楼主: holala
[智能音箱] 天猫精灵的接入,虚拟主机版,非docker
 火.. [复制链接]
发表于 2018-1-23 22:14:21 来自手机 | 显示全部楼层
我就是搭酸酸乳再装lnmp一键安装,注意酸酸乳 不要占用了443
发表于 2018-1-24 13:43:25 | 显示全部楼层
支持一下
3t2y 手机认证
发表于 2018-1-25 00:23:10 | 显示全部楼层
试验看看。
huex
发表于 2018-1-27 14:03:38 | 显示全部楼层
thanks。。。。。
发表于 2018-1-27 17:28:17 | 显示全部楼层
66666666666666666
发表于 2018-1-28 18:32:44 | 显示全部楼层
看看,谢谢分享
发表于 2018-1-29 10:15:57 | 显示全部楼层
学习一下!
发表于 2018-1-29 20:18:43 | 显示全部楼层
感谢楼主,天猫精灵终于到了,开始折腾……
发表于 2018-1-30 11:02:26 | 显示全部楼层
Create Virtul Host directory......
set permissions of Virtual Host directory......
You select the exist rewrite rule:/usr/local/nginx/conf/none.conf
Test Nginx configure file......
nginx: [warn] conflicting server name "www.m****.cn" on 0.0.0.0:80, ignored
nginx: the configuration file /usr/local/nginx/conf/nginx.conf syntax is ok
nginx: configuration file /usr/local/nginx/conf/nginx.conf test is successful
Reload Nginx......
Gracefully shutting down php-fpm . done
Starting php-fpm Failed loading /usr/local/zend/ZendGuardLoader.so:  /usr/local/zend/ZendGuardLoader.so: cannot open shared object file: No such file or directory
done
Create dhparam.pem...
Generating DH parameters, 2048 bit long safe prime, generator 2
This is going to take a long time
然后一直等 结束不了。
发表于 2018-1-30 14:27:45 | 显示全部楼层
非常感兴趣
GMT+8, 2025-9-21 03:02 , Processed in 1.254035 second(s), 12 queries , MemCached On.
