查看: 8611|回复: 22
[人体存在] CEM5855H毫米波雷达使用esphome通过串口连入HA可修改参数
发表于 2022-8-13 13:07:30 | 显示全部楼层 |阅读模式
前几天写了个CEM5825F的通过串口接入HA,按照一样的思路把5855H的串口也接入了HA,LD1115H有几条串口命令不一样,一样的也是生效的,也能显示运动状态。
https://bbs.hassbian.com/thread-17438-1-1.html CEM5825F的参考链接使用5855H和LD1115H对比了下,发现5855H误报情况比1115H要好,但是5855H有个问题是有时候触发非常不灵敏,就找卖家看能不能改到1115H固件,要了好久卖家给了我2条命令“ind_min_mov=1”和”ind_min_occ=2“,改了下效果立马变好,我也把这2条命令加进去了,有此问题的可以试一下。
yaml配置文件
esphome:
  includes:
  - UartReadLineSensor_55h.h
esp32:
  board: esp32dev
# Enable logging
logger:
  #level: VERBOSE #makes uart stream available in esphome logstream
  #baud_rate: 0 #disable logging over uart
# Enable Home Assistant API
api:
ota:
  password: "password"
wifi:
  networks:
  - ssid: "WIFI"
    password: "12345678"
  - ssid: "WIFI2"
  - ssid: "WIFI3"
  ap:
    ssid: "mmWave-Occupancy"
substitutions:
  device_name: mmwave-sensor
captive_portal:
web_server:
  port: 80
  version: 2
  include_internal: true
http_request:
  useragent: esphome/$device_name
  timeout: 2s
# switch:
#   - platform: safe_mode
#     internal: true
#     name: use_safe_mode
binary_sensor:
- platform: gpio
  pin:
    number: GPIO5
    mode: INPUT_PULLDOWN
uart:
  tx_pin: GPIO16
  rx_pin: GPIO17
  baud_rate: 115200
  # debug:
  #   direction: BOTH
  #   dummy_receiver: true
  #   after:
  #     delimiter: "\n"
  #   sequence:
  #     - lambda: UARTDebug::log_string(direction, bytes);
number:
  - platform: template
    mode: box
    min_value: 130
    max_value: 1000
    initial_value: 130
    optimistic: true
    step: 50
    restore_value: true
    #unit_of_measurement: m
    set_action:
      - uart.write: !lambda
                      int th1 = (int)ceil(x / 1.0);
                      std::string mss = "th1=" + to_string(th1);
                      return std::vector<unsigned char>(mss.begin(), mss.end());
    mode: box
    min_value: 200
    max_value: 1000
    initial_value: 250
    optimistic: true
    step: 50
    restore_value: true
    #unit_of_measurement: ms
    set_action:
                      int th2 = (int)ceil(x / 1.0);
                      std::string mss = "th2=" + to_string(th2);
    mode: box
    min_value: 130
    max_value: 1000
    initial_value: 360
    optimistic: true
    step: 50
    restore_value: true
    set_action:
                      int th_in = (int)ceil(x / 1.0);
                      std::string mss = "th_in=" + to_string(th_in);
    mode: box
    min_value: 1
    max_value: 100
    initial_value: 30
    optimistic: true
    step: 1
    restore_value: true
    unit_of_measurement: "秒"
    set_action:
                      int tons = (int)ceil(x / 1.0);
                      std::string mss = "tons=" + to_string(tons);
    mode: box
    min_value: 50
    max_value: 1000
    initial_value: 100
    optimistic: true
    step: 50
    restore_value: true
    unit_of_measurement: "毫秒"
    set_action:
                      int utons = (int)ceil(x / 1.0);
                      std::string mss = "utons=" + to_string(utons);
    mode: box
    min_value: 0
    max_value: 5
    initial_value: 1
    optimistic: true
    step: 1
    restore_value: true
    set_action:
                      int ind_min_mov = (int)ceil(x / 1.0);
                      std::string mss = "ind_min_mov=" + to_string(ind_min_mov);
    mode: box
    min_value: 0
    max_value: 5
    initial_value: 2
    optimistic: true
    step: 1
    restore_value: true
    set_action:
                      int ind_min_occ = (int)ceil(x / 1.0);
                      std::string mss = "ind_min_occ=" + to_string(ind_min_occ);
button:
    on_press:
      - uart.write: "save"
    on_press:
      - uart.write: "get_all"
    on_press:
      - uart.write: "initial"
text_sensor:
- platform: custom
  lambda: |-
    auto my_custom_sensor = new UartReadLineSensor(id(uart_bus));
    App.register_component(my_custom_sensor);
    return {my_custom_sensor};
