楼主: hood2000
[经验分享] PVE+ vGPU Tesla P4 + Frigate 的简单尝试
 楼主| 发表于 2024-4-13 20:45:16 | 显示全部楼层
crazychen 发表于 2024-4-13 07:24
请问您ubuntu用的是哪个版本呀,还是没找到问题出在哪里
ubuntu 22.04
我觉得不应该是系统版本的问题,试试 chmod 777 config.yml  ,看看是否读写权限的问题。
或者把config.yml这行注释掉试试。
另外,每次是否重新删除container重新创建?
发表于 2024-4-13 23:30:20 | 显示全部楼层
厉害了,学习,谢谢分享,mark
发表于 2024-4-14 06:27:53 | 显示全部楼层
hood2000 发表于 2024-4-13 20:45
ubuntu 22.04
或 ...
我把ront目录下的frigate移动到home下重新拉的,哪个错误没了,但又有新的
ensive_goodall
crazychen@ubuntu2:/home/frigate$ sudo docker logs 5a887d19d108
s6-rc: info: service s6rc-fdholder: starting
s6-rc: info: service s6rc-fdholder successfully started
s6-rc: info: service trt-model-prepare: starting
s6-rc: info: service log-prepare: starting
s6-rc: info: service log-prepare successfully started
s6-rc: info: service nginx-log: starting
Generating the following TRT Models: yolov7-tiny-288
s6-rc: info: service go2rtc-log: starting
Downloading yolo weights
s6-rc: info: service frigate-log: starting
s6-rc: info: service nginx-log successfully started
s6-rc: info: service go2rtc-log successfully started
s6-rc: info: service go2rtc: starting
s6-rc: info: service frigate-log successfully started
s6-rc: info: service go2rtc successfully started
s6-rc: info: service go2rtc-healthcheck: starting
2024-04-13 22:25:25.489638044  [INFO] Preparing new go2rtc config...
s6-rc: info: service go2rtc-healthcheck successfully started
s6-rc: warning: unable to start service trt-model-prepare: command exited 4
2024-04-13 22:25:25.738726543  [INFO] Starting go2rtc...
2024-04-13 22:25:25.820817678  22:25:25.820 INF go2rtc version 1.8.4 linux/amd64
2024-04-13 22:25:25.821397255  22:25:25.821 INF [api] listen addr=:1984
2024-04-13 22:25:25.821613666  22:25:25.821 INF [rtsp] listen addr=:8554
2024-04-13 22:25:25.821820680  22:25:25.821 INF [webrtc] listen addr=:8555
2024-04-13 22:25:35.494943638  [INFO] Starting go2rtc healthcheck service...
发表于 2024-4-14 08:50:56 | 显示全部楼层
最后一顿胡倒腾,总算打开后台页面了,但ffmpeg 出错
2024-04-14 00:46:30.404408461  Traceback (most recent call last):
2024-04-14 00:46:30.404411187    File "/usr/lib/python3.9/multiprocessing/process.py", line 315, in _bootstrap
2024-04-14 00:46:30.404415765      self.run()
2024-04-14 00:46:30.404418310    File "/usr/lib/python3.9/multiprocessing/process.py", line 108, in run
2024-04-14 00:46:30.404420073      self._target(*self._args, **self._kwargs)
2024-04-14 00:46:30.404421658    File "/opt/frigate/frigate/object_detection.py", line 102, in run_detector
2024-04-14 00:46:30.404456532      object_detector = LocalObjectDetector(detector_config=detector_config)
2024-04-14 00:46:30.404458432    File "/opt/frigate/frigate/object_detection.py", line 53, in __init__
2024-04-14 00:46:30.404459811      self.detect_api = create_detector(detector_config)
2024-04-14 00:46:30.404461218    File "/opt/frigate/frigate/detectors/__init__.py", line 18, in create_detector
2024-04-14 00:46:30.404492962      return api(detector_config)
2024-04-14 00:46:30.404494525    File "/opt/frigate/frigate/detectors/plugins/tensorrt.py", line 220, in __init__
2024-04-14 00:46:30.404496058      self.engine = self._load_engine(detector_config.model.path)
2024-04-14 00:46:30.404497547    File "/opt/frigate/frigate/detectors/plugins/tensorrt.py", line 88, in _load_engine
2024-04-14 00:46:30.404507829      with open(model_path, "rb") as f, trt.Runtime(self.trt_logger) as runtime:
2024-04-14 00:46:30.404527297  FileNotFoundError: [Errno 2] No such file or directory: '/home/frigate/model_cache/tensorrt/8.5.3/yolov5nu.trt'
2024-04-14 00:46:30.404528824  Exception ignored in: <function TensorRtDetector.__del__ at 0x7fc3637b3d30>
2024-04-14 00:46:30.404530065  Traceback (most recent call last):
2024-04-14 00:46:30.404531544    File "/opt/frigate/frigate/detectors/plugins/tensorrt.py", line 239, in __del__
2024-04-14 00:46:30.404656008      if self.outputs is not None:
2024-04-14 00:46:30.404709969  AttributeError: 'TensorRtDetector' object has no attribute 'outputs'
2024-04-14 00:46:31.384495370  [2024-04-14 00:46:31] audio.South                    ERROR   : ffmpeg process is not running,
 楼主| 发表于 2024-4-14 17:48:39 | 显示全部楼层
是模型文件的问题。在docker compose过程中有问题,就是下面这个提示:
你可以你重新compose试一下,shm_size 设置大一点,1024MB试一下。另外,看一下我主贴第5部分的图片,生成模型文件有个过程,如果logs中没有,就是没有成功。
发表于 2024-4-15 16:25:30 | 显示全部楼层
但是p4买不到,咳咳。我用tpu还行
发表于 2024-4-18 07:37:13 | 显示全部楼层
s6-rc: warning: unable to start  ...
我尝试更改更大尺寸还是不行,模型文件无法生成,模型文件可以手动下载吗?
还有就是提示版本低不知道有影响吗?root@ubuntu2:/home/frigate# docker compose up -d
WARN[0000] /home/frigate/docker-compose.yml: `version` is obsolete
 楼主| 发表于 2024-4-18 08:29:07 | 显示全部楼层
还有就是提示版本低不知道有 ...
yml版本只是提醒,没啥影响。
模型文件应该可以下载,另外,如果有fq环境,试一下,很多脚本尤其是涉及到在github上拉文件都可能受影响。,
发表于 2024-4-18 12:15:36 | 显示全部楼层
hood2000 发表于 2024-4-18 08:29
yml版本只是提醒,没啥影响。
模型文件应该可以下载,另外,如果有fq环境,试一下,很多脚本尤其是涉及 ...
试了,切换到科学环境下,仍没反应,郁闷至极
 楼主| 发表于 2024-4-18 12:26:54 | 显示全部楼层
没有道理啊,我试了重新compose,也能正常下载模型文件。
GMT+8, 2025-9-17 03:24 , Processed in 1.048562 second(s), 7 queries , MemCached On.
