查看: 2272|回复: 3
[人体存在] 大佬们,求一份ld2410的固件
发表于 2024-3-28 00:17:25 | 显示全部楼层 |阅读模式
有没有老哥做这个帖子的人体存在了 帖子地址:esp32C3人体存在传感器工程分享 - 『HomeAssistant』综合讨论区 - 『瀚思彼岸』» 智能家居技术论坛 - Powered by Discuz! (hassbian.com)
板子已经焊好了,不会弄固件,能否分享下yaml,万分感谢!!
HomeAssistant
发表于 2024-3-28 08:22:14 | 显示全部楼层
https://esphome.io/  根据传感器名字搜就有例程,一个一个慢慢调就行
版主
发表于 2024-3-28 10:23:25 | 显示全部楼层
substitutions:
  device_name: "esp32-ld2410b"
esphome:
  # Automatically add the mac address to the name
  # so you can use a single firmware for all devices
  name_add_mac_suffix: True
esp32:
  board: nodemcu-32s
  # board: esp32dev
  framework:
    type: arduino
wifi:
  ap: {}
api:
ota:
# Enable logging
logger:
  # baud_rate: 0
web_server:
captive_portal:
i2c:
  sda: GPIO21
  scl: GPIO22
  scan: true
uart:
  tx_pin: GPIO17
  rx_pin: GPIO16
  baud_rate: 256000 # Change this according to your setting
  parity: NONE
  stop_bits: 1
ld2410:
  uart_id: uart_bus
switch:
  - platform: ld2410
    bluetooth:
button:
  - platform: ld2410
    restart:
      name: "${device_name} Ld2410 Reboot"
binary_sensor:
  - platform: gpio
    pin: GPIO33
    device_class: motion
  # - platform: ld2410
  #   has_target:
  #     name: "${device_name} Presence"
  #   has_moving_target:
  #     name: "${device_name} Moving Target"
  #   has_still_target:
  #     name: "${device_name} Still Target"
  # - platform: gpio
  #   pin: GPIO32
  #   name: "${device_name} IR"
  #   device_class: motion
  # - platform: status
  #   name: "${device_name} Online"
  - platform: bh1750
    name: "${device_name} Illuminance"
    address: 0x23
    update_interval: 15s
  #   moving_distance:
  #     name : "${device_name} Moving Distance"
  #   still_distance:
  #     name: "${device_name} Still Distance"
  #   moving_energy:
  #     name: "${device_name} Move Energy"
  #   still_energy:
  #     name: "${device_name} Still Energy"
  #   detection_distance:
  #     name: "${device_name} Detection Distance"
  # - platform: internal_temperature
  #   name: "${device_name} Internal Temperature"
发表于 2024-3-28 11:23:25 | 显示全部楼层
这个ld2410有什么后缀吗
GMT+8, 2025-9-17 03:13 , Processed in 0.532118 second(s), 14 queries , MemCached On.
