查看: 6217|回复: 17
[经验分享] 新版esphome 2023.12.3 编译DC1固件修改
发表于 2024-1-17 17:44:37 | 显示全部楼层 |阅读模式
最近想更新下我几个dc1的esphome固件, 发现新版esphome编译过不了,看了下新版变化太多,加上platformio的更新, 即使用旧的esphome1.14也不能正常编译了.
看了下esphome现在的components里有另一个类似io芯片的代码, pca9554, 比较了cat9554和pca9554的datasheet, 都一样, 所以对照esphome pca9554页面改下yaml就行了.
要改的就是把cat9554全部替换成pca9554, 然后把#irq_pin: GPIO4注释掉就能编译了.
默认情况下的wifi led不能控制了, 看了下esphome文档,用status_led platform代替status_led component就可以,附件就不修改了, 帖子里代码修改过了.
wifi led之前是要inverted,之前没注意.yaml已改.
用几天后,发现有时候会出现dc1半死机状态, 需要断电后才正常,大家慎用,当然在yaml里加上如下代码也是可以实现定时重启的.
time:
  - platform: homeassistant
    on_time:
      - seconds: 0
        minutes: 0
        hours: 2
        days_of_week: MON-SUN
        then:
           - switch.toggle: restart_switch
switch:
  - platform: restart
测试正常使用.完整的yaml如下.
esphome:
  platform: ESP8266
  board: esp01_1m
  esp8266_restore_from_flash: yes
  build_path: build/$device_name
substitutions:
  config_version: 'v2019.12.26.001'
  device_name: dc1-api
  wifi_fast_connect: 'false'
  wifi_reboot_timeout: 0s
  api_reboot_timeout: 0s
  cse7766_update_interval: 1s
wifi:
  ssid: !secret wifi_ssid
  domain: .local
  reboot_timeout: $wifi_reboot_timeout
  power_save_mode: none
  fast_connect: $wifi_fast_connect
  #use_address: ota.local
  ap:
    ssid: $device_name
    password: "1234567890"
captive_portal:
api:
  reboot_timeout: $api_reboot_timeout
ota:
  safe_mode: true
  password: !secret ota_password
#  port: 3286
web_server:
  port: 80
#  css_url: https://esphome.io/_static/webserver-v1.min.css
#  js_url: https://esphome.io/_static/webserver-v1.min.js
i2c:
  sda: GPIO3
  scl: GPIO12
  scan: false
  #frequency: 20kHz
pca9554:
  #address: 0x20
  #irq_pin: GPIO4
uart:
  rx_pin: GPIO13
  baud_rate: 4800
#debug:
logger:
  # NONE、ERROR、WARN、INFO、DEBUG、VERBOSE、VERY_VERBOSE
  level: INFO
  baud_rate: 0
#  hardware_uart: UART1
  - platform: cse7766
    voltage:
    current:
    power:
    update_interval: $cse7766_update_interval
  - platform: uptime
  - platform: wifi_signal
    name: "${device_name} wifi_signal"
binary_sensor:
  - platform: status
    internal: false
  - platform: gpio
    internal: true
    pin:
      pca9554: pca9554_hub
      # Use pin number 0
      number: 0
      mode: INPUT
    filters:
      - invert:
      - delayed_on: 50ms
      - delayed_off: 50ms
    on_click:
      - min_length: 50ms
        max_length: 500ms
        then:
          - switch.toggle: switch1
  - platform: gpio
    internal: true
    pin:
      # Use pin number 1
      number: 1
      mode: INPUT
    filters:
      - invert:
      - delayed_on: 50ms
      - delayed_off: 50ms
    on_click:
      - min_length: 50ms
        max_length: 500ms
        then:
          - switch.toggle: switch2
  - platform: gpio
    internal: true
    pin:
      # Use pin number 2
      number: 2
      mode: INPUT
    filters:
      - invert:
      - delayed_on: 50ms
      - delayed_off: 50ms
    on_click:
      - min_length: 50ms
        max_length: 500ms
        then:
          - switch.toggle: switch3
  - platform: gpio
    internal: true
    pin:
      number: GPIO16
      mode: INPUT_PULLDOWN_16
    filters:
      - invert:
      - delayed_on: 50ms
      - delayed_off: 50ms
    on_click:
      - min_length: 50ms
        max_length: 500ms
        then:
          - switch.toggle: switch0
  - platform: template
    internal: true
    internal: true
    internal: true
#status_led:
