楼主: 倚竹聽雨
[新奇玩法] Aarch64 OpenWRT运行Home Assistant OS新姿势
发表于 2024-4-18 23:19:28 | 显示全部楼层
rk3399 用pve安装haos不是更方便
发表于 2024-4-20 11:12:53 | 显示全部楼层
这似乎是个新思路,我用3399的板子可折腾够了。用Debian10吧Docker正常运行安装了homeassistant core版本 要升级Supervisor版呢又系统版本低升不了,用Debian11吧Docker又出问题运行不起来,直接搞的没脾气!
发表于 2024-6-30 01:00:26 | 显示全部楼层
想问一下宿主机是ARMbian该咋办呢,不会配置桥接接口  卡住了
发表于 2024-6-30 11:48:29 | 显示全部楼层
大佬   我的和39楼一样,报错  内容如下:Error starting domain: unable to open '/sys/fs/cgroup/machine/qemu-29-haos.libvirt-qemu/': No such file or directory
  File "/usr/share/virt-manager/virtManager/asyncjob.py", line 65, in cb_wrapper
    callback(asyncjob, *args, **kwargs)
  File "/usr/share/virt-manager/virtManager/asyncjob.py", line 101, in tmpcb
    callback(*args, **kwargs)
  File "/usr/share/virt-manager/virtManager/object/libvirtobject.py", line 57, in newfn
    ret = fn(self, *args, **kwargs)
  File "/usr/share/virt-manager/virtManager/object/domain.py", line 1329, in startup
    self._backend.create()
  File "/usr/lib/python3/dist-packages/libvirt.py", line 1353, in create
    raise libvirtError('virDomainCreate() failed')
libvirt.libvirtError: unable to open '/sys/fs/cgroup/machine/qemu-29-haos.libvirt-qemu/': No such file or directory
发表于 2024-8-29 18:13:03 | 显示全部楼层
求问这个aarch64是UEFI引导的吗还是怎么引导的
另外为什么不直接用系统自带的KVM呢?
GMT+8, 2025-9-13 03:08 , Processed in 0.576758 second(s), 12 queries , MemCached On.
