查看: 2487|回复: 5
[硬件DIY] 卫生间多功能模块,集成浴霸,热水器,照明,电能计量.....
发表于 2024-3-8 12:23:43 | 显示全部楼层 |阅读模式
本着少用8266的数量的原则个人做了热水器、热水温度,浴霸灯、卫生间照明灯、微波人体传感器、光纤传感器以及电能计量集成控制,目前工作稳定
esphome:
  comment: 厕所灯、浴霸、热水器
  platform: ESP8266
  board: esp01_1m
ota:
  password: ""
wifi:
  networks:
  - ssid:
    password:
  ap:
    ssid: "toliet"
    password: ""
captive_portal:
api:
#logger:
web_server:
  port: 80
time:
  - platform: sntp
    timezone: "Asia/Shanghai"
    servers: "ntp1.aliyun.com"
    on_time:
      - seconds: 0
        minutes: 00
        hours: 23
        then:
         - light.control:
              brightness: 50%
      - seconds: 0
        minutes: 20
        hours: 6
        then:
         - light.control:
              brightness: 100%
uart:
  - id: uart_bus
    tx_pin: 1
    rx_pin: 3
    baud_rate: 256000
    parity: NONE
    stop_bits: 1
  - id: uart_bus1
    tx_pin: 2
    rx_pin: 12
    baud_rate: 4800
    stop_bits: 1
i2c:
  sda: 4
  scl: 5
  scan: true
pcf8574:
  - id: 'pcf8574_hub'
    address: 0x20
    pcf8575: true
dallas:
  - pin: GPIO13
    update_interval: 60s
  - platform: dallas
    address: 0x61220ad445eef528
    name: "Toliet-water heater temperature"
  - platform: bl0942
    uart_id: uart_bus1
    voltage:
    current:
    power:
    energy:
      accuracy_decimals: 2
    frequency:
      name: "Toliet Frequency"
  - platform: total_daily_energy
    name: 'Toliet Total Daily Energy'
    power_id: power
    restore: true
    unit_of_measurement: 'kWh'
    state_class: total_increasing
    device_class: energy
    accuracy_decimals: 3
    filters:
# Multiplication factor from W to kW is 0.001
       - multiply: 0.001
  - platform: adc
    pin: A0
    name: "Toliet Brightness"
    update_interval: 1s
    filters:
      - multiply: 3.3
    on_value_range:
      - below: 2.2
        then:
          - binary_sensor.template.publish:
              state: ON
      - above: 2.2
        then:
              state: OFF
ld2410:
  - uart_id: uart_bus
light:
  - platform: monochromatic
    icon: "mdi:wall-sconce-round"
    output: pwm_output
    restore_mode: RESTORE_DEFAULT_OFF
  - platform: binary
    icon: "mdi:lightbulb"
    output: light_output1
  - platform: binary
    icon: "mdi:lightbulb-group"
    output: light_output2
output:
  - platform: esp8266_pwm
    pin: GPIO15
    frequency: 5000Hz
  - platform: gpio
    pin:
      pcf8574: pcf8574_hub
      # Use pin number 0
      number: 6
      # One of INPUT or OUTPUT
      mode:
        output: true
      inverted: false
  - platform: gpio
    pin:
      # Use pin number 0
      number: 5
      mode:
        output: true
      inverted: false
binary_sensor:
  - platform: ld2410
    has_moving_target:
      name: "Toliet Moving Target"
    has_still_target:
      name: Toliet Still Target
      filters:
        - delayed_on: 10ms
        - delayed_off: 10s
      on_press:
         - if:
            condition:
              and:
                - binary_sensor.is_off: fxp
                - binary_sensor.is_off: blight
            then:
              - light.turn_on: lamp
      on_release:
         - if:
            condition:
              and:
            then:
              - light.turn_off: lamp
  - platform: gpio
    pin:
      # Use pin number 0
      number: 2
      mode:
        input: true
      inverted: false
    filters:
        - delayed_on: 10ms
    on_press:
        - switch.toggle: template_swi
  - platform: gpio
    pin:
      # Use pin number 0
      number: 3
      mode:
        input: true
      inverted: false
    filters:
        - delayed_on: 10ms
    on_press:
        - light.toggle: lamp1
  - platform: gpio
    pin:
      # Use pin number 0
      number: 4
      mode:
        input: true
      inverted: false
    filters:
        - delayed_on: 10ms
    on_press:
        - light.toggle: lamp2
  - platform: template
    lambda: |-
      if (id(template_swi).state == true) {
        return true;
      } else {
        return false;
    name: "light binary_sensor"
    device_class: light
climate:
  - platform: thermostat
    name: "Toliet Water Heater Controller"
    sensor: temperature
    min_heating_off_time: 120s
    min_heating_run_time: 120s
    min_idle_time: 30s
    heat_deadband: 5
    heat_overrun: 5
    visual:
      min_temperature: 25
      max_temperature: 65
      temperature_step: 1°C
    heat_action:
      - switch.turn_on: rs_output
    idle_action:
      - switch.turn_off: rs_output
    default_preset: Home
    on_boot_restore_from: memory
    preset:
      - name: Home
        default_target_temperature_low: 45°C
switch:
    turn_on_action:
      - switch.template.publish:
          state: ON
    turn_off_action:
          state: OFF
  - platform: gpio
   # name: "Toliet HOT"
    pin:
      # Use pin number 0
      number: 7
      mode:
        output: true
      inverted: false
  - platform: gpio
    pin: 14
    restore_mode: ALWAYS_ON
button:
  - platform: restart
嘉立创制版文件
Gerber_PCB1_2024-03-018.zip (339.29 KB, 下载次数: 1, 售价: 2 金钱)
参与人数 2金钱 +21 收起 理由
sorrypqa + 16 感谢楼主分享!
yc0209 + 5 高手,这是高手!
发表于 2024-3-8 14:34:01 | 显示全部楼层
Ari 手机认证
发表于 2024-3-8 14:56:07 | 显示全部楼层
热水器温度和设置温度怎么弄
flim 手机认证
发表于 2024-3-8 15:03:41 | 显示全部楼层
只能顶礼膜拜
发表于 2024-3-8 15:07:21 | 显示全部楼层
感谢分享  ,打板制作
发表于 2024-3-9 07:52:15 | 显示全部楼层
不错,学习学习,谢谢分享!
GMT+8, 2025-9-19 06:38 , Processed in 1.075572 second(s), 13 queries , MemCached On.
