楼主: dscao
[插件集成] [加载项] 将常用的docker转化为hassos中的addons
发表于 2023-10-17 13:58:47 | 显示全部楼层
膜拜大神!大神加油
发表于 2023-10-17 14:06:38 | 显示全部楼层
学习学习
发表于 2023-10-17 16:02:33 | 显示全部楼层
膜拜  正好研究看看
bbg
发表于 2023-10-18 10:41:46 | 显示全部楼层
电网数据  出错了看看啥问题
#22 0x7fc1d1cd206f clone
2023-10-18 10:09:25  [INFO    ] ---- Webdriver initialized.
2023-10-18 10:09:49  [ERROR   ] ---- Webdriver quit abnormly, reason: Message: element not interactable
  (Session info: headless chrome=90.0.4430.212)
Stacktrace:
#0 0x55783a3177f9 <unknown>
#1 0x55783a2b73b3 <unknown>
#2 0x557839ffede1 <unknown>
#3 0x55783a02ebe4 <unknown>
#4 0x55783a02e659 <unknown>
#5 0x55783a056dc2 <unknown>
#6 0x55783a02ad7b <unknown>
#7 0x55783a056fce <unknown>
#8 0x55783a0679e1 <unknown>
#9 0x55783a056c93 <unknown>
#10 0x55783a028ce4 <unknown>
#11 0x55783a02a4d2 <unknown>
#12 0x55783a2e3542 <unknown>
#13 0x55783a2f2ce7 <unknown>
#14 0x55783a2f29e4 <unknown>
#15 0x55783a2f713a <unknown>
#16 0x55783a2f35b9 <unknown>
#17 0x55783a2d8e00 <unknown>
#18 0x55783a30a5d2 <unknown>
#19 0x55783a30a778 <unknown>
#20 0x55783a322a1f <unknown>
#21 0x7fcafe106fa3 start_thread
#22 0x7fcafd35c06f clone
. 1 retry times left.
  File "/app/data_fetcher.py", line 30, in fetch
    return self._fetch()
  File "/app/data_fetcher.py", line 47, in _fetch
    self._login(driver)
  File "/app/data_fetcher.py", line 106, in _login
    input_elements[2].send_keys(orc_result)
  File "/usr/local/lib/python3.8/site-packages/selenium/webdriver/remote/webelement.py", line 223, in send_keys
    self._execute(Command.SEND_KEYS_TO_ELEMENT,
  File "/usr/local/lib/python3.8/site-packages/selenium/webdriver/remote/webelement.py", line 396, in _execute
    return self._parent.execute(command, params)
  File "/usr/local/lib/python3.8/site-packages/selenium/webdriver/remote/webdriver.py", line 429, in execute
    self.error_handler.check_response(response)
  File "/usr/local/lib/python3.8/site-packages/selenium/webdriver/remote/errorhandler.py", line 243, in check_response
    raise exception_class(message, screen, stacktrace)
selenium.common.exceptions.ElementNotInteractableException: Message: element not interactable
3万
 楼主| 发表于 2023-10-18 13:27:28 | 显示全部楼层
bbg 发表于 2023-10-18 10:41
电网数据  出错了看看啥问题
你是什么环境呢?是用这个加载项安装的吗?
这个看不出来什么问题,前天我测试是正常的。平时我是用docker的,刚刚又重新在加载项安装了一下,测试还是正常的哦。
发布测试截图后,第二天官网就有变动而导致插件不能使用了。
发表于 2023-10-18 15:07:17 | 显示全部楼层
试试看看
发表于 2023-10-18 21:55:39 | 显示全部楼层
一定要推的,正苦惱HA不支持非HA容器。
发表于 2023-10-18 23:50:36 | 显示全部楼层
刚起步 小白一个 学习学习
发表于 2023-10-19 09:31:21 | 显示全部楼层
看看是什么好东西
发表于 2023-10-19 10:40:55 | 显示全部楼层
谢谢大佬的分享
GMT+8, 2025-9-19 05:38 , Processed in 1.221924 second(s), 11 queries , MemCached On.
