查看: 15594|回复: 52
[进阶教程] 小爱音箱让电视播放任意电影教程(附详细配置流程及代...
发表于 2023-11-18 00:26:41 | 显示全部楼层 |阅读模式
你们要的小爱同学让电视播放任意电影实现观影自有的教程来了。
首先说明,我实在群晖docker安装的homeassistant和nodered,部署在其他服务器上的可参考修改。
1.本地部署小雅,具体怎么部署的自己搜哔站,教程一大堆就不在重复。假设我部署的地址是:http://192.168.1.222:6789/
后边代码中这个地址改为你自己的
2.在homeassistant中将你家的电视通过dlna接入。
3.在群晖创建一个文件夹挂载 nodered的root目录。
4.群晖开启ssh,并进入nodered容器内部:
docker exec -it nodered /bin/bash
我这里以新docker部署的nr为例
安装http请求及解析需要的库:
python3 -m ensurepip --upgrade
python3 -m pip install requests
python3 -m pip install bs4
安装完就可以到nr里边操作了。
5.在nodered中,将我的流导入:并将第一步说的小雅的网址改为自己的
        "id": "ce7ae6436c0af95a",
        "type": "file",
        "z": "5641ce060432f122",
        "name": "存储在root目录下",
        "filename": "/root/查询小雅电影url.py",
        "filenameType": "str",
        "appendNewline": true,
        "createDir": true,
        "overwriteFile": "true",
        "encoding": "none",
        "x": 430,
        "y": 1740,
        "wires": [
                "6d47d72d49f59618"
        "id": "6d47d72d49f59618",
        "type": "exec",
        "command": "python3 /root/查询小雅电影url.py",
        "addpay": "payload",
        "append": "",
        "useSpawn": "false",
        "timer": "",
        "winHide": false,
        "oldrc": false,
        "name": "",
        "x": 740,
        "y": 1740,
        "wires": [
                "05f6b97e57de70a4",
                "931f4e09ee722274"
        "id": "1b5f9bfbd0bce847",
        "type": "api-call-service",
        "name": "主卧电视",
        "server": "598f8fe7bc05621b",
        "version": 5,
        "debugenabled": false,
        "domain": "media_player",
        "service": "play_media",
        "areaId": [
            "wo_shi"
        "deviceId": [],
        "entityId": [
            "media_player.zhu_wo_dian_shi"
        "data": "{\t   "media_content_id": msg.payload[0],\t   "media_content_type":"video",\t   "announce":"true"\t}",
        "dataType": "jsonata",
        "mergeContext": "",
        "mustacheAltTags": false,
        "outputProperties": [],
        "queue": "none",
        "x": 1680,
        "y": 1700,
        "wires": [
                "6ffd3c1403904fc6"
        "id": "6ffd3c1403904fc6",
        "type": "debug",
        "name": "debug 18",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 1960,
        "y": 1800,
        "wires": []
        "id": "2e0618eb53503ab3",
        "type": "debug",
        "name": "debug 20",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 1460,
        "y": 1600,
        "wires": []
        "id": "030138d8effd759f",
        "type": "template",
        "name": "python 脚本",
        "field": "payload",
        "fieldType": "msg",
        "format": "python",
        "syntax": "mustache",
        "template": "import requests\nfrom bs4 import BeautifulSoup\n\n# 定义URL\nurl = "http://192.168.1.222:6789/search?box={{payload}}&type=video&url="\n\n# 发送GET请求获取页面内容\nresponse = requests.get(url)\n\n# 检查响应状态码\nif response.status_code == 200:\n    html = response.text\n\n    # 使用Beautiful Soup解析HTML\n    soup = BeautifulSoup(html, 'html.parser')\n\n    # 找到所有的<a>标签\n    a_tags = soup.find_all('a')\n\n    # 初始化路径列表,用于存储尝试的路径\n    paths_to_try = [a['href'] for a in a_tags[2:]]\n\n    # 用于记录是否找到匹配的文件名\n    found = False\n\n    # 检查列表中是否包含".mkv"或".mp4"的结果\n    for path in paths_to_try:\n        if ".mkv" in path or ".mp4" in path:\n            # 拼接新的URL\n            new_url = f"http://192.168.1.222:6789/d/{path}"\n            print(new_url)\n            found = True\n            break\n\n    if not found:\n        while paths_to_try and not found:\n            path = paths_to_try.pop(0)  # 弹出列表中的第一个路径\n\n            # 定义URL\n            api_url = "http://192.168.1.222:6789/api/fs/list"\n\n            # 定义请求参数\n            params = {\n                "path": path,\n                "password": "",\n                "page": 1,\n                "per_page": 30,\n                "refresh": False\n            }\n\n            # 发送POST请求获取JSON响应\n            response = requests.post(api_url, json=params)\n\n            # 检查响应状态码\n            if response.status_code == 200:\n                data = response.json()\n\n                # 尝试获取content中的项目,如果出现异常则跳出当前循环\n                try:\n                    content = data.get("data", {}).get("content")\n                except AttributeError:\n                   # print(f"在路径 {path} 下发生异常,跳过该路径")\n                    continue\n\n                if content is not None:\n                    # 查找第一个包含“.mp4”或“.mkv”的name\n                    found_name = None\n                    for item in content:\n                        name = item.get("name", "")\n                        if ".mp4" in name or ".mkv" in name:\n                            found_name = name\n                            break\n\n                    # 如果找到了匹配的name\n                    if found_name:\n                        # 拼接完整的网址\n                        full_url = f"http://192.168.1.222:6789/d/{path}/{found_name}"\n                        print(full_url)\n                        found = True\n                    else:\n                        print(f"在路径 {path} 下未找到匹配的文件名")\n                else:\n                    print(f"JSON响应中没有'content'字段")\n            else:\n                print(f"无法访问指定URL: {api_url}")\n\n        if not found:\n            print("没有找到包含'.mp4'或'.mkv'的文件名")\nelse:\n    print("无法访问指定URL")\n",
        "output": "str",
        "x": 210,
        "y": 1760,
        "wires": [
                "ce7ae6436c0af95a"
        "id": "0e62fca7ed5d9b7b",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "速度与激情10",
        "payloadType": "str",
        "x": 130,
        "y": 1680,
        "wires": [
                "030138d8effd759f"
        "id": "05f6b97e57de70a4",
        "type": "debug",
        "name": "debug 21",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 940,
        "y": 1840,
        "wires": []
        "id": "561da383e0140cab",
        "type": "join",
        "name": "",
        "mode": "custom",
        "build": "array",
        "property": "payload",
        "propertyType": "msg",
        "key": "topic",
        "joiner": "\\n",
        "joinerType": "str",
        "accumulate": false,
        "timeout": "",
        "count": "",
        "reduceRight": false,
        "reduceExp": "",
        "reduceInit": "",
        "reduceInitType": "",
        "reduceFixup": "",
        "x": 1230,
        "y": 1720,
        "wires": [
                "2e0618eb53503ab3",
                "081e66e145ad4ade",
                "65545ddaebf3e8a4"
        "id": "c3e5a779dfee461f",
        "type": "split",
        "name": "",
        "splt": "\\n",
        "spltType": "str",
        "arraySplt": 1,
        "arraySpltType": "len",
        "stream": false,
        "addname": "",
        "x": 1130,
        "y": 1780,
        "wires": [
                "561da383e0140cab"
        "id": "4d24b8ce856620bf",
        "type": "function",
        "name": "function 10",
        "func": "\nmsg.payload=encodeURI(msg.payload).slice(0, -3);\n\n\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1630,
        "y": 1600,
        "wires": [
                "1b5f9bfbd0bce847"
        "id": "ef5d923092afd21d",
        "type": "comment",
        "name": "电影url",
        "info": "",
        "x": 110,
        "y": 1600,
        "wires": []
        "id": "ebde0123b4902e43",
        "type": "server-state-changed",
        "name": "小爱对话",
        "version": 4,
        "exposeToHomeAssistant": false,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "sensor.xiaomi_lx5a_7d9b_conversation",
        "entityidfiltertype": "exact",
        "outputinitially": false,
        "state_type": "str",
        "haltifstate": "",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "outputs": 1,
        "output_only_on_state_change": true,
        "for": "0",
        "forType": "num",
        "forUnits": "minutes",
        "ignorePrevStateNull": false,
        "ignorePrevStateUnknown": false,
        "ignorePrevStateUnavailable": false,
        "ignoreCurrentStateUnknown": false,
        "ignoreCurrentStateUnavailable": false,
                "value": "",
                "valueType": "entityState"
                "property": "data",
