查看: 7449|回复: 2
[信息发布] 博联S1C HB插件更新啦~~~
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-1-14 15:08:29 | 显示全部楼层 |阅读模式
从2.5.16更新到3.0.2   提高了稳定性和响应速度
解决了digital envelope routines:EVP_DecryptFinal 错误
但是依旧无法控制报警,每次报警都永久响,弄的我只好把报警关掉,只用来查看状态
https://www.npmjs.com/package/homebridge-broadlink-s1c
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-1-14 18:52:36 | 显示全部楼层
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] 10-homebridge: applying...
[fix-attrs.d] 10-homebridge: exited 0.
[fix-attrs.d] 20-dbus: applying...
[fix-attrs.d] 20-dbus: exited 0.
[fix-attrs.d] 30-avahi: applying...
[fix-attrs.d] 30-avahi: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Hass.io Add-on: Homebridge v2.3.0
 HomeKit support for your Home Assistant instance using Homebridge
 By: Franck Nijhof <[email][email protected][/email]>
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing...
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 03-version-requirements.sh: executing...
INFO: Supervisor version requirements checks passed.
[cont-init.d] 03-version-requirements.sh: exited 0.
[cont-init.d] 20-dbus.sh: executing...
[cont-init.d] 20-dbus.sh: exited 0.
[cont-init.d] 30-avahi.sh: executing...
[cont-init.d] 30-avahi.sh: exited 0.
[cont-init.d] 50-config.sh: executing...
[cont-init.d] 50-config.sh: exited 0.
[cont-init.d] 60-ipv6-hotfix.sh: executing...
[cont-init.d] 60-ipv6-hotfix.sh: exited 0.
[cont-init.d] 80-user-packages.sh: executing...
fetch [url]http://dl-cdn.alpinelinux.org/alpine/v3.7/main/armhf/APKINDEX.tar.gz[/url]
fetch [url]http://dl-cdn.alpinelinux.org/alpine/v3.7/community/armhf/APKINDEX.tar.gz[/url]
v3.7.0-92-g4ff2158d0c [[url]http://dl-cdn.alpinelinux.org/alpine/v3.7/main[/url]]
v3.7.0-94-g8335dc0967 [[url]http://dl-cdn.alpinelinux.org/alpine/v3.7/community[/url]]
OK: 8879 distinct packages available
(1/39) Installing sdl2 (2.0.7-r3)
(2/39) Installing libxau (1.0.8-r2)
(3/39) Installing libbsd (0.8.6-r1)
(4/39) Installing libxdmcp (1.1.2-r4)
(5/39) Installing libxcb (1.12-r1)
(6/39) Installing libx11 (1.6.5-r1)
(7/39) Installing alsa-lib (1.1.4.1-r2)
(8/39) Installing libbz2 (1.0.6-r6)
(9/39) Installing gmp (6.1.2-r1)
(10/39) Installing nettle (3.3-r0)
(11/39) Installing libffi (3.2.1-r4)
(12/39) Installing libtasn1 (4.12-r2)
(13/39) Installing p11-kit (0.23.2-r2)
(14/39) Installing libunistring (0.9.7-r0)
(15/39) Installing gnutls (3.6.1-r0)
(16/39) Installing lame (3.100-r0)
(17/39) Installing opus (1.2.1-r1)
(18/39) Installing librtmp (2.4_git20160909-r3)
(19/39) Installing libogg (1.3.3-r1)
(20/39) Installing libtheora (1.1.1-r13)
(21/39) Installing libjpeg-turbo (1.5.2-r0)
(22/39) Installing v4l-utils-libs (1.12.5-r1)
(23/39) Installing libxdamage (1.1.4-r1)
(24/39) Installing libxext (1.3.3-r2)
(25/39) Installing libxfixes (5.0.3-r1)
(26/39) Installing libxxf86vm (1.1.4-r1)
(27/39) Installing libdrm (2.4.88-r0)
(28/39) Installing mesa-glapi (17.2.4-r1)
(29/39) Installing libxshmfence (1.2-r2)
(30/39) Installing mesa-gl (17.2.4-r1)
(31/39) Installing libva (1.8.2-r0)
(32/39) Installing libvdpau (1.1.1-r1)
(33/39) Installing libvorbis (1.3.5-r3)
(34/39) Installing libvpx (1.6.1-r0)
(35/39) Installing x264-libs (20170930-r0)
(36/39) Installing x265 (2.5-r0)
(37/39) Installing xvidcore (1.3.4-r0)
(38/39) Installing ffmpeg-libs (3.4-r1)
(39/39) Installing ffmpeg (3.4-r1)
Executing busybox-1.27.2-r6.trigger
OK: 100 MiB in 90 packages
[cont-init.d] 80-user-packages.sh: exited 0.
[cont-init.d] 81-user-scripts.sh: executing...
[cont-init.d] 81-user-scripts.sh: exited 0.
[cont-init.d] 82-user-plugins.sh: executing...
npm WARN deprecated [email][email protected][/email]: Use mz or fs-extra^3.0 with Promise Support
发表于 2018-1-14 19:18:06 | 显示全部楼层
谢谢分享
GMT+8, 2025-8-13 03:40 , Processed in 0.090096 second(s), 8 queries , MemCached On.
