查看: 2407|回复: 1
[插件集成] 使用外部python给homeassistant MQTT推送设备代码示例
发表于 2023-6-28 14:35:48 | 显示全部楼层 |阅读模式
这个是纯个人学习,也相当于给一些练手的看看,HA有node-red方式方法是一样的,只是个人喜欢使用python,处理逻辑好用,具体代码可以下载附件
import json
import time
import paho.mqtt.client as mqtt
# 这段是你的MQTT的地址和端口信息
mqtt_server = "192.168.20.6"
mqtt_port = 1883
client = mqtt.Client()
# 这段是你的MQTT的账户名和密码,
client.username_pw_set("homeassistant", "Eugae4phah6aaz9fohpei9duGuh7Yatujei4NoreiNai2eem7oQue1OhKoch7ooj")
client.connect(mqtt_server, mqtt_port, 60)
# 连接MQTT服务器,使用函数方式
def client_mqtt():
    mqtt_port = 1883
# 如果有批量,可以使用此种方式创建MQTT控件信息,直接调用函数就可以
def configure_device(client, device_type, device_id, name, manufacturer, model, sw_version, unit, icon, payload_on=None,
                     payload_off=None):
    topic_config = f"homeassistant/{device_type}/{device_id}/config"
    topic_state = f"homeassistant/{device_type}/{device_id}/state"
    config_data = {
        "name": name,
        "state_topic": topic_state,
        "unit_of_measurement": unit,
        "device": {
            "identifiers": [device_id],
            "manufacturer": manufacturer,
            "model": model,
            "name": name,
            "sw_version": sw_version
        "icon": icon
    if payload_on is not None and payload_off is not None:
        config_data["payload_on"] = payload_on
        config_data["payload_off"] = payload_off
    client.publish(topic_config, json.dumps(config_data))
# 单控件创建
while True:  # 循环创建,这个是测试环境,正式环境自己调节
    try:
        mqtt_topic_sensor_config = "homeassistant/sensor/test1/config"
        sensor_config = {
            "device_class": "temperature",
            "name": "test1",
            "state_topic": "homeassistant/sensor/test1/state",
            "unit_of_measurement": "°C",
            # "value_template": 0,
            "unique_id": "test1",
            # device信息,如果是相同的就会归纳到同一个设备,如果不同就是不同的设备
            "device": {
                "identifiers": ["my_sensor"],
                "manufacturer": "测试MQTT",
                "model": "Model 1.0",
                "name": "my_sensor",
                "sw_version": "1.0.0"
            "icon": "mdi:thermometer"
        # 这段代码是创建控件
        client.publish(mqtt_topic_sensor_config, json.dumps(sensor_config))
        # 这段代码是更新控件值信息
        client.publish("homeassistant/sensor/test1/state", '525')
        # 创建第二个控件--------------------------------------------------------
        mqtt_topic_sensor_config = "homeassistant/sensor/test/config"
        sensor_config = {
            "name": "test",
            "text": "",
            "state_topic": "homeassistant/sensor/test/state",
            # "value_template": "0",
            "unique_id": "test",
            "device": {
        # 这段代码是创建控件
        # 这段代码是更新控件值信息
        client.publish("homeassistant/sensor/test/state", '1521')
        # 输出调试信息,正式可以拿掉
        print("OK")
    except Exception as e:
        # 错误,返回错误信息
        print(f"An error occurred: {e}")
        print("Attempting to reconnect...")
        client.reconnect()  # Attempt to reconnect
    # 设置的是每5秒更新一次
    time.sleep(5)  # Wait for 5 seconds
HA 使用外部开发发送MQTT方式进行配置设备信息.zip
1.68 KB, 下载次数: 0
发表于 2023-6-28 21:11:20 | 显示全部楼层
真棒,我原来只推送了一个,你这个好。
GMT+8, 2025-9-18 02:52 , Processed in 0.051401 second(s), 9 queries , MemCached On.