  text_sensors:
C++文件UartReadLineSensor_55h.h
#include "esphome.h"
class UartReadLineSensor : public Component, public UARTDevice, public TextSensor{
 public:
  UartReadLineSensor(UARTComponent *parent) : UARTDevice(parent) {}
  void setup() override {
    // nothing to do here
  int readline(int readch, char *buffer, int len)
    static int pos = 0;
    int rpos;
    if (readch > 0) {
      switch (readch) {
        case '\n': // Ignore new-lines
          break;
        case '\r': // Return on CR
          rpos = pos;
          pos = 0;  // Reset position index ready for next time
          return rpos;
        default:
          if (pos < len-1) {
            buffer[pos++] = readch;
            buffer[pos] = 0;
    // No end of line has been found, so return -1.
    return -1;
  void loop() override {
    const int max_line_length = 80;
    static char buffer[max_line_length];
        static uint8_t mov_flag = 0;
        static int uartdata = 0;
        static char u16_dis[7] = {0};
        static char u16_dis_1[6] = {0};
        static char u16_dis_2[5] = {0};
        static int i,j;
        static float intdis = 0;
        static float f32rmax;
        static char chartemp[4] = {0};
        static char chartemp5[5] = {0};
        static char chartemp2[2] = {0};
        static char chartemp3[3] = {0};
        static uint8_t chartemp1 = 0;
    while (available()) {
                uartdata = readline(read(), buffer, max_line_length);
                if(uartdata > 0) {
                        //publish_state(buffer);
                         if(buffer[0] == 0x6d && buffer[1] == 0x6f && buffer[2] == 0x76)
                                if(mov_flag != 0)
                                        mov_flag = 0;
                                        publish_state("运动");
                        else if(buffer[0] == 0x6f && buffer[1] == 0x63 && buffer[2] == 0x63)
                                if(mov_flag != 1)
                                        mov_flag = 1;
                                        publish_state("静止");
                        else if(buffer[0] == 0x6e && buffer[1] == 0x75 && buffer[2] == 0x6C)
                                if(mov_flag != 2)
                                        mov_flag = 2;
                                        publish_state("无人");
                        else if(buffer[0] == 0x74 && buffer[1] == 0x68 && buffer[2] == 0x31 && buffer[3] == 0x20 && buffer[4] == 0x69 && buffer[5] == 0x73 && buffer[6] == 0x20 )
                                j = 0;
                                if(uartdata == 9)
                                        for(i = 7; i < uartdata; i++)
                                                chartemp2[j] = buffer[i];
                                                j++;
                                        id(th1).publish_state(atoi(chartemp2));
                                if(uartdata == 10)
                                                chartemp3[j] = buffer[i];
                                                j++;
                                        id(th1).publish_state(atoi(chartemp3));
                                if(uartdata == 11)
                                                chartemp[j] = buffer[i];
                                                j++;
                                        id(th1).publish_state(atoi(chartemp));
                        else if(buffer[0] == 0x74 && buffer[1] == 0x68 && buffer[2] == 0x32 && buffer[3] == 0x20 && buffer[4] == 0x69 && buffer[5] == 0x73 && buffer[6] == 0x20 )
                                j = 0;
                                if(uartdata == 9)
                                                j++;
                                        id(th2).publish_state(atoi(chartemp2));
                                if(uartdata == 10)
                                                j++;
