楼主: demacia
[智能音箱] HAVCS (ha 2023.5.2) 接入小度踩坑
007潜水了
 楼主| 发表于 2023-10-31 11:14:29 | 显示全部楼层
czou 发表于 2023-10-31 11:03
可以了,厉害,但是reload失败,授权能成功,还需要改吗
reload失败是啥意识,授权能成功了,然后你就在havcs界面上配置几个实体(传送个小度app的),然后过段时间看看小度app上面能出现配置的设备没有。出现了,就可以用语音喊喊试试了
czou
发表于 2023-10-31 11:25:00 | 显示全部楼层
demacia 发表于 2023-10-31 11:14
reload失败是啥意识,授权能成功了,然后你就在havcs界面上配置几个实体(传送个小度app的),然后过段时 ...
2023-10-31 11:14:43.916 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [139863382710976] Error handling message: Unknown error (unknown_error)  from 172.17.0.4 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36)
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 26, in _handle_async_response
    await func(hass, connection, msg)
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 727, in handle_execute_script
    script_result = await script_obj.async_run(msg.get("variables"), context=context)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1578, in async_run
    return await asyncio.shield(run.async_run())
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 420, in async_run
    await self._async_step(log_exceptions=False)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 470, in _async_step
    self._handle_exception(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 493, in _handle_exception
    raise exception
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 468, in _async_step
    await getattr(self, handler)()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 704, in _async_call_service_step
    response_data = await self._async_run_long_action(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 666, in _async_run_long_action
    return long_task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 2012, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2049, in _execute_service
    return await target(service_call)
  File "/config/custom_components/havcs/__init__.py", line 653, in async_handler_service
    await hass.data[DOMAIN][DATA_HAVCS_HANDLER][platform].vcdm.async_reregister_devices(hass)
  File "/config/custom_components/havcs/helper.py", line 265, in async_reregister_devices
    device_registry = await hass.helpers.device_registry.async_get_registry()
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1073, in __getattr__
    value = getattr(self._module, attr)
AttributeError: module 'homeassistant.helpers.device_registry' has no attribute 'async_get_registry'
这个 async_get_registry 还没改,等真实测试看看是否正常
007潜水了
 楼主| 发表于 2023-10-31 12:30:20 | 显示全部楼层
你是不是没看帖子,这个帖子就是这个报错踩坑
czou
发表于 2023-11-1 08:49:09 | 显示全部楼层
弄好了,但是出现了新的问题,在小度智能家居里面设备一直是离线状态,但是能开灯没办法关灯
007潜水了
 楼主| 发表于 2023-11-1 09:53:45 | 显示全部楼层
czou 发表于 2023-11-1 08:49
弄好了,但是出现了新的问题,在小度智能家居里面设备一直是离线状态,但是能开灯没办法关灯 ...
绷不住了,这么坑吗。网络确实比较蛋疼,我之前是走国外vps代理的,速度比较慢,延迟很厉害。
czou
发表于 2023-11-1 12:29:32 | 显示全部楼层
demacia 发表于 2023-11-1 09:53
绷不住了,这么坑吗。网络确实比较蛋疼,我之前是走国外vps代理的,速度比较慢,延迟很厉害。 ...
不知道什么问题,还没开始排查,我是走国内的网络,应该不是网速的问题
发表于 2024-4-20 01:36:23 | 显示全部楼层
https://havcs.ljr.im:8123/account,此网页打不开注册不了怎么办?有没有相同情况的人?
发表于 2024-9-22 14:32:29 | 显示全部楼层
coolmxq 发表于 2024-4-20 01:36
https://havcs.ljr.im:8123/account,此网页打不开注册不了怎么办?有没有相同情况的人? ...
解决没?
发表于 2025-5-4 21:51:42 | 显示全部楼层
大佬,这个havcs是可以把小度的stt接入ha,还是直接小度识别到ha里的设备,小组直接控制设备?
GMT+8, 2025-9-15 03:11 , Processed in 0.974864 second(s), 12 queries , MemCached On.
