查看: 8915|回复: 27
[硬件DIY] 代码更新带显示屏!老空调改造通过esphome接入hassio
发表于 2023-7-6 16:22:08 | 显示全部楼层 |阅读模式
老上菱单冷空调,96年生产,虽然很久,本着勤俭持家的原则还是不换了。遥控器死难用,北鼻无奈买了一个米家空调伴侣2,搞笑的是居然无法匹配??!!唉。。。。。
自己做一个控制板吧,拆除原室内机内脏
在地上随便捡一个旧的风盘控制器改造一下,风盘控制器有零线/火线/风机高挡/风机中挡/风机低挡和阀控接线端子,刚好为我所用。阀控继电器功率较小,经检查发现空调室外机继电器刚好也是12v控制,所以就从风盘阀控继电器弱电端直接驱动原空调室内机内的室外机继电器。
diy需要灵活运用,灵活发挥。
加入室内温度检测和室内机换热器温度检测
装机测试
Screenshot_20230708_150738_io.homeassistant.companion.android.jpg Screenshot_20230708_150748_io.homeassistant.companion.android.jpg
已通过巴法云接入小爱同学,效果还不错,现已正常服役,可显示送风模式档位、制冷设定的稳定、关闭状态、关闭5秒后显示时钟。
红外控制待完善。代码如下:
esphome:
  friendly_name: "shangling"
  platformio_options:
    board_build.flash_mode: dio
    board_build.mcu: esp32c3
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: esp-idf
    version: recommended
    # Custom sdkconfig options
    sdkconfig_options:
      CONFIG_COMPILER_OPTIMIZATION_SIZE: y
    # Advanced tweaking options
    advanced:
      ignore_efuse_mac_crc: false
logger:
  hardware_uart: USB_SERIAL_JTAG
#logger:
# Enable logging
# Enable Home Assistant API
api:
ota:
  password: "xxxxxxxxxx"
wifi:
  networks:
     - ssid: xxxxxx
       password: xxxxxxxxxx
  ap:
    ssid: "climate Fallback Hotspot"
    password: "trRclijXb3T4"
time:
  - platform: homeassistant
#盘管温度检测
  - platform: dallas
    dallas_id: hub_1
    address: 0x013ce1e07601d428
#室内温度检测
  - platform: dallas
    dallas_id: hub_2
    address: 0xfb3cdcf649306728
dallas:
  - pin: GPIO4
    update_interval: 10s
  - pin: GPIO5
display:
    platform: tm1637
    clk_pin: 0
    dio_pin: 1
#    inverted: true
    length: 4
    update_interval: 500ms
    lambda: |-
        static int i = 0;
        i++;
        if (id(relay_1).state == true && id(valve).state == false ) {
          it.print("FS-1");
         } else if (id(relay_2).state == true && id(valve).state == false) {
          it.print("FS-2");
         } else if (id(relay_3).state == true && id(valve).state == false) {
          it.print("FS-3");
        } else if (id(ventilate).state == true && id(valve).state == true) {
          it.printf(0, "-%.0f-", id(mythermostat).target_temperature );
        } else if (id(relay_4).state == true && id(ventilate).state == false && id(valve).state == false) {
          it.print(1,"OFF");
        } else if (id(relay_4).state == false && (i % 2) == 0 && id(valve).state == false)
           it.strftime("%H.%M", id(homeassistant_time).now());
          else
           it.strftime("%H%M", id(homeassistant_time).now());
#remote_receiver:
 # pin:
 #   number: 7
 #   inverted: true
 #   mode:
 #     input: true
  #    pullup: true
 # dump: all
switch:
# relay 1 风扇 low
  - platform: gpio
    pin: 10
 #   name: "Fan low"
    interlock: &interlock_group [relay_1, relay_2, relay_3]
    interlock_wait_time: 50ms
    restore_mode: ALWAYS_OFF
# relay 2 风扇 mid
  - platform: gpio
    pin: 3
#    name: "Fan mid"
    interlock: *interlock_group
# relay 3 风扇 high
  - platform: gpio
    pin: 2
 #   name: "Fan high"
# 时间切换
  - platform: gpio
    pin: 8
# relay 4  室外机继电器
  - platform: gpio
    pin: 6
    icon: "mdi:valve"
  #  internal: true
  #  on_turn_on:
 #     - switch.turn_on: relay_6
  #  on_turn_off:
  #    - switch.turn_off: relay_6
#制冷指示灯
  - platform: gpio
    pin: 1
#    name: "refrigeration"
    inverted: false
#  电源指示灯
  - platform: gpio
    pin: 0