#  pin: GPIO0
## choose only one between light status_led platform and status_led component
light:
  - platform: status_led
    name: "${device_name} wifi_light"
    pin:
      number: GPIO0
      inverted: true
text_sensor:
    name: "${device_name} Config Version"
    lambda: |-
      return {"${config_version}"};
  - platform: version
    name: "${device_name} esphome_version"
    icon: mdi:information-outline
  - platform: wifi_info
    ip_address:
      name: "${device_name} IP Address"
    ssid:
      name: "${device_name} Connected SSID"
#    bssid:
#      name: "${device_name} Connected BSSID"
output:
  - platform: gpio
    setup_priority: 900
    pin:
      # Use pin number 4
      number: 4
      mode: OUTPUT
      inverted: false
  - platform: gpio
    setup_priority: 900
    pin:
      # Use pin number 5
      number: 5
      mode: OUTPUT
      inverted: false
  - platform: gpio
    setup_priority: 900
    pin:
      # Use pin number 6
      number: 6
      mode: OUTPUT
      inverted: false
  - platform: gpio
    setup_priority: 900
    pin:
      # Use pin number 7
      number: 7
      mode: OUTPUT
      inverted: false
switch:
  - platform: output
    output: realy0
    on_turn_on:
      - switch.turn_on: LOGO_light
      - lambda: |-
          if (id(shadow1).state) {
            id(switch1).turn_on();
            id(shadow1).publish_state(false);
          if (id(shadow2).state) {
            id(switch2).turn_on();
            id(shadow2).publish_state(false);
          if (id(shadow3).state) {
            id(switch3).turn_on();
            id(shadow3).publish_state(false);
    on_turn_off:
      - switch.turn_off: LOGO_light
      - lambda: |-
          if (id(switch1).state) {
            id(switch1).turn_off();
            id(shadow1).publish_state(true);
          if (id(switch2).state) {
            id(switch2).turn_off();
            id(shadow2).publish_state(true);
          if (id(switch3).state) {
            id(switch3).turn_off();
            id(shadow3).publish_state(true);
  - platform: output
    output: realy1
    on_turn_on:
      - lambda: |-
          if (!id(switch0).state) {
            id(switch0).turn_on();
  - platform: output
    output: realy2
    on_turn_on:
      - lambda: |-
  - platform: output
    output: realy3
    on_turn_on:
      - lambda: |-
  - platform: gpio
    pin: GPIO14
    name: "${device_name} LOGO_light"
    internal: false
    inverted: true
dc1_homeassistant_api_pca9554.zip
1.61 KB, 下载次数: 45
参与人数 7金钱 +83 收起 理由
testss + 8 我来瀚思就为看你!
wfnydx + 5 高手,这是高手!
sss190 + 10 感谢楼主分享!
kkkkllll08 + 8 论坛有你更精彩!
whxciotw + 16 膜拜大神!
dscao + 20 感谢楼主分享!
sorrypqa + 16 大神666!
Awe7 手机认证
发表于 2024-1-17 19:12:04 | 显示全部楼层
沙发0.0
发表于 2024-1-17 22:42:46 | 显示全部楼层
留个脚印。。。
发表于 2024-1-18 08:16:06 | 显示全部楼层
终于有人出手了
发表于 2024-1-18 15:13:44 | 显示全部楼层
收藏,这个刷完homeassitant里是不是可以自动发现使用了?
Freddy.
最佳新人卓越贡献
发表于 2024-1-18 15:20:14 | 显示全部楼层
之前的固件能在线刷不。。。。
发表于 2024-1-18 19:27:27 | 显示全部楼层
日志里有点错误,不过貌似控制正常,不管了
lse 手机认证
发表于 2024-1-18 23:00:17 | 显示全部楼层
不错,有空试试看
 楼主| 发表于 2024-1-18 23:05:19 | 显示全部楼层
南柯醉一梦丶 发表于 2024-1-18 15:20
之前的固件能在线刷不。。。。
应该可以,不过我之前2019编译的固件也备份了,不过当时是固定ip,刷别的dc1上麻烦点
 楼主| 发表于 2024-1-18 23:06:49 | 显示全部楼层
我的暂时只发现几个warning
22:50:10[W][cse7766:062]Invalid checksum from CSE7766: 0x1C != 0x12
22:50:18[W][cse7766:062]Invalid checksum from CSE7766: 0xA0 != 0x9B
22:50:23[W][cse7766:062]Invalid checksum from CSE7766: 0x95 != 0x4F
GMT+8, 2025-9-16 02:53 , Processed in 1.090259 second(s), 14 queries , MemCached On.
