查看: 11723|回复: 27
[经验分享] 实时电价、峰谷电量设置教程
发表于 2023-2-20 13:01:36 | 显示全部楼层 |阅读模式
——————————实时电价——————————————————————————
  - platform: template
    sensors:
      shishidianjia:
        unit_of_measurement: "/kWh"
        friendly_name:  '实时电价'
        value_template: >
          {% if now().strftime("%H")| int >= 8 and now().strftime("%H")|int < 22 and states("sensor.dang_qian_jie_ti")=="1" %}
            0.5953  #1阶梯,峰电费   (实际使用需要删掉备注!!!)
          {%elif now().strftime("%H")| int >= 8 and now().strftime("%H")|int < 22  and states("sensor.dang_qian_jie_ti")=="2" %}
            0.6453  #2阶梯,峰电费
          {%elif now().strftime("%H")| int >= 8 and now().strftime("%H")|int < 22  and states("sensor.dang_qian_jie_ti")=="3" %}
            0.8953  #3阶梯,峰电费
          {% elif states("sensor.dang_qian_jie_ti")=="1"%}
            0.3583  #1阶梯,谷电费
          {% elif states("sensor.dang_qian_jie_ti")=="2" %}
            0.4083  #2阶梯,谷电费
          {% elif states("sensor.dang_qian_jie_ti")=="3" %}
            0.6583  #3阶梯,谷电费
          {% endif %}
    sensors:
       dang_qian_jie_ti:
         value_template: >
           {% if states("sensor.tasmota_energy_total#改成自己的电量实体") | float <= 2300 %}
           1     #1阶梯,2300度电以内
           {% elif states("sensor.tasmota_energy_total#改成自己的电量实体") | float >2310  and states("sensor.tasmota_energy_total") | float <= 4000 %}
           2    #2阶梯,2300度—4000度
           {% elif states("sensor.tasmota_energy_total#改成自己的电量实体") | float > 4000 %}
           3    #3阶梯,4000度以上
           {% endif %}
         friendly_name:  '当前阶梯'
         unit_of_measurement: "L"
——————————峰谷电量—————————————————————————
utility_meter:
  daily_energy:
    source: sensor.tasmota_energy_total
    cycle: daily
    tariffs:
      - peak
      - offpeak
  monthly_energy:
    cycle: monthly
    tariffs:
      - peak
      - offpeak
——————————峰谷电量自动化—————————————————————————
alias: 峰谷电
description: ""
trigger:
  - platform: time
    at: "07:00:00"
    variables:
      tariff: peak
  - platform: time
    at: "21:00:00"
    variables:
      tariff: offpeak
condition: []
action:
  - service: select.select_option
    data:
      option: "{{ tariff }}"
    target:
      entity_id: select.daily_energy
mode: single
视频教程在这里:
Ari 手机认证
发表于 2023-2-20 13:17:26 | 显示全部楼层
感谢分享,实时电价不就是已经可以区分峰谷了吗
 楼主| 发表于 2023-2-20 13:35:04 | 显示全部楼层
是区分峰谷了,但是看不到峰谷电量具体是多少。后面设置是让它直接显示出多少来的
Ari 手机认证
发表于 2023-2-20 13:39:57 | 显示全部楼层
flyice 发表于 2023-2-20 13:35
是区分峰谷了,但是看不到峰谷电量具体是多少。后面设置是让它直接显示出多少来的 ...
找到漂亮的卡片顺便分享下
发表于 2023-4-14 13:01:47 | 显示全部楼层
支持,紫苏不等
发表于 2023-4-15 00:47:32 | 显示全部楼层
按月阶梯电价如何设置?
发表于 2023-4-28 11:33:05 | 显示全部楼层
你好,我们是按月阶梯实行3个电价,180度以内按照0.53元计费,180度到280度这段电价按照0.63元计费,280度以上的按照0.83元计费,然后每个月清零,第二个月从新计算,这个怎么写代码呢
发表于 2023-4-28 14:45:04 | 显示全部楼层
13990973177 发表于 2023-4-28 11:33
你好,我们是按月阶梯实行3个电价,180度以内按照0.53元计费,180度到280度这段电价按照0.63元计费,280度 ...
我们类似 再加上峰电价
发表于 2023-5-19 17:24:27 | 显示全部楼层
sensor.tasmota_energy_total是从安装时间开始累计的总电量,不具备清零功能。怎么搞个年电量的实体来判断处于哪个梯价,hass中能源里面到是可以显示年用电量,但是没有对应的实体。
发表于 2023-5-21 13:29:05 | 显示全部楼层
太多都想要。。可惜又不会玩。。蛋疼中
GMT+8, 2025-9-14 03:05 , Processed in 0.924235 second(s), 6 queries , MemCached On.
