楼主: 翻滚吧暖菌
[基础教程] Windows安装HomeAssistant菜鸟教程
发表于 2018-9-4 09:45:59 | 显示全部楼层
MARK一下
发表于 2018-9-7 11:32:42 | 显示全部楼层
请教个问题,安装完怎么设置开机启动呢,每次都得手动启动。。。
发表于 2018-9-8 21:25:29 | 显示全部楼层
楼主有在windows上配置homebridge么
发表于 2019-6-15 20:54:09 来自手机 | 显示全部楼层
谢谢分享!
发表于 2019-6-20 10:50:39 | 显示全部楼层
大佬 我输入hass --open-ui的时候不自动打开浏览器,然后输入路由器分配的192.168.31.82:8123时一直显示initializing,输入127.0.0.1:8123时可以打开hass
发表于 2019-7-17 00:49:09 | 显示全部楼层
问题来了,
第一个:是不能http://hassio:8123打开页面,只能IP:8123打开
第二个:这货不带hass.io啊,.都没找到怎么在win中安装
发表于 2020-3-29 15:49:37 | 显示全部楼层
hao 试试试试
发表于 2020-5-14 18:55:29 | 显示全部楼层
  File "d:\python\lib\site-packages\pip\_vendor\urllib3\response.py", line 425, in _error_catcher
    yield
  File "d:\python\lib\site-packages\pip\_vendor\urllib3\response.py", line 507, in read
    data = self._fp.read(amt) if not fp_closed else b""
  File "d:\python\lib\site-packages\pip\_vendor\cachecontrol\filewrapper.py", line 62, in read
    data = self.__fp.read(amt)
  File "d:\python\lib\http\client.py", line 449, in read
    n = self.readinto(b)
  File "d:\python\lib\http\client.py", line 493, in readinto
    n = self.fp.readinto(b)
  File "d:\python\lib\socket.py", line 586, in readinto
    return self._sock.recv_into(b)
  File "d:\python\lib\ssl.py", line 1009, in recv_into
    return self.read(nbytes, buffer)
  File "d:\python\lib\ssl.py", line 871, in read
    return self._sslobj.read(len, buffer)
  File "d:\python\lib\ssl.py", line 631, in read
    v = self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
  File "d:\python\lib\site-packages\pip\_internal\cli\base_command.py", line 188, in _main
    status = self.run(options, args)
  File "d:\python\lib\site-packages\pip\_internal\cli\req_command.py", line 185, in wrapper
    return func(self, options, args)
  File "d:\python\lib\site-packages\pip\_internal\commands\install.py", line 333, in run
    reqs, check_supported_wheels=not options.target_dir
  File "d:\python\lib\site-packages\pip\_internal\resolution\legacy\resolver.py", line 179, in resolve
    discovered_reqs.extend(self._resolve_one(requirement_set, req))
  File "d:\python\lib\site-packages\pip\_internal\resolution\legacy\resolver.py", line 362, in _resolve_one
    abstract_dist = self._get_abstract_dist_for(req_to_install)
  File "d:\python\lib\site-packages\pip\_internal\resolution\legacy\resolver.py", line 314, in _get_abstract_dist_for
    abstract_dist = self.preparer.prepare_linked_requirement(req)
  File "d:\python\lib\site-packages\pip\_internal\operations\prepare.py", line 412, in prepare_linked_requirement
    hashes=hashes,
  File "d:\python\lib\site-packages\pip\_internal\operations\prepare.py", line 198, in unpack_url
    hashes=hashes,
  File "d:\python\lib\site-packages\pip\_internal\operations\prepare.py", line 124, in get_http_url
    link, downloader, temp_dir.path, hashes
  File "d:\python\lib\site-packages\pip\_internal\operations\prepare.py", line 220, in _download_http_url
    for chunk in download.chunks:
  File "d:\python\lib\site-packages\pip\_internal\cli\progress_bars.py", line 166, in iter
    for x in it:
  File "d:\python\lib\site-packages\pip\_internal\network\utils.py", line 39, in response_chunks
    decode_content=False,
  File "d:\python\lib\site-packages\pip\_vendor\urllib3\response.py", line 564, in stream
    data = self.read(amt=amt, decode_content=decode_content)
  File "d:\python\lib\site-packages\pip\_vendor\urllib3\response.py", line 529, in read
    raise IncompleteRead(self._fp_bytes_read, self.length_remaining)
  File "d:\python\lib\contextlib.py", line 99, in __exit__
    self.gen.throw(type, value, traceback)
  File "d:\python\lib\site-packages\pip\_vendor\urllib3\response.py", line 430, in _error_catcher
    raise ReadTimeoutError(self._pool, None, "Read timed out.")
pip._vendor.urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='files.pythonhosted.org', port=443): Read timed out.
这个怎么办
发表于 2020-5-14 19:04:30 | 显示全部楼层
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProxyError('Cannot connect to proxy.', timeout('timed out',))': /packages/87/c9/f41fcf931501f07ef9ca12365fd09eb879f6755618f375b058a229d9c94b/homeassistant-0.103.6-py3-none-any.whl
这个该怎么解决
发表于 2020-7-16 10:13:42 | 显示全部楼层
友情提示。千万别瞎改中文用户名。我自己改成英文用户名了之后所有用户配置全变了,改回去都不管用,最后重装了系统。
GMT+8, 2025-9-19 02:55 , Processed in 1.294416 second(s), 16 queries , MemCached On.
