楼主: cxlwill
[经验分享] 升级 python-miio 至 0.3.3,根治0.60.0错误
发表于 2017-12-25 15:43:12 | 显示全部楼层
谢谢分享
发表于 2017-12-26 12:56:19 | 显示全部楼层
谢谢分享,支持一下
★Raspberry + Raspbian + Home Assistant v0.1
★树莓派 + Raspbian系统 + HomeAssistant
https://github.com/huangqian8/homeassistant
发表于 2017-12-28 00:49:44 | 显示全部楼层
我升完反而挂了
之前是用把
        "devtype" / Enum(Default(Int16ub, 0x02f2),
                         default=Pass, **xiaomi_devices),
替换成
   "devtype" / Int16ub
解决的,虽然还会报错,但起码能用不是很明白为什么升级了miio反而又不能用了
发表于 2017-12-28 13:52:54 | 显示全部楼层
Raspbian 的 Components 路径是: /srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components,先把此路径文件夹添加到samba,赋予777权限,然后按照“智能届唯一女神”的本贴方法,分分钟搞定,感谢墨澜女神!!!
发表于 2017-12-29 09:10:41 | 显示全部楼层
厉害哇
发表于 2018-1-8 23:44:59 | 显示全部楼层
解决了,非常感谢
发表于 2018-1-14 14:39:58 | 显示全部楼层
群晖、Hassio 自理
发表于 2018-3-27 09:13:17 | 显示全部楼层
Hassio 的Components 路径???
发表于 2019-2-23 17:08:22 | 显示全部楼层
你们怎么作的呢?
我还是报错:
2145        2019-02-23 16:48:54 INFO (MainThread) [homeassistant.components.switch.xiaomi_miio] Initializing with host 192.168.199.129 (token c3bc8...)
  2146        2019-02-23 16:48:55 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  2147        Traceback (most recent call last):
  2148          File "/data/shufu/apps/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 332, in _async_add_entity
  2149            'Invalid entity id: {}'.format(entity.entity_id))
  2150        homeassistant.exceptions.HomeAssistantError: Invalid entity id: switch.
  2151        2019-02-23 16:48:55 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 9.8 seconds.
GMT+8, 2025-9-15 03:04 , Processed in 0.631180 second(s), 12 queries , MemCached On.
