查看: 3078|回复: 5
[插件集成] 小米净水器插件不能用了
发表于 2023-6-19 19:58:22 | 显示全部楼层 |阅读模式
不知道HA从哪个版本开始就不能用了,查日志显示如下:
Logger: homeassistant.components.sensor
Source: custom_components/mi_water_purifier/sensor.py:59
Integration: 传感器 (documentation, issues)
First occurred: 00:41:38 (1 occurrences)
Last logged: 00:41:38
Error while setting up mi_water_purifier platform for sensor
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 320, in _async_setup_platform
    await asyncio.shield(task)
  File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/config/custom_components/mi_water_purifier/sensor.py", line 37, in setup_platform
    devices.append(XiaomiWaterPurifierSensor(waterPurifier, TAP_WATER_QUALITY, unique_id))
  File "/config/custom_components/mi_water_purifier/sensor.py", line 59, in __init__
    self._attr_unique_id = unique_id + '_' + data_key['key']
TypeError: unsupported operand type(s) for +: 'int' and 'str'
有没有大神解读一下?
发表于 2023-6-20 12:58:12 | 显示全部楼层
可以试试直接用xiaomi miot auto接入?
3万
发表于 2023-6-20 13:04:58 | 显示全部楼层
改成:
self._attr_unique_id = str(unique_id) + '_' + str(data_key['key'])
试试
 楼主| 发表于 2023-6-20 21:29:53 | 显示全部楼层
miio可以接入,但是那个数据不好用
 楼主| 发表于 2023-6-20 21:32:44 | 显示全部楼层
改成:
self._attr_unique_id = str(unique_id ...
大神,按你的改了确实能用了,不报错,实体也出来了
发表于 2024-3-6 00:30:58 | 显示全部楼层
不好用,数据跟米家app上的不一致,很难看出哪个是f1、f2、ro剩余情况
GMT+8, 2025-9-18 04:00 , Processed in 0.259024 second(s), 9 queries , MemCached On.
