查看: 2522|回复: 2
[UI界面] layout-card 尺寸如何调整
发表于 2023-12-18 23:19:16 | 显示全部楼层 |阅读模式
我现在做完了一个净化器的弹出卡片,但是不管是是在手机侧还是电脑侧,显示效果都要重叠的部分,怎么可以调整下宽度和高度的比例让它完美显示呢?
代码如下:
type: vertical-stack
cards:
  - type: horizontal-stack
    cards:
      - type: picture
        image: /local/jinghuaqi.jpg
        theme: ios-dark-mode
        tap_action:
          action: none
        hold_action:
          action: none
      - type: custom:layout-card
        layout_type: custom:grid-layout
        cards:
          - type: custom:mushroom-entity-card
            entity: switch.zhimi_va1_276f_switch_status
            icon_color: purple
            primary_info: name
            secondary_info: state
            icon_type: entity-picture
            tap_action:
              action: toggle
            hold_action:
              action: none
            entity: fan.kong_qi_jing_hua_qi
            icon_color: green
            primary_info: name
            tap_action:
              action: toggle
            hold_action:
              action: none
            double_tap_action:
              action: none
        layout: {}
        cards:
            entity: switch.kong_qi_jing_hua_qi_child_lock
            icon: mdi:lock
            icon_color: orange
            primary_info: name
            hold_action:
              action: toggle
            double_tap_action:
              action: none
            tap_action:
              action: none
            entity: sensor.kong_qi_jing_hua_qi_motor_speed
            icon: mdi:speedometer
            icon_color: teal
            primary_info: name
            tap_action:
              action: more-info
            hold_action:
              action: none
            double_tap_action:
              action: none
    cards:
      - type: vertical-stack
        cards:
            layout: {}
            cards:
                entity: number.kong_qi_jing_hua_qi_fan_level
                icon_color: green
                primary_info: name
                tap_action:
                  action: call-service
                  service: fan.increase_speed
                  target:
                    entity_id: []
                    device_id:
                      - 1decf51fdbb7c6ae6177ecf65c09a2bb
                    area_id: []
                  data:
                    percentage_step: 30
                hold_action:
                  action: more-info
                double_tap_action:
                  action: none
                icon_color: light-green
                primary_info: name
                tap_action:
                  service: fan.decrease_speed
                  target:
                    area_id: []
                  data:
                    percentage_step: 30
                hold_action:
                  action: more-info
                double_tap_action:
                  action: none
                icon: mdi:speedometer-slow
        layout: {}
        cards:
            entity: sensor.zhimi_va1_276f_temperature
            icon_color: red
            primary_info: name
            background: green
            tap_action:
              action: more-info
            hold_action:
              action: none
            double_tap_action:
              action: none
            layout: {}
            cards:
                entity: sensor.zhimi_va1_276f_relative_humidity
                icon_color: teal
                primary_info: name
                tap_action:
                  action: more-info
                hold_action:
                  action: none
                double_tap_action:
                  action: none
        layout: {}
        cards:
            entity: sensor.zhimi_va1_276f_filter_used_time
            icon_color: purple
            primary_info: name
            tap_action:
              action: more-info
            hold_action:
              action: none
            double_tap_action:
              action: none
            layout:
              layout: {}
            cards:
                entity: sensor.kong_qi_jing_hua_qi_filter_lifetime_remaining
                icon_color: green
                primary_info: name
                tap_action:
                  action: more-info
                hold_action:
                  action: none
                double_tap_action:
                  action: none
        cards:
            cards:
                entity: light.zhimi_va1_276f_indicator_light
                primary_info: name
                tap_action:
                  action: toggle
                hold_action:
                  action: more-info
                double_tap_action:
                  action: none
                entity: sensor.kong_qi_jing_hua_qi_pm2_5
                icon: ''
                icon_color: pink
                primary_info: name
                tap_action:
                  action: more-info
                hold_action:
                  action: none
                double_tap_action:
                  action: none
            layout: {}
 楼主| 发表于 2023-12-18 23:22:14 | 显示全部楼层
实际效果见图
发表于 2023-12-19 22:59:07 来自手机 | 显示全部楼层
学习学习
GMT+8, 2025-10-19 13:50 , Processed in 0.063426 second(s), 14 queries , MemCached On.
