查看: 5994|回复: 10
[进阶教程] [智能家居]: 普通风扇改装智能控制
发表于 2024-3-1 17:54:23 | 显示全部楼层 |阅读模式
[智能家居]: 普通风扇改装智能控制
使用目的:改装家里的老式风扇,接入home-assistant平台,使其支持语音与无人时自动关闭,也可以根据环境温度自动调节风量档位。
1. 使用环境
home-assistant
node-red
esphome
2. 准备材料
esp32 板子
4路继电器
调速电容1只
电阻1只(1~10K都可以)
3. 硬件接线
忘记拍图了,借网友的图用 下,电阻是串在手动调速按钮上的,作下拉电阻。如果电机是2线的话改接调速电容之后就好。
3. esp32刷入程序
esp32代码,以下x 自己j更改
#                    基本信息                      #
esphome:
  friendly_name: esp32-erlouketing-fan
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
  password: "xxxxxxxxxxxxxxxxxxxxxxx"
#                    网络信息                      #
wifi:
  ssid: !secret wifi_ssid
#   manual_ip:
#    static_ip: 192.168.2.55
#    gateway: 192.168.2.1
#    subnet: 255.255.255.0
#    dns1: 223.5.5.5
#    dns2: 223.6.6.6
#   # Enable fallback hotspot (captive portal) in case wifi connection fails
  ap:
    ssid: "xxxxxxxxxxxxxxxxx"
    password: "xxxxxxxxxxxxxxxx"
captive_portal:
#                    时间信息                      #
time:
  - platform: sntp
    timezone: Asia/Shanghai
    servers:
      - ntp1.aliyun.com
      - ntp2.aliyun.com
      - ntp3.aliyun.com
#                    MQTT信息                      #
# mqtt:
#  broker: 192.168.2.14
#  username: !secret mqtt_username
#  password: !secret mqtt_password
#                    风扇控制                      #
#####################  按键  #######################
binary_sensor:
  - platform: status
  - platform: gpio
    pin: {number: GPIO3, mode: INPUT_PULLUP, inverted: True}
    filters: [{delayed_on: 40ms}, {delayed_off: 40ms}]
    on_press:
      then: [{switch.turn_on: light}]
    on_release:
      then: [{switch.turn_off: light}]
  - platform: gpio
    pin: {number: GPIO21, mode: INPUT_PULLUP, inverted: True}
    # on_state: [{switch.toggle: low}]
#####################  开关  #######################
switch:
  - platform: restart
  - platform: gpio
    pin: 16
    # pin: GPIO16
    inverted: yes
  - platform: gpio
    pin: 17
    inverted: yes
    interlock:  [mid, hig]
  - platform: gpio
    pin: 18
    inverted: yes
    interlock:  [low, hig]
  - platform: gpio
    pin: 19
    inverted: yes
    interlock:  [low, mid]
output:
  - platform: template
    type: float
    write_action:
      - if:
          condition:
            lambda: return ((state == 0));
          then:
            # action for off
            - switch.turn_off: low
            - switch.turn_off: mid
            - switch.turn_off: hig
      - if:
          condition:
            lambda: return ((state > 0) && (state < 0.4));
          then:
            # action for speed 1
            - switch.turn_on: low
      - if:
          condition:
            lambda: return ((state > 0.4) && (state < 0.7));
          then:
            # action for speed 2
            - switch.turn_on: mid
      - if:
          condition:
            lambda: return ((state > 0.7));
          then:
            # action for speed 3
            - switch.turn_on: hig
fan:
  - platform: speed
    output: custom_fan
    speed_count: 3
#                      传感器                      #
####################  无线信号  #####################
  - platform: wifi_signal
    update_interval: 60s
####################  运行时间  #####################
  - platform: uptime
4. home-assistant 设置
5. node-red 设置
node-red 代码:
        "id": "6836b7fd08578f56",
        "type": "group",
        "z": "f6f2187d.f17ca8",
        "style": {
            "stroke": "#999999",
            "stroke-opacity": "1",
            "fill": "none",
            "fill-opacity": "1",
            "label": true,
            "label-position": "nw",
            "color": "#a4a4a4"
        "nodes": [
            "8b9ff480520b4f2f",
            "e910097dd7e68731",
            "ed08ea25ada86837",
            "b0702dd4384454ad",
            "4b8f8e642a80d506",
            "a1035eb9cb61e7c3",
            "941f7a1fe79447f1",
            "5cf03e6da4744350",
            "2cc857c4b5c1cbe9",
            "1b81787d2234125a",
            "e67af704c3d4f5b1",
            "3b6736e2623d6d08",
            "2f90baa596394ae9",
            "4de5d220150f1c29",
            "527fbe89e935a9c2",
            "9a5f24df6bcfd9d6",
