楼主: zhf883680
[基础教程] Xiaomi Gateway 3添加不在支持列表中的设备
发表于 2024-4-11 14:15:26 | 显示全部楼层
fenglou777 发表于 2024-4-10 17:50
from custom_components.xiaomi_gateway3.core.devices import *
抬头改成这个
改了没有效果
发表于 2024-4-11 14:34:45 | 显示全部楼层
可以的。
V4的里面的Converter命名好像也变了,你进入原文件参考也修改一下。
发表于 2024-4-11 17:53:14 | 显示全部楼层
除了import路径要改外,之前引用的converter命名也要对应改,整个文件内不能出现错误,否则该文件全部不生效
发表于 2024-4-16 20:07:56 | 显示全部楼层
乱了,改不来了
发表于 2024-4-21 20:59:29 | 显示全部楼层
大佬出个新教程呗
发表于 2024-5-12 01:33:04 | 显示全部楼层
你好,我在尝试使用你的方法来修改  新的转换文件的时候 发现无论如何更改我的配置文件,我的hass中都没有相应,  使用的是zigbee 的协议  想接入一个无线开关  使用的京鱼座的套装 中的无线开关   ,使用的配置文件是https://github.com/cheny95/J.XUAN-External-converters   求指点
发表于 2024-5-13 14:01:23 | 显示全部楼层
请教一下,多种自定义开关,如何合并
发表于 2024-5-14 02:16:06 | 显示全部楼层
请教一下  我的SZGL智能感应开关四键Mesh版,通过教程后接入了四个开关。但是还有背光灯等等一系列的控制,观察代码,我尝试在mi=XX这里不断地参照模板试错,仍然无法添加其他的功能。这部分应该怎么处理合适?
发表于 2024-5-14 17:23:08 | 显示全部楼层
经过研究,补充15418   sw4a02的代码
DEVICES = [{
     15418: ["LeMesh", "Mesh Switch", "lemesh.switch.sw4a02"],
    "spec": [
        BaseConv("channel_1", "switch", mi="2.p.1"),
        BaseConv("channel_2", "switch", mi="3.p.1"),
        BaseConv("channel_3", "switch", mi="4.p.1"),
        BaseConv("channel_4", "switch", mi="12.p.1"),
        BaseConv("channel_5", "switch", mi="5.p.1"),
        MapConv("power_on_state_1", "select", mi="2.p.2", map={1: "On", 2: "Off", 3: "Default"}),
        MapConv("power_on_state_2", "select", mi="3.p.2", map={1: "On", 2: "Off", 3: "Default"}),
        MapConv("power_on_state_3", "select", mi="4.p.2", map={1: "On", 2: "Off", 3: "Default"}),
        MapConv("power_on_state_4", "select", mi="12.p.2", map={1: "On", 2: "Off", 3: "Default"}),
        MapConv("wireless_1", "select", mi="2.p.3", map={0: "default", 1: "Wireless", 2: "Wireless", 3: "Wireless"}),
        MapConv("wireless_2", "select", mi="3.p.3", map={0: "default", 1: "Wireless", 2: "Wireless", 3: "Wireless"}),
        MapConv("wireless_3", "select", mi="4.p.3", map={0: "default", 1: "Wireless", 2: "Wireless", 3: "Wireless"}),
        MapConv("wireless_4", "select", mi="12.p.3", map={0: "default", 1: "Wireless", 2: "Wireless", 3: "Wireless"}),
        MapConv("mode", "select", mi="8.p.1", map={1: "Top Speed Mode", 2: "Standard Mode"}),
        BaseConv("action", "sensor", entity=ENTITY_DISABLED),
        ConstConv("action", mi="14.e.1", value=BUTTON_1_SINGLE),
        ConstConv("action", mi="14.e.2", value=BUTTON_1_DOUBLE),
        ConstConv("action", mi="14.e.3", value=BUTTON_1_HOLD),
        ConstConv("action", mi="15.e.1", value=BUTTON_2_SINGLE),
        ConstConv("action", mi="15.e.2", value=BUTTON_2_DOUBLE),
        ConstConv("action", mi="15.e.3", value=BUTTON_2_HOLD),
        ConstConv("action", mi="16.e.1", value=BUTTON_3_SINGLE),
        ConstConv("action", mi="16.e.2", value=BUTTON_2_DOUBLE),
        ConstConv("action", mi="16.e.3", value=BUTTON_3_HOLD),
        ConstConv("action", mi="17.e.1", value=BUTTON_4_SINGLE),
        ConstConv("action", mi="17.e.2", value=button_4_double),
        ConstConv("action", mi="17.e.3", value=BUTTON_4_HOLD),
}] + DEVICES
发表于 2024-5-19 15:23:47 | 显示全部楼层
大佬我的也是这款,我在config创建了xiaomi_gateway3.py 用了您发的代码,然后重启没办法使用?请问您的可以吗?
GMT+8, 2025-9-18 04:21 , Processed in 0.436803 second(s), 11 queries , MemCached On.