                                        id(th2).publish_state(atoi(chartemp3));
                                if(uartdata == 11)
                                                j++;
                                        id(th2).publish_state(atoi(chartemp));
                        else if(buffer[0] == 0x74 && buffer[1] == 0x6f && buffer[2] == 0x6e && buffer[3] == 0x73 && buffer[4] == 0x20 && buffer[5] == 0x69 && buffer[6] == 0x73 && buffer[7] == 0x20 )
                                j = 0;
                                if(uartdata == 9)
                                        chartemp1 = buffer[8]-48;
                                        id(tons).publish_state(chartemp1);
                                if(uartdata == 10)
                                        for(i = 8; i < uartdata; i++)
                                                j++;
                                        id(tons).publish_state(atoi(chartemp2));
                                if(uartdata == 11)
                                                j++;
                                        id(tons).publish_state(atoi(chartemp3));
                        else if(buffer[0] == 0x75 && buffer[1] == 0x74 && buffer[2] == 0x6f && buffer[3] == 0x6e && buffer[4] == 0x73 && buffer[5] == 0x20 && buffer[6] == 0x69 && buffer[7] == 0x73 && buffer[8] == 0x20 )
                                j = 0;
                                if(uartdata == 11)
                                        for(i = 9; i < uartdata; i++)
                                                j++;
                                        id(utons).publish_state(atoi(chartemp2));
                                if(uartdata == 12)
                                                j++;
                                        id(utons).publish_state(atoi(chartemp3));
                                if(uartdata == 13)
                                                j++;
                                        id(utons).publish_state(atoi(chartemp));
                        else if(buffer[0] == 0x74 && buffer[1] == 0x68 && buffer[2] == 0x5f && buffer[3] == 0x69 && buffer[4] == 0x6e && buffer[5] == 0x20 && buffer[6] == 0x69 && buffer[7] == 0x73 && buffer[8] == 0x20 )
                                j = 0;
                                if(uartdata == 11)
                                                j++;
                                        id(th_in).publish_state(atoi(chartemp2));
                                if(uartdata == 12)
                                                j++;
                                        id(th_in).publish_state(atoi(chartemp3));
                                if(uartdata == 13)
                                                j++;
                                        id(th_in).publish_state(atoi(chartemp));
                        memset(chartemp,0,4);
                        memset(chartemp3,0,3);
                        memset(chartemp2,0,2);
                        memset(chartemp5,0,2);
参与人数 5金钱 +41 收起 理由
zxyny1989 + 12 感谢楼主分享!
jonceli + 8
jjcs + 10 在下对你的景仰犹如滔滔长江之水,连绵不绝.
情非殇 + 10 感谢楼主分享!
sxrcm + 1 高手,这是高手!
发表于 2022-8-13 13:41:16 | 显示全部楼层
给雷达大王点赞
jjcs 手机认证
57
发表于 2022-8-13 15:35:44 | 显示全部楼层
大佬牛逼
发表于 2022-8-15 09:50:50 | 显示全部楼层
这个牛的,大佬牛逼!
发表于 2022-8-24 17:25:31 | 显示全部楼层
哎,问个问题,无论5855还是1115, 调整的参数每次断电重启都恢复到出厂设置,我不清楚,ESPhome的固件,是否每次断电重启后,把存储的参数写入5855/1115?
一直困扰着我啊。
 楼主| 发表于 2022-8-24 21:15:54 | 显示全部楼层
fjn1999 发表于 2022-8-24 17:25
哎,问个问题,无论5855还是1115, 调整的参数每次断电重启都恢复到出厂设置,我不清楚,ESPhome的固件,是 ...
你应该是设置完参数后没有发save命令或者没有点我固件上面的保存按钮,否则断电参数会重置的
发表于 2022-8-31 18:37:48 | 显示全部楼层
大佬牛逼
发表于 2022-9-28 22:07:52 | 显示全部楼层
干货太干了,难以下咽,99%像我这种小白,看完跟看天书一样
发表于 2022-9-28 22:57:53 | 显示全部楼层
这个牛的,大佬牛逼!
发表于 2022-10-2 13:11:54 来自手机 | 显示全部楼层
不会切换无人
GMT+8, 2025-9-13 03:21 , Processed in 1.252261 second(s), 16 queries , MemCached On.