            "f5a2869b96fc0710",
            "e1a1e6bb9fef52e0"
        "x": 14,
        "y": 19,
        "w": 1432,
        "h": 282
        "id": "8b9ff480520b4f2f",
        "type": "api-call-service",
        "g": "6836b7fd08578f56",
        "name": "风扇低速",
        "server": "99c664b867ad2e30",
        "version": 5,
        "debugenabled": false,
        "domain": "switch",
        "service": "turn_on",
        "areaId": [],
        "deviceId": [],
        "entityId": [
            "switch.esp32_erlouketing_fan_low"
        "data": "",
        "dataType": "jsonata",
        "mergeContext": "",
        "mustacheAltTags": false,
        "outputProperties": [],
        "queue": "none",
        "x": 1280,
        "y": 100,
        "wires": [
                "f5a2869b96fc0710"
        "id": "e910097dd7e68731",
        "name": "风扇中速",
        "version": 5,
        "domain": "switch",
        "areaId": [],
        "deviceId": [],
        "entityId": [
            "switch.esp32_erlouketing_fan_medium"
        "data": "",
        "mergeContext": "",
        "queue": "none",
        "x": 1280,
        "y": 140,
        "wires": [
                "f5a2869b96fc0710"
        "id": "ed08ea25ada86837",
        "name": "风扇高速",
        "version": 5,
        "domain": "switch",
        "areaId": [],
        "deviceId": [],
        "entityId": [
            "switch.esp32_erlouketing_fan_high"
        "data": "",
        "mergeContext": "",
        "queue": "none",
        "x": 1280,
        "y": 180,
        "wires": [
                "f5a2869b96fc0710"
        "id": "b0702dd4384454ad",
        "type": "function",
        "name": "次数加一",
        "func": "var count = flow.get('count-01')||0;\nif (count > 0) {\n    count = count+1;\n    flow.set('count-01', count);\n}\n\nmsg.payload = count;\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 880,
        "y": 180,
        "wires": [
                "4b8f8e642a80d506"
        "id": "4b8f8e642a80d506",
        "type": "switch",
        "name": "次数判断",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "2",
                "vt": "str"
                "t": "eq",
                "v": "3",
                "vt": "str"
                "t": "eq",
                "v": "4",
                "vt": "str"
                "t": "eq",
                "v": "5",
                "vt": "str"
                "t": "gt",
                "v": "5",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 5,
        "x": 1060,
        "y": 180,
        "wires": [
                "8b9ff480520b4f2f"
                "e910097dd7e68731"
                "ed08ea25ada86837"
                "5cf03e6da4744350"
                "a1035eb9cb61e7c3"
        "id": "a1035eb9cb61e7c3",
        "type": "link out",
        "name": "二楼客厅风扇-01",
        "mode": "link",
        "links": [
            "2f90baa596394ae9"
        "x": 1235,
        "y": 260,
        "wires": []
        "id": "941f7a1fe79447f1",
        "type": "function",
        "name": "设定基数",
        "func": "flow.set('count-01', 1);\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 680,
        "y": 260,
        "wires": [
                "b0702dd4384454ad"
        "id": "5cf03e6da4744350",
        "name": "风扇关闭",
        "version": 5,
        "domain": "fan",
        "service": "turn_off",
        "areaId": [],
        "deviceId": [],
        "entityId": [
            "fan.esp32_erlouketing_fan"
        "data": "",
        "mergeContext": "",
        "queue": "none",
        "x": 1280,
        "y": 220,
        "wires": [
        "id": "2cc857c4b5c1cbe9",
        "type": "server-state-changed",
        "d": true,
        "name": "风扇灯按键",
        "version": 5,
        "outputs": 2,
        "exposeAsEntityConfig": "",
        "entityId": "binary_sensor.esp32_erlouketing_fan_light",
        "entityIdType": "exact",
        "outputInitially": false,
        "stateType": "str",
        "ifState": "on",
        "ifStateType": "str",
        "ifStateOperator": "is",
        "outputOnlyOnStateChange": true,
        "for": "0",
        "forType": "num",
        "forUnits": "minutes",
