楼主: lhy741059930
[经验分享] 中国移动X12空调伴侣折腾(不拆机,云端协议)
发表于 2023-6-24 11:23:16 | 显示全部楼层
sorrypqa 发表于 2023-6-24 10:23
X12刷ESPHome有功率统计的呀!!只是刷了之后,不知怎么控制格力空调.......
大佬能提供一下x12刷esphome的固件么?
我的两个x12最近都报废了。打移动的电话询问后说是合作的企业停止服务了。
发表于 2023-6-24 11:29:33 | 显示全部楼层
我的两个x12最近都报废了。打移动的电话询问后说是合作的企业停止 ...
大佬的帖子里有啊
https://bbs.hassbian.com/thread-17410-1-1.html
 楼主| 发表于 2023-6-25 10:01:36 | 显示全部楼层
我刷的esphome。可以控制格力
发表于 2023-6-25 11:13:51 | 显示全部楼层
lhy741059930 发表于 2023-6-25 10:01
我刷的esphome。可以控制格力
大佬可以分享一下使用方法吗?
 楼主| 发表于 2023-6-26 16:37:06 | 显示全部楼层
sorrypqa 发表于 2023-6-25 11:13
大佬可以分享一下使用方法吗?
完整配置如下:
esphome:
esp8266:
  board: esp01_1m
# Enable logging
logger:
  level: debug
status_led:
  pin:
    number: GPIO15
ota:
  password: "43b4e7a8d3fce8b72ec81803e1023972"
wifi:
  ssid: FAST_903
  password: '13616273842'
  ap:
    ssid: "Ir Fallback Hotspot"
    password: "rHG6DQPSPI1P"
captive_portal:
web_server:
    port: 80
api:
  services:
    - service: send_raw_command
      variables:
        command: int[]
      then:
        - remote_transmitter.transmit_raw:
            code: !lambda 'return command;'
            carrier_frequency: 38kHz
    - service: send_nec_command
      variables:
        address: int
        command: int
      then:
        - remote_transmitter.transmit_nec:
            address: !lambda 'return address;'
            command: !lambda 'return command;'
    - service: send_pronto_command
      variables:
        command: string
      then:
        - remote_transmitter.transmit_pronto:
            data: !lambda 'return command;'
remote_transmitter:
  pin: GPIO14
  carrier_duty_percent: 50%
remote_receiver:
  dump: all
  pin:
    number: GPIO13
    inverted: true
    mode:
      input: true
      pullup: true
  tolerance: 50%
# remote_receiver:
#   id: rcvr
#   dump: all
#   pin: GPIO13
climate:
  - platform: heatpumpir
    protocol: greeyan
    horizontal_default: auto
    vertical_default: auto
    max_temperature: 30.0
    min_temperature: 16.0
    receiver_id: rcvr
#   - platform: midea_ir
#     name: "AC"
#     receiver_id: rcvr
  - platform: hlw8012
    model: BL0937
    sel_pin:
      number: GPIO12
      inverted: true
    cf_pin: GPIO4
    cf1_pin: GPIO5
    current_resistor: 0.001
    voltage_divider: 1711
    current:
      name: "Bedroom AC Current"
    voltage:
      name: "Bedroom AC Voltage"
    power:
      filters:
        - multiply: 0.001
      unit_of_measurement: kW
      name: "Bedroom AC Power"
    energy:
      filters:
        - multiply: 0.001
      unit_of_measurement: kWh
      name: "Bedroom AC Energy"
    update_interval: 10s
参与人数 1金钱 +10 收起 理由
sorrypqa + 10 大神666!
发表于 2023-6-26 17:11:15 | 显示全部楼层
太好了,我又翻箱倒柜把它找出来玩玩,谢谢分享!
发表于 2023-6-28 18:59:29 | 显示全部楼层
可以在homeassistant做个离线的版本,劫持下服务器,参考:https://zhuanlan.zhihu.com/p/82545806
发表于 2023-8-9 12:54:47 | 显示全部楼层
留存了,谢谢分享。。。。。。。
发表于 2023-8-10 14:29:38 | 显示全部楼层
有没有小白教程
 楼主| 发表于 2023-8-10 19:31:34 | 显示全部楼层
putao 发表于 2023-8-10 14:29
有没有小白教程
拆机刷esphome。
GMT+8, 2025-9-15 03:15 , Processed in 0.366178 second(s), 12 queries , MemCached On.