                "value": "",
                "valueType": "eventData"
                "property": "topic",
                "value": "",
                "valueType": "triggerId"
        "x": 120,
        "y": 2000,
        "wires": [
                "2f2c89887be9e04e"
        "id": "2f2c89887be9e04e",
        "type": "switch",
        "name": "我想看",
        "rules": [
                "t": "cont",
                "v": "我想看",
                "vt": "str"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 310,
        "y": 1980,
        "wires": [
                "b028350e4a8ff48d",
                "2dc0658ed70d52dd"
        "id": "b028350e4a8ff48d",
        "type": "split",
        "name": "",
        "splt": "想看",
        "spltType": "str",
        "arraySplt": "1",
        "stream": false,
        "addname": "",
        "x": 510,
        "y": 1980,
        "wires": [
                "2c27c3910bb47959"
        "id": "2c27c3910bb47959",
        "type": "join",
        "name": "",
        "mode": "custom",
        "build": "array",
        "key": "topic",
        "joiner": "\\n",
        "timeout": "",
        "count": "",
        "reduceExp": "",
        "reduceInit": "",
        "reduceFixup": "",
        "x": 670,
        "y": 1980,
        "wires": [
                "cfb73ae3d376c74a"
        "id": "cfb73ae3d376c74a",
        "type": "function",
        "name": "",
        "func": "msg.payload = msg.payload[1]\n\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 790,
        "y": 1980,
        "wires": [
                "030138d8effd759f",
                "f4f391a64858ac59"
        "id": "df9356cc80c6bfb0",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "我想看我和我的祖国",
        "x": 210,
        "y": 2100,
        "wires": [
                "2f2c89887be9e04e"
        "id": "2dc0658ed70d52dd",
        "type": "xiaoai-mediaplayer",
        "name": "",
        "xiaoai": "09b787bdbe3ed75d",
        "action": "pause",
        "device": "",
        "x": 550,
        "y": 2100,
        "wires": [
        "id": "f23f85e17f7d3a33",
        "name": "",
        "version": 5,
        "areaId": [],
        "deviceId": [],
        "entityId": [
            "media_player.chuang_wei_ke_ting_dian_shi_g6_7f6_dlna"
        "mergeContext": "",
        "queue": "none",
        "x": 1790,
        "y": 1860,
        "wires": [
                "6ffd3c1403904fc6"
        "id": "3798846de5c7f949",
        "name": "电影名称",
        "version": 4,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "input_text.dian_ying_ming_cheng",
        "haltifstate": "",
        "outputs": 1,
        "for": "0",
        "forType": "num",
                "value": "",
                "property": "data",
                "value": "",
                "value": "",
        "x": 100,
        "y": 1880,
        "wires": [
                "030138d8effd759f"
        "id": "081e66e145ad4ade",
        "name": "",
        "version": 5,
        "service": "media_stop",
        "areaId": [],
        "deviceId": [],
        "entityId": [
        "data": "",
        "mergeContext": "",
        "queue": "none",
        "x": 1250,
        "y": 1860,
        "wires": [
        "id": "e6304a814503d679",
        "type": "debug",
        "name": "debug 301",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "x": 1550,
        "y": 1960,
        "wires": []
        "id": "2162eb85046df316",
        "type": "delay",
        "name": "",
        "pauseType": "delay",
        "timeout": "2",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 1640,
        "y": 1780,
        "wires": [
                "f23f85e17f7d3a33"
        "id": "3e5669590088e34d",
        "type": "function",
        "name": "function 17",
        "func": "// 获取输入的URL\nvar originalURL = msg.payload;\n\n// 使用encodeURI函数转换URL\nvar encodedURL = encodeURI(originalURL);\n\n// 删除末尾的逗号\nvar cleanedURL = encodedURL.replace(/,+$/, '');\n\n// 将清理后的URL存储在msg.payload中\nmsg.payload = cleanedURL;\n\n// 返回msg对象以传递到下一个节点\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1470,
        "y": 1840,
        "wires": [
                "2162eb85046df316",