        "ignorePrevStateNull": false,
        "ignorePrevStateUnknown": false,
        "ignorePrevStateUnavailable": false,
        "ignoreCurrentStateUnknown": false,
        "ignoreCurrentStateUnavailable": false,
                "value": "",
                "valueType": "entityState"
                "property": "data",
                "value": "",
                "valueType": "eventData"
                "property": "topic",
                "value": "",
                "valueType": "triggerId"
        "x": 180,
        "y": 260,
        "wires": [
                "1b81787d2234125a"
        "id": "1b81787d2234125a",
        "name": "风扇灯光",
        "version": 5,
        "domain": "switch",
        "service": "toggle",
        "areaId": [],
        "deviceId": [],
        "entityId": [
            "switch.esp32_erlouketing_fan_light"
        "data": "",
        "mergeContext": "",
        "queue": "none",
        "x": 380,
        "y": 260,
        "wires": [
        "id": "e67af704c3d4f5b1",
        "name": "风扇按键",
        "version": 5,
        "outputs": 2,
        "entityId": "binary_sensor.esp32_erlouketing_fan_button",
        "stateType": "str",
        "ifState": "on",
        "for": "0",
        "forType": "num",
                "value": "",
                "property": "data",
                "value": "",
                "value": "",
        "x": 680,
        "y": 100,
        "wires": [
                "b0702dd4384454ad"
        "id": "3b6736e2623d6d08",
        "type": "comment",
        "name": "二楼客厅风扇",
        "info": "",
        "x": 110,
        "y": 60,
        "wires": []
        "id": "2f90baa596394ae9",
        "type": "link in",
        "links": [
            "a1035eb9cb61e7c3"
        "x": 545,
        "y": 260,
        "wires": [
                "941f7a1fe79447f1"
        "id": "4de5d220150f1c29",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 500,
        "y": 180,
        "wires": [
                "527fbe89e935a9c2"
        "id": "527fbe89e935a9c2",
        "type": "function",
        "name": "设定基数",
        "func": "flow.set('count-01', 4);\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 680,
        "y": 180,
        "wires": [
                "b0702dd4384454ad"
        "id": "9a5f24df6bcfd9d6",
        "type": "api-current-state",
        "name": "客厅雷达",
        "version": 3,
        "outputs": 2,
        "halt_if": "无人",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "entity_id": "sensor.erlouketing_motion_radar",
        "state_type": "str",
        "blockInputOverrides": false,
                "value": "",
                "property": "data",
                "value": "",
                "valueType": "entity"
        "for": "5",
        "forType": "num",
        "override_topic": false,
        "state_location": "payload",
        "override_payload": "msg",
        "entity_location": "data",
        "override_data": "msg",
        "x": 1060,
        "y": 260,
        "wires": [
                "5cf03e6da4744350"
        "id": "f5a2869b96fc0710",
        "type": "link out",
        "name": "二楼客厅风扇-02",
        "mode": "link",
        "links": [
            "e1a1e6bb9fef52e0"
        "x": 1405,
        "y": 140,
        "wires": []
        "id": "e1a1e6bb9fef52e0",
        "type": "link in",
        "links": [
            "f5a2869b96fc0710"
        "x": 925,
        "y": 260,
        "wires": [
                "9a5f24df6bcfd9d6"
        "id": "99c664b867ad2e30",
        "type": "server",
        "name": "omv-homeassistant",
        "version": 5,
        "addon": false,
        "connectionDelay": true,
        "cacheJson": true,
        "heartbeat": false,
        "heartbeatInterval": "30",
        "areaSelector": "friendlyName",
        "deviceSelector": "friendlyName",
        "entitySelector": "friendlyName",
        "statusSeparator": "at: ",
        "statusYear": "hidden",
        "statusMonth": "short",
        "statusDay": "numeric",
        "statusHourCycle": "h23",
        "statusTimeFormat": "h:m",
        "enableGlobalContextStore": true
6. 完成效果
参与人数 2金钱 +21 收起 理由
lishidong0912 + 5 厉害了word楼主!
