查看: 85569|回复: 104
[进阶教程] 分享博联RM插件在HK实现空调控制的教程
 火.. [复制链接]
发表于 2017-5-8 20:54:05 | 显示全部楼层 |阅读模式
1、运行Putty
sudo npm install -g homebridge
sudo npm install -g homebridge-broadlink-rm
备注:(环境 nodejs==7.9.0 npm==4.5.0)
2、在HB中 sudo nano config.json
备注:范本文件网址
https://github.com/lprhodes/home ... /config-sample.json
3、运行homebridge
4 添加好HB后,发现Learn按键, 点击按下Learn 键,此时RM PRO灯处于橙色状态,把要学习的红外/或者射频的遥控器按键按下让RM PRO学习
5、查看HEX码(HomeKit 16进制码)
查看日志运行:sudo journalctl --no-pager -u homebridge --since today
6、找到Hex码
7、编辑config.json 中,里面有之前的HA.HB,HB后面加入博联RM
8、关于添加格式
9、可以看到以下选项时说明已经搞定
10、愉快的享受夏天吧!
##########我是分界线################
    "bridge": {
        "name":"Homebridge",
        "username":"B8:27:EB:15:45:A5",
        "port": 51888,
        "pin": "123-88-678"
    "platforms": [
            "platform":"HomeAssistant",
            "name":"HomeAssistant",
            "host":"http://ip:8123",
            "password":"raspberry",
            "supported_types": [
                "garage_door",
                "binary_sensor",
                "cover",
                "fan",
                "input_boolean",
                "light",
                "rollershutter",
                "lock",
                "media_player",
                "scene",
                "sensor",
                "switch"
            "platform":"Camera-ffmpeg",
            "cameras": [
                    "name": "Cameraxiaofang",
                    "videoConfig": {
                        "source":"-rtsp_transport tcp -re -i rtsp://ip:554/unicast",
                        "maxStreams":2,
                        "maxWidth":1920,
                        "maxHeight":1080,
                        "maxFPS": 10
                "platform": "BroadlinkRM",
                "name": "Broadlink RM",
                "homebridgeDirectory":"/var/homebridge",
                 "accessories": [
                            "name":"air-conditioner",
                            "type":"air-conditioner",
                            "data": {
                               "off":"26004e00000128901611161017341736161017101710161116351710171017341710171016111611161017101710171116101734171017101611161116101710173417101735161017101735171017000d0500000000000000000000",
                               "temperature30": {
                                    "pseudo-mode":"heat",
                                   "data":"26004e00000128901611161116361610161116111611161116351710171016351710161116111611161017101710171017101635171017101611161116101710173417101734171017101735161116000d0500000000000000000000"
                               "temperature22": {
                                   "pseudo-mode": "cool",
                                   "data": "26004e00000128901734171017101735171017101611161116101636161017101710171017101710161116111611161116111535171017101710171016111611163516111635161116111635161116000d0500000000000000000000"
发表于 2017-5-8 21:00:06 | 显示全部楼层
星总威武!
发表于 2017-5-8 21:18:27 | 显示全部楼层
星总威武!
发表于 2017-5-8 21:34:17 | 显示全部楼层
星总威武!
发表于 2017-5-8 21:56:57 | 显示全部楼层
星總威武
发表于 2017-5-8 22:52:55 | 显示全部楼层
星总威武!
eric
卓越贡献
发表于 2017-5-8 23:00:43 | 显示全部楼层
星总威武!!
发表于 2017-5-8 23:30:03 | 显示全部楼层
星总威武霸气
wqqs 手机认证
活跃会员
发表于 2017-5-10 18:50:06 | 显示全部楼层
星总威武!!
发表于 2017-5-11 16:15:18 | 显示全部楼层
这个必须顶,不然哪天不能看了
GMT+8, 2025-9-7 04:55 , Processed in 0.653303 second(s), 6 queries , MemCached On.
