wires": []
        "id": "c57947f6b27e0c0a",
        "type": "link out",
        "mode": "link",
        "links": [
            "ea373363454b30cb"
        "x": 735,
        "y": 720,
        "wires": []
        "id": "a3d4adb9cd02d6af",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "A-1",
        "payloadType": "str",
        "x": 370,
        "y": 660,
        "wires": [
                "4bf283517a0bb126"
        "id": "d27904daf87e9494",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "A-2",
        "x": 390,
        "y": 800,
        "wires": [
                "4bf283517a0bb126"
        "id": "5bdfa5a3ae721c1d",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "A-3",
        "x": 390,
        "y": 860,
        "wires": [
                "4bf283517a0bb126"
        "id": "ec844c5f740874c5",
        "type": "debug",
        "name": "debug 368",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 530,
        "y": 640,
        "wires": []
        "id": "fe52ae74185a932e",
        "type": "debug",
        "name": "debug 369",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "x": 930,
        "y": 300,
        "wires": []
        "id": "fc79be3ba922821c",
        "type": "debug",
        "name": "debug 370",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 1350,
        "y": 300,
        "wires": []
        "id": "15e9ca6a44eb2b20",
        "type": "mqtt-broker",
        "name": "",
        "broker": "192.168.1.100",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "autoUnsubscribe": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthRetain": "false",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closeRetain": "false",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willRetain": "false",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "id": "bcd483331e52fdeb",
        "type": "ha-entity-config",
        "deviceConfig": "",
        "name": "",
        "version": "6",
        "entityType": "sensor",
        "haConfig": [
                "property": "name",
                "value": "D1mini_player"
                "property": "icon",
                "value": ""
                "property": "entity_category",
                "value": ""
                "property": "entity_picture",
                "value": ""
                "property": "device_class",
                "value": ""
                "property": "unit_of_measurement",
                "value": ""
                "property": "state_class",
                "value": ""
        "resend": false,
        "debugEnabled": false
        "id": "459a05598e74e156",
        "type": "server",
        "name": "Home Assistant",
        "version": 5,
        "addon": false,
        "connectionDelay": true,
        "cacheJson": true,
        "heartbeat": false,
        "heartbeatInterval": "30",
        "areaSelector": "friendlyName",
        "deviceSelector": "friendlyName",
        "entitySelector": "friendlyName",
        "statusSeparator": ": ",
        "statusYear": "hidden",
        "statusMonth": "short",
        "statusDay": "numeric",
        "statusHourCycle": "default",
        "statusTimeFormat": "h:m",
        "enableGlobalContextStore": false
        "id": "1ca8bde6237bf8a6",
        "deviceConfig": "",
        "name": "",
        "version": "6",
        "entityType": "switch",
        "haConfig": [
                "property": "name",
                "value": "D1mini-player开关"
                "property": "icon",
                "value": ""
                "value": ""
                "value": ""
                "value": ""
        "resend": false,
修改http request节点和其前边的function节点,改为你自己的数据。保存部署就行了
参与人数 1金钱 +10 收起 理由
kaka0992 + 10 感谢楼主分享!
发表于 2024-5-1 12:11:57 | 显示全部楼层
很厉害呀。有一个问题,这种方式连接音箱的话,是否会有电流杂音?
mitu 手机认证
发表于 2024-5-1 12:28:53 | 显示全部楼层
它的TTS支持中文吗?
 楼主| 发表于 2024-5-1 12:44:16 | 显示全部楼层
mitu 发表于 2024-5-1 12:28
它的TTS支持中文吗?
不支持。。。。?
发表于 2024-5-1 18:02:18 | 显示全部楼层
电路很简单,就不知道这个音质好不,如果不行就做语音提醒
发表于 2024-5-2 20:43:23 | 显示全部楼层
流复制出错
 楼主| 发表于 2024-5-3 12:55:56 | 显示全部楼层
有杂音。。。。
发表于 2024-5-3 14:24:29 | 显示全部楼层
嗯,感谢。杂音问题确实不太好解决
发表于 2024-5-5 09:23:19 | 显示全部楼层
它的TTS支持中文吗?
借助中文tts可以实现中文tts,我这边已经实现
发表于 2024-5-5 09:25:37 | 显示全部楼层
杂音问题上功放板就能解决
GMT+8, 2025-9-18 02:50 , Processed in 1.199536 second(s), 13 queries , MemCached On.
