查看: 5002|回复: 2
[硬件DIY] 小米ax6000路由器固件分析
发表于 2022-7-29 16:37:07 | 显示全部楼层 |阅读模式
固件分析用到的工具 binwalk、ubi_reader、unsquashfs
1. 解压固件
ubireader_extract_images   miwifi_ra72_firmware_59812_1.0.41.bin
UBI_File Warning: end_offset - start_offset length is not block aligned, could mean missing data.
2.进入目录准备
cd ubifs-root/&&ls -FR
miwifi_ra72_firmware_59812_1.0.41.bin/
./miwifi_ra72_firmware_59812_1.0.41.bin:
img-1961083533_vol-kernel.ubifs                img-1961083533_vol-ubi_rootfs.ubifs
3.提取固件内容: 文件img-1961083533_vol-ubi_rootfs.ubifs为系统文件
cd miwifi_ra72_firmware_59812_1.0.41.bin/
unsquashfs img-1961083533_vol-ubi_rootfs.ubifs
Parallel unsquashfs: Using 8 processors
4075 inodes (3772 blocks) to write
create_inode: could not create character device squashfs-root/dev/console, because you're not superuser!
[===============================================================================================================================| ] 7846/7847  99%
created 3605 files
created 260 directories
created 469 symlinks
created 0 devices
created 0 fifos
created 0 sockets
created 0 hardlinks
提取完成;squashfs-root文件夹下的内容即为路由器系统文件;
接下来可以查看系统代码了;
反编译lua文件需要用到https://github.com/NyaMisty/unluac_miwifi
java -jar ./unluac.jar XQBackup.lua > XQBackup2.lua
发表于 2022-7-29 19:31:11 | 显示全部楼层
so, 发现漏洞了没有,如何利用啊
 楼主| 发表于 2022-8-26 17:54:16 | 显示全部楼层
有兴趣的可以根据源码再找找其他功能
file_2decompiled.lua.zip
20.89 KB, 下载次数: 2
GMT+8, 2025-11-3 09:01 , Processed in 0.051352 second(s), 6 queries , MemCached On.
