楼主: powjie
[插件集成] 将小米多模网关支持zigBee2mqtt,接入第三方非小米ZigBee设备
发表于 2023-11-30 08:57:02 | 显示全部楼层
jy940006145 发表于 2023-5-23 12:47
我翻了一下Gateway 3的文档,那里好像写着如果启用了zha或者z2m模式,米家的zigbee设备会失去控制? ...
我说我的所有zigbee设备咋都离线了呢,重启网关也不行,不知道怎么恢复
发表于 2024-1-6 03:02:08 | 显示全部楼层
z00000000 发表于 2023-5-26 13:10
如图所示,最后的模式设定选项没有。
我的也没有。请问你解决了吗?
发表于 2024-4-15 17:59:00 | 显示全部楼层
报错日志
报错日志
我的zigbee2MQTT接入小米多模报错,搜不到,怎么解决呢,小米固件1.5.4
发表于 2024-9-19 10:21:40 | 显示全部楼层
学习了。学习老大分享!
发表于 2025-5-9 21:18:55 | 显示全部楼层
[21:14:47] INFO: Preparing to start...
[21:14:48] INFO: Socat not enabled
[21:14:48] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2025-05-09 21:14:53] info:         z2m: Logging to console, file (filename: log.log)
[2025-05-09 21:14:54] info:         z2m: Starting Zigbee2MQTT version 2.3.0 (commit #unknown)
[2025-05-09 21:14:54] info:         z2m: Starting zigbee-herdsman (4.0.0)
[2025-05-09 21:14:54] warning:         zh:ezsp: 'ezsp' driver is deprecated and will only remain to provide support for older firmware (pre 7.4.x). Migration to 'ember' is recommended. If using Zigbee2MQTT see ithub.com/Koenkk/zigbee2mqtt/discussions/21462[/url]
[2025-05-09 21:14:54] error:         zh:ezsp:ezsp: Connection attempt 1 error: Error: connect ECONNREFUSED 192.168.66.29:8888
[2025-05-09 21:14:59] error:         zh:ezsp:ezsp: Connection attempt 2 error: Error: connect ECONNREFUSED 192.168.66.29:8888
[2025-05-09 21:15:09] error:         zh:ezsp:ezsp: Connection attempt 3 error: Error: connect ECONNREFUSED 192.168.66.29:8888
连不上啊,过几钟就自己关机了,网关的ip对的,tel进网关后台查看端口8888也没有被监听
GMT+8, 2025-9-18 03:00 , Processed in 1.046836 second(s), 14 queries , MemCached On.
