查看: 3137|回复: 7
[硬件DIY] 电动升降晒衣架控制板PCB
发表于 2024-3-8 11:20:25 | 显示全部楼层 |阅读模式
如题,纯属个人业余玩玩,不做专业对比,有需要的可自行打印
附件:嘉立创制版文件
Gerber_电动晾衣架模块_2024-03-08.zip (234.4 KB, 下载次数: 9, 售价: 2 金钱)
esphome程序
esphome:
  friendly_name: "clothes-hanger"
  comment: 阳台晒衣杆、阳台灯
  platformio_options:
    board_build.flash_mode: dio
    board_build.mcu: esp32c3
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: esp-idf
    version: recommended
    # Custom sdkconfig options
    sdkconfig_options:
      CONFIG_COMPILER_OPTIMIZATION_SIZE: y
    # Advanced tweaking options
    advanced:
      ignore_efuse_mac_crc: false
logger:
  hardware_uart: USB_SERIAL_JTAG
# Enable logging
api:
ota:
  password: "2fe5275a4f967590a20bb6179fb0ce14"
captive_portal:
wifi:
  networks:
     - ssid:
       password:
     - ssid:
       password:
  ap:
    ssid: " - "
    password: " "
  - platform: adc
    pin: 0
    update_interval: 2s
    filters:
      - multiply: 10
    on_value_range:
      - above: 1.5
        then:
          - cover.stop: hanger
          - rtttl.play: 'long:d=1,o=5,b=100:e6'
  - platform: wifi_signal
    name: "clothes-hanger WiFi Signal"
    update_interval: 60s
binary_sensor:
#上升限位
  - platform: gpio
    icon: mdi:arrow-collapse-up
    pin:
      number: GPIO2
      mode:
        input: true
        pullup: true
#      inverted: true
    filters:
      - delayed_on: 20ms
    on_press:
      then:
        - rtttl.play: 'scale_up:d=32,o=7,b=100:c,c#,d#,e,f#,g#,a#,b'
        - switch.turn_off: relay
#下降限位
  - platform: gpio
    icon: mdi:arrow-collapse-down
    pin:
      number: GPIO3
      mode:
        input: true
        pullup: true
#      inverted: true
    filters:
      - delayed_on: 20ms
    on_press:
      then:
        - rtttl.play: 'scale_up:d=32,o=7,b=100:b,a#,g#,f#,e,d#,c#,c'
        - switch.turn_off: relay1
#衣物检测限位
  - platform: gpio
    pin:
      number: GPIO5
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - delayed_on: 20ms
  #  on_press:
  #      - switch.turn_off: relay
  #      - switch.turn_off: relay1
  #      - switch.turn_on: relay2
  #      - delay: 200ms
  #      - delay: 200ms
#上升按钮
  - platform: gpio
    pin:
      number: GPIO21
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - delayed_on: 50ms
    on_press:
      - cover.open: hanger
#      - rtttl.play: 'scale_up:d=32,o=7,b=100:c,c#,d#'
#下降按钮
  - platform: gpio
    pin:
      number: GPIO1
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - delayed_on: 50ms
    on_press:
      - cover.close: hanger
 #     - rtttl.play: 'scale_up:d=32,o=7,b=100:b,a#'
#暂停按钮
  - platform: gpio
    pin:
      number: GPIO20
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - delayed_on: 50ms
    on_press:
 #     - rtttl.play: 'two_short:d=4,o=5,b=100:16e6,16e6'
#灯按钮
  - platform: gpio
    pin:
      number: GPIO8
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - delayed_on: 50ms
    on_press:
      - light.toggle: lamp
switch:
# 上升继电器控制
  - platform: gpio
    pin: GPIO7
#    name: "Up D15"
    restore_mode: RESTORE_DEFAULT_OFF
    interlock: &interlock_group [relay, relay1]
    interlock_wait_time: 200ms
#  下降继电器控制
  - platform: gpio
    pin: GPIO10
#    name: "Down D4"
    interlock: *interlock_group
cover:
  - platform: endstop
    open_action:
    open_duration: 12s
    open_endstop: sxw
    close_action:
      - switch.turn_on: relay1
    close_duration: 13s
    close_endstop: jxw
    stop_action:
      - rtttl.play: two_short:d=4,o=5,b=100:16e6,16e6
light:
  - platform: binary
    output: light_output
output:
  - id: light_output
    platform: gpio
#    inverted: False
    pin: GPIO6
  - platform: ledc
    pin: GPIO4
rtttl:
  output: rtttl_out
text_sensor:
  - platform: template
    update_interval: 1s
    icon: mdi:hanger
    lambda: |-
      if (id(relay1).state == true){
        return {"晒衣杆正在下降中..."};
      } else if (id(relay).state == true){
        return {"晒衣杆正在升起..."};
      } else if (id(jxw).state == true ){
        return {"晒衣杆已降下"};
      } else if (id(sxw).state == true ){
        return {"晒衣杆已升起"};
      } else if (id(alarm1).state > 1 ){
        return {"告警,晒衣杆超负荷!"};
      } else {
        return {"待机中"};
参与人数 3金钱 +22 收起 理由
simonliu009 + 2 感谢楼主分享!
book123 + 10 论坛有你更精彩!
隔壁的王叔叔 + 10 论坛有你更精彩!
发表于 2024-3-8 13:47:49 | 显示全部楼层
支持大佬。
flim 手机认证
发表于 2024-3-8 15:02:17 | 显示全部楼层
膜拜大佬啊
发表于 2024-3-8 15:09:03 | 显示全部楼层
打板制作
发表于 2024-6-17 18:06:47 | 显示全部楼层
请问超载检测的adc是测的啥?
发表于 2024-12-10 23:21:30 来自手机 | 显示全部楼层
大佬,bom表方便提供下吗
发表于 2024-12-11 08:15:00 | 显示全部楼层
wpw72 发表于 2024-6-17 18:06
请问超载检测的adc是测的啥?
看图,应该是检测R13的压降,电机的驱动电流越大,R13两端的电压也越大
发表于 2024-12-11 09:26:31 | 显示全部楼层
GMT+8, 2025-9-17 03:30 , Processed in 0.662506 second(s), 16 queries , MemCached On.