#    name: "power"
    inverted: false
# setting up fan with output to corresponding fanspeed
#风扇组件
fan:
  - platform: speed
    output: custom_fan
    speed_count: 3
output:
  - platform: template
    type: float
    write_action:
      - if:
          condition:
            lambda: return ((state ==0));
          then:
            #action for off
            - switch.turn_off: relay_1
            - switch.turn_off: relay_2
            - switch.turn_off: relay_3
      - if:
          condition:
             lambda: return (( state > .16) && (state < .34));
          then:
            # action for low
            - switch.turn_on: relay_1
      - if:
          condition:
             lambda: return ((state > .35) && (state < .7));
          then:
           # action for medium
            - switch.turn_on: relay_2
      - if:
          condition:
             lambda: return ((state ==1));
          then:
            # action for high
            - switch.turn_on: relay_3
# setting up climate conrol
climate:
  - platform: thermostat
    name: "Climate Controller"
    sensor: sntemperature
    visual:
      min_temperature: 17
      max_temperature: 30
      temperature_step: 0.1°C
    min_cooling_off_time: 5s
    min_cooling_run_time: 5s
    min_fan_mode_switching_time: 1s
    min_fanning_off_time: 5s
    min_fanning_run_time: 5s
    min_idle_time: 5s
#    fan_with_cooling: true
#制冷模式
    cool_action:
       - fan.turn_on: ventilate
       - switch.turn_on: valve
#空闲模式
    idle_action:
       - switch.turn_off: valve
    dry_action:
    default_preset: home
    on_boot_restore_from: memory
    preset:
      - name: home
        default_target_temperature_high: 26
        fan_mode: medium
        mode: cool
    cool_mode:
#        - switch.turn_on: valve
 #       - fan.turn_on: ventilate
        - switch.turn_on: relay_7
    dry_mode:
    off_mode:
       - fan.turn_off: ventilate
       - switch.turn_off: relay_7
    fan_only_action:
    fan_mode_low_action:
      lambda: !lambda |-
         auto call = id(ventilate).turn_on();
         call.set_speed(1);
         call.perform();
    fan_mode_medium_action:
      lambda: !lambda |-
         call.set_speed(2);
         call.perform();
    fan_mode_high_action:
      lambda: !lambda |-
         call.set_speed(3);
         call.perform();
    fan_mode_off_action:
    fan_mode_on_action:
参与人数 5金钱 +59 HASS币 +10 收起 理由
ryf + 5 高手,这是高手!
xuyang + 12 高手,这是高手!
咸味土豆 + 12 虽然看不懂,但感觉很厉害的样子。.
book123 + 10 感谢楼主分享!
admin + 20 + 10 高手,这是高手!
发表于 2023-7-6 16:34:28 | 显示全部楼层
我更喜欢82年的老风扇
 楼主| 发表于 2023-7-6 19:15:23 | 显示全部楼层
yc0209 发表于 2023-7-6 16:34
我更喜欢82年的老风扇
我更喜欢82年的拉菲
hyq
发表于 2023-7-6 22:07:46 | 显示全部楼层
我更喜欢82年的老风扇
古董级别的我家也还有一台!现在都还能工作!
发表于 2023-7-6 23:44:13 | 显示全部楼层
直接用esphome替代了原机的主机板了吗?牛哇
发表于 2023-7-7 07:40:21 | 显示全部楼层
如果能把接线图分享一下就好了,方便大家学习。
 楼主| 发表于 2023-7-7 08:30:46 | 显示全部楼层
对于定频空调很简单,掏出室内机内脏,把风机线、压缩机线和电源线接上就行了
发表于 2023-7-7 08:42:40 | 显示全部楼层
牛逼,要对空调内部线路要有了解才行,空调内部线组定义是网上找资料还是自己摸索的
 楼主| 发表于 2023-7-7 09:00:20 | 显示全部楼层
360341024 发表于 2023-7-7 08:42
牛逼,要对空调内部线路要有了解才行,空调内部线组定义是网上找资料还是自己摸索的 ...
定频很简单,拆开就知道了
发表于 2023-7-7 09:59:14 来自手机 | 显示全部楼层
用我这个可以替代主控就是不知道怎么接线,这东西会自动变频
【闲鱼】https://m.tb.cn/h.5aIpGte?tk=G5phdHKO9kE CZ3457 「我在闲鱼发布了【zigbee空调控制器,】」
点击链接直接打开
想问下能接?
GMT+8, 2025-9-17 03:20 , Processed in 0.655323 second(s), 10 queries , MemCached On.