sorrypqa + 16 感谢楼主分享!
Awe7 手机认证
发表于 2024-3-1 18:08:58 | 显示全部楼层
大佬,两线的通过电容调速的吊扇改,用双向可控硅驱动,pwm频率多大为好??  我这边改完低速抖动一直启停
发表于 2024-3-1 18:53:30 | 显示全部楼层
Awe7 发表于 2024-3-1 18:08
大佬,两线的通过电容调速的吊扇改,用双向可控硅驱动,pwm频率多大为好??  我这边改完低速抖动一直启停: ...
用可控硅调速,只能按市电频率,没得选
发表于 2024-3-1 19:28:08 | 显示全部楼层
还是买直流变频风扇吧!按我的使用频率,最高档位38W VS 12W,用个10年8年,连买风扇的钱都能从电费中省回来
发表于 2024-3-1 20:44:11 | 显示全部楼层
终于等到,,,家里一个落地上红外遥控的控制板坏了,,,哈哈哈能搞
发表于 2024-3-5 15:16:55 | 显示全部楼层
双向可控硅移相调压,应该是100Hz。
不过实际上,由于可控硅是半控器件,不应该简单用PWM,而是应该根据过零点延时一定时间(相位),再触发可控硅开通。
如果不对PWM和市电的相位进行同步,理论上会出现一种情况:1%占空比的脉冲正好在过零点触发,导致设备满功率工作。与预期相悖
Awe7 手机认证
发表于 2024-3-5 22:46:16 | 显示全部楼层
二十四书生 发表于 2024-3-5 15:16
双向可控硅移相调压,应该是100Hz。
不过实际上,由于可控硅是半控器件,不应该简单用PWM,而是应该根据 ...
用的moc3063自带过零.100hz低速还是抖  加电容调速86盒放不下了
发表于 2024-3-6 10:06:20 | 显示全部楼层
这种带过零点检测的光耦,控制交流电的时候,最小单位是一个半波周期,即10ms
我说的移相调压,需要配个过零点检测电路和普通光耦,过零事件发生后,启动计时,延时比如 5ms,触发晶闸管导通(需要普通光耦)这样就是半功率了
过零光耦 当且仅当过零点事件发生时,有输入信号,才能触发导通,其他时间是不能触发的。
机器抖动说明电机功率不稳定可能是因为你的触发脉冲相位处于临界状态,偶尔才能触发光耦
话说100Hz的pwm,竟然能调速?
现在你修改pwm的周期和脉宽,比如周期500ms,占空比以10ms步进依次递增,再看调速性能怎么样
发表于 2024-3-6 12:36:34 | 显示全部楼层
改可控硅的驱动电阻.电阻1-10k测试吧.改了几把可控硅风扇了.电阻小了低速一直抖动.无法关停
发表于 2024-3-7 02:58:17 | 显示全部楼层
就喜欢大佬分享这种实用的,且详略的、具有实践性和可操作性的教程让我们这些门外汉也能享受折腾的乐趣,谢谢大佬
GMT+8, 2025-10-15 03:45 , Processed in 0.138620 second(s), 11 queries , MemCached On.
