楼主: qqjil
[人体存在] (更新)CEM5825F人体存使用esphome通过串口连入HA
发表于 2022-8-12 16:35:51 | 显示全部楼层
楼主我用一个便宜的蓝牙模组能不能用你这个方案直接接入米家?
tink 手机认证
发表于 2022-8-12 21:59:27 来自手机 | 显示全部楼层
距离取平均值了吗
发表于 2022-8-12 22:10:28 | 显示全部楼层
我这编译不成功,错误如下:
In file included from src/main.cpp:65:0:
src/UartReadLineSensor.h: In member function 'virtual void UartReadLineSensor::loop()':
src/UartReadLineSensor.h:67:70: error: invalid conversion from 'char*' to 'char' [-fpermissive]
                                                         u16_dis_2[j] = buffer;
src/UartReadLineSensor.h:77:70: error: invalid conversion from 'char*' to 'char' [-fpermissive]
                                                         u16_dis_1[j] = buffer;
src/UartReadLineSensor.h:86:68: error: invalid conversion from 'char*' to 'char' [-fpermissive]
                                                         u16_dis[j] = buffer;
src/UartReadLineSensor.h:108:70: error: invalid conversion from 'char*' to 'char' [-fpermissive]
src/UartReadLineSensor.h:117:70: error: invalid conversion from 'char*' to 'char' [-fpermissive]
src/UartReadLineSensor.h:126:68: error: invalid conversion from 'char*' to 'char' [-fpermissive]
src/UartReadLineSensor.h:155:61: error: invalid conversion from 'char*' to 'char' [-fpermissive]
                                                 chartemp[j] = buffer;
src/UartReadLineSensor.h:165:62: error: invalid conversion from 'char*' to 'char' [-fpermissive]
                                                 chartemp5[j] = buffer;
src/UartReadLineSensor.h:178:62: error: invalid conversion from 'char*' to 'char' [-fpermissive]
                                                 chartemp2[j] = buffer;
src/UartReadLineSensor.h:187:62: error: invalid conversion from 'char*' to 'char' [-fpermissive]
                                                 chartemp3[j] = buffer;
src/UartReadLineSensor.h:196:61: error: invalid conversion from 'char*' to 'char' [-fpermissive]
src/UartReadLineSensor.h:209:62: error: invalid conversion from 'char*' to 'char' [-fpermissive]
src/UartReadLineSensor.h:218:62: error: invalid conversion from 'char*' to 'char' [-fpermissive]
src/UartReadLineSensor.h:227:61: error: invalid conversion from 'char*' to 'char' [-fpermissive]
src/UartReadLineSensor.h:240:62: error: invalid conversion from 'char*' to 'char' [-fpermissive]
src/UartReadLineSensor.h:249:62: error: invalid conversion from 'char*' to 'char' [-fpermissive]
src/UartReadLineSensor.h:258:61: error: invalid conversion from 'char*' to 'char' [-fpermissive]
src/UartReadLineSensor.h:276:62: error: invalid conversion from 'char*' to 'char' [-fpermissive]
src/UartReadLineSensor.h:285:62: error: invalid conversion from 'char*' to 'char' [-fpermissive]
src/UartReadLineSensor.h:298:62: error: invalid conversion from 'char*' to 'char' [-fpermissive]
src/UartReadLineSensor.h:307:62: error: invalid conversion from 'char*' to 'char' [-fpermissive]
src/UartReadLineSensor.h:316:61: error: invalid conversion from 'char*' to 'char' [-fpermissive]
/config/cem5825f.yaml: In lambda function:
/config/cem5825f.yaml:82:91: warning: statement has no effect [-Wunused-value]
*** [.pioenvs/cem5825f/src/main.cpp.o] Error 1
========================= [FAILED] Took 39.94 seconds =========================
发表于 2022-8-12 23:42:07 | 显示全部楼层
casatift 发表于 2022-8-12 22:10
我这编译不成功,错误如下:
已解决,把所有出错的buffer改成buffer即可
发表于 2022-8-12 23:46:22 来自手机 | 显示全部楼层
有什么分别?
发表于 2022-8-13 09:12:44 | 显示全部楼层
被吞了字符
出错的buffer改成buffer[i]
 楼主| 发表于 2022-8-13 12:10:33 | 显示全部楼层
tink 发表于 2022-8-12 21:59
距离取平均值了吗
没有取平均,直接解析的100ms出的距离
发表于 2022-8-15 16:51:43 | 显示全部楼层
有个问题啊,为社么你写的uart custom程序,没有设置
  float get_setup_priority() const override
    // After UART bus
    return setup_priority::BUS - 1.0f;
或者 DATA,也能 接收到数据?
 楼主| 发表于 2022-8-15 20:32:15 | 显示全部楼层
你这个函数是设置什么的,串口不是在yaml里传过去的吗,还有别的设置方式?
发表于 2022-8-15 21:21:11 | 显示全部楼层
qqjil 发表于 2022-8-15 20:32
你这个函数是设置什么的,串口不是在yaml里传过去的吗,还有别的设置方式? ...
https://bbs.hassbian.com/thread-17464-1-1.html
我不设置,就无法正常从 rx 获取 数据。不清楚是什么情况。
GMT+8, 2025-9-13 03:18 , Processed in 0.296361 second(s), 13 queries , MemCached On.
