楼主: c1pher_小愚
[插件集成] HomeAssistant插件【和风天气v7】【20250420更新】
发表于 2022-7-30 10:29:24 | 显示全部楼层
是否真的有效,查查看
发表于 2022-7-30 10:46:50 | 显示全部楼层
收藏了,谢谢!
发表于 2022-7-30 11:15:44 | 显示全部楼层
25989406 发表于 2022-7-30 04:42
需要的文件都在github里,按目录格式下载就行了,我不会再额外打包。 运行不成功不贴日志的话没人能帮到 ...
好像是缺了 group:  配置额
 楼主| 发表于 2022-7-30 12:06:27 来自手机 | 显示全部楼层
wmhack 发表于 2022-7-30 11:15
好像是缺了 group:  配置额
Group怎么展示是你自己的事情啊,前台自己配置,跟插件本身没关系
发表于 2022-7-30 12:49:40 | 显示全部楼层
Logger: homeassistant.components.weather
Source: custom_components/heweather_forecast/weather.py:81
Integration: Weather (documentation, issues)
First occurred: 12:42:32 (1 occurrences)
Last logged: 12:42:32
Error while setting up heweather_forecast platform for weather
  File "/usr/lib/python3.10/site-packages/homeassistant/helpers/entity_platform.py", line 250, in _async_setup_platform
    await asyncio.shield(task)
  File "/config/custom_components/heweather_forecast/weather.py", line 69, in async_setup_platform
    async_add_devices([LocalWeather(data)], True)
  File "/config/custom_components/heweather_forecast/weather.py", line 81, in __init__
    self._temperature_unit = None
[backcolor=var(--mdc-theme-surface, #fff)][color=var(--mdc-dialog-content-ink-color, rgba(0, 0, 0, 0.6))]Logger: custom_components.heweather_forecast.weather
Source: custom_components/heweather_forecast/weather.py:298
Integration: heweather_forecast ([color=var(--primary-color)]documentation
Error while accessing: https://devapi.qweather.com/v7/w ... 7acaxxxxxxxxxxxx
发表于 2022-7-30 15:27:06 来自手机 | 显示全部楼层
回复一下顶一下看看
 楼主| 发表于 2022-7-30 17:13:12 来自手机 | 显示全部楼层
Source: custom_components/heweather_forecast/weather.py:81 ...
我晚上回家看看
发表于 2022-7-30 17:37:21 | 显示全部楼层
感谢分享~~
 楼主| 发表于 2022-7-30 21:20:00 | 显示全部楼层
你的key和权限应该都没问题,感觉是没拿到数据或者超时,重启试试看
正常拿到数据后的主要实体:
小时天气预报
sensor.hourly_forcast_*
天气、空气情况
sensor.heweather_**
生活指数
sensor.suggestion_**
7天天气预报(ha主界面添加天气卡片即可)
weather.localweather
极端天气预警
sensor.heweather_disaster_warn
一小时天气预警
sensor.remind
发表于 2022-7-31 16:40:05 | 显示全部楼层
正常拿到数据后的主要实体:
小时天 ...
我重启过很多次了,都是不能不行额,而且上面那个保存,感觉代码有问题额
GMT+8, 2025-9-13 03:04 , Processed in 0.771220 second(s), 12 queries , MemCached On.