                "e6304a814503d679"
        "id": "65545ddaebf3e8a4",
        "type": "switch",
        "name": "",
        "rules": [
                "t": "cont",
                "v": "%20",
                "vt": "str"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 1410,
        "y": 1680,
        "wires": [
                "2162eb85046df316"
                "3e5669590088e34d"
        "id": "3a5605c9317eb24f",
        "name": "",
        "version": 5,
        "domain": "xiaomi_miot",
        "service": "intelligent_speaker",
        "areaId": [],
        "deviceId": [],
        "entityId": [
            "media_player.xiaomi_lx5a_7d9b_play_control"
        "data": "{"text":"没有找到您所说的电影,可以去tv,box找找"}",
        "mergeContext": "",
        "queue": "none",
        "x": 1030,
        "y": 1520,
        "wires": [
        "id": "931f4e09ee722274",
        "type": "switch",
        "name": "",
        "rules": [
                "t": "cont",
                "v": "没有找到包含",
                "vt": "str"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 850,
        "y": 1620,
        "wires": [
                "3a5605c9317eb24f"
                "c3e5a779dfee461f",
                "38da2c94e298a6f6",
                "8b39e6f4e4fa8774"
        "id": "1ee4cc39ad69ee40",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 990,
        "y": 1920,
        "wires": [
                "081e66e145ad4ade"
        "id": "dac6af55d7290b5e",
        "name": "",
        "version": 5,
        "areaId": [],
        "deviceId": [],
        "entityId": [
        "data": "{"text":msg.name}",
        "mergeContext": "",
        "queue": "none",
        "x": 1410,
        "y": 1520,
        "wires": [
        "id": "38da2c94e298a6f6",
        "type": "function",
        "name": "function 18",
        "func": "\n\n\nmsg.name = "正在为您播放 " + global.get("moviename")+"请稍后";\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1030,
        "y": 1580,
        "wires": [
                "dac6af55d7290b5e"
        "id": "f4f391a64858ac59",
        "type": "function",
        "name": "function 19",
        "func": "\n\nglobal.set("moviename", msg.payload);\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 930,
        "y": 2020,
        "wires": [
        "id": "8b39e6f4e4fa8774",
        "type": "debug",
        "name": "debug 302",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 1130,
        "y": 1660,
        "wires": []
        "id": "598f8fe7bc05621b",
        "type": "server",
        "name": "Home Assistant",
        "version": 5,
        "addon": false,
        "rejectUnauthorizedCerts": false,
        "connectionDelay": true,
        "cacheJson": true,
        "heartbeat": false,
        "heartbeatInterval": "30",
        "areaSelector": "friendlyName",
        "deviceSelector": "friendlyName",
        "entitySelector": "friendlyName",
        "statusSeparator": ": ",
        "statusYear": "hidden",
        "statusMonth": "short",
        "statusDay": "numeric",
        "statusHourCycle": "default",
        "statusTimeFormat": "h:m",
        "enableGlobalContextStore": false
        "id": "09b787bdbe3ed75d",
        "type": "xiaoai-tts-configurator",
        "name": ""
在nr输入一个你想看的电影,如果出现下边的url就说明成功了。恭喜你,可以随心看电影了。
如果上边的流导入有问题就直接下载附件
flows1.zip
4.63 KB, 下载次数: 127
参与人数 3金钱 +25 收起 理由
baiqianlover + 5 厉害了word楼主!
DDDear + 10 大神666!
隔壁的王叔叔 + 10 高手,这是高手!
发表于 2023-11-18 20:28:38 | 显示全部楼层
大神666.
 楼主| 发表于 2023-11-18 21:21:36 | 显示全部楼层
你都弄好了,你是大神
发表于 2023-11-19 06:42:17 来自手机 | 显示全部楼层
厉害了,膜拜一下
发表于 2023-11-19 23:19:42 | 显示全部楼层
厉害了,膜拜一下
发表于 2023-11-19 23:21:24 | 显示全部楼层
建议直接在论坛分享教程,还可以混个技达~
 楼主| 发表于 2023-11-20 01:06:41 | 显示全部楼层
囧大都发话了必须好好写个教程,话说技达是评的还是攒积分?
发表于 2023-11-20 15:51:09 | 显示全部楼层
有些人可能是在homeassistant里面安装的nodered,并不是独立的docker,这种情况怎么安装http请求及解析需要的库(bs4)
发表于 2023-11-23 01:24:23 | 显示全部楼层
电视提示视频播放失败,不知道哪里有问题了。 能找到视频url的,就是播放不了。不知道为什么。
用call service,试过同样的url也是同样的错误。
另外,也测试过,该dlna设备可以正常播放添加到HA的媒体文件夹的视频。
发表于 2023-11-23 08:25:33 | 显示全部楼层
算评的吧,有原创代码能力,在论坛多发教程,我会给加技达的
GMT+8, 2025-9-16 02:56 , Processed in 1.076120 second(s), 17 queries , MemCached On.
