楼主: idreamshen
[插件集成] 【2025.3.20更新】Volvo On Call CN 沃尔沃 HASS 集成【中国区】
 火.. [复制链接]
发表于 2023-8-30 10:19:39 | 显示全部楼层
idreamshen 发表于 2023-8-22 22:31
“配置-人员”自己改“跟踪设备”。它会默认追加到人员,你手动删除就行。 ...
大佬,今天集成好像失效了,重新添加集成也加不了,输入手机号和密码显示Unkown
发表于 2023-8-30 12:23:40 | 显示全部楼层
Logger: homeassistant.components.volvooncall.config_flow
Source: components/volvooncall/__init__.py:166
Integration: Volvo On Call (documentation, issues)
First occurred: 12:06:03 (1 occurrences)
Last logged: 12:06:03
Unhandled exception in user step
  File "/usr/src/homeassistant/homeassistant/components/volvooncall/config_flow.py", line 60, in async_step_user
    await self.is_valid(user_input)
  File "/usr/src/homeassistant/homeassistant/components/volvooncall/config_flow.py", line 133, in is_valid
    await test_volvo_data.auth_is_valid()
  File "/usr/src/homeassistant/homeassistant/components/volvooncall/__init__.py", line 166, in auth_is_valid
    await self.connection.get("customeraccounts")
  File "/usr/local/lib/python3.11/site-packages/volvooncall/volvooncall.py", line 93, in get
    return await self._request(METH_GET, self._make_url(url, rel))
  File "/usr/local/lib/python3.11/site-packages/volvooncall/volvooncall.py", line 68, in _request
    async with self._session.request(
  File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 1141, in __aenter__
    self._resp = await self._coro
  File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 508, in _request
    req = self._request_class(
  File "/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 310, in __init__
    self.update_auth(auth)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 497, in update_auth
    self.headers[hdrs.AUTHORIZATION] = auth.encode()
  File "/usr/local/lib/python3.11/site-packages/aiohttp/helpers.py", line 186, in encode
    creds = (f"{self.login}:{self.password}").encode(self.encoding)
UnicodeEncodeError: 'latin-1' codec can't encode character '\u201c' in position 0: ordinal not in range(256)
发表于 2023-8-30 13:37:55 | 显示全部楼层
jasona3 发表于 2023-8-22 17:36
终于来了,hass更新后,volvo插件一直用不了。试下这个。
兄弟,你今天能用吗?我的登不上了
发表于 2023-8-30 14:07:26 | 显示全部楼层
好像跟api的接口有问题?
此错误来自自定义集成。
Logger: custom_components.volvooncall_cn.volvooncall_cn
Source: custom_components/volvooncall_cn/volvooncall_cn.py:104
Integration: Volvo On Call CN (documentation, issues)
First occurred: 13:50:00 (1 occurrences)
Last logged: 13:50:00
Failure when communicating with the server: 500, message='', url=URL('https://apigateway.digitalvolvo.com/app/iam/api/v1/auth')
  File "/config/custom_components/volvooncall_cn/volvooncall_cn.py", line 104, in _request_digitalvolvo
    response.raise_for_status()
  File "/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 1005, in raise_for_status
    raise ClientResponseError(
aiohttp.client_exceptions.ClientResponseError: 500, message='', url=URL('https://apigateway.digitalvolvo.com/app/iam/api/v1/auth')
发表于 2023-8-30 14:21:37 | 显示全部楼层
我的也不行,全為不可用
海鲜市场:jasona3
发表于 2023-8-30 14:24:58 | 显示全部楼层
jasona3 发表于 2023-8-30 14:21
我重啟下插件都搜不到了
插件还有的,HACS里,但横竖登不上
发表于 2023-8-30 14:49:01 | 显示全部楼层
我的也不行,全為不可用
今天早上起来刚发现的,昨天还正常使用
呼唤群主大佬……
 楼主| 发表于 2023-8-30 20:51:04 | 显示全部楼层
我晚点查下。今天一直外出了,没来得及查
公众号+海鲜市场: 万能浇筑哥
发表于 2023-8-30 21:19:18 | 显示全部楼层
买不起沃尔沃
发表于 2023-8-30 22:21:54 | 显示全部楼层
高手,这是高手!
GMT+8, 2025-9-18 04:22 , Processed in 0.810405 second(s), 11 queries , MemCached On.
