查看: 15087|回复: 28
[UI界面] HomeAssistant超级漂亮的界面 apexcharts-card
发表于 2022-7-25 09:42:48 | 显示全部楼层 |阅读模式
(看到有朋友反馈卡用不了,在这里说明一下吧,配置低的就不建议用了,这个界面会获取大量历史数据(记得数据源改为mysql,ha自带的db可不支持奥),如果你实在想玩可以把获取点数和时间段改小点,具体看项目手册吧,会玩的总是可以愉快的玩耍的)
HomeAssistant超级漂亮的界面接入Home Assistant效果:
安装插件:
首先安装apexcharts-card插件,你可以直接安装也可以通过hacs
界面UI:
卡片的配置
1-1
type: custom:apexcharts-card
experimental:
  color_threshold: true
graph_span: 24h
show:
  last_updated: true
header:
  standard_format: false
  show: true
  show_states: true
  colorize_states: true
  title: Living Room Temperature
now:
  show: true
  color: red
  label: Now
series:
  - entity: sensor.weather_temperature
    type: line
    group_by:
      func: last
      duration: 5m
    stroke_width: 2
    show:
      extremas: true
      header_color_threshold: true
    color_threshold:
      - value: 18
        color: steelblue
      - value: 21
        color: midnightblue
      - value: 22
        color: orange
      - value: 23
        color: orangered
      - value: 26
        color: red
  - entity: sensor.weather_humidity
    stroke_width: 2
    show:
      in_chart: true
  - entity: sensor.0xa4c1380a60008845_temperature
    stroke_width: 2
    show:
      extremas: true
  - entity: sensor.0xa4c1380a60008845_humidity
    stroke_width: 2
    show:
      in_chart: true
1-2
experimental:
graph_span: 24h
show:
  last_updated: true
header:
  show: true
  show_states: true
  title: Home Energy
now:
  show: true
  color: red
  label: Now
span:
  end: hour
series:
  - entity: sensor.meter_power
    type: line
    group_by:
      func: avg
      duration: 5m
    stroke_width: 2
    show:
      extremas: true
    color_threshold:
      - value: 100
        color: steelblue
      - value: 800
        color: midnightblue
      - value: 1500
        color: orange
      - value: 2000
        color: orangered
      - value: 3000
        color: red
  - entity: sensor.relay_2053cd_power
    stroke_width: 2
    group_by:
      func: avg
      duration: 5min
  - entity: sensor.relay_ecf998_power
    stroke_width: 2
    show:
      in_chart: true
    group_by:
      func: avg
      duration: 5min
  - entity: sensor.plug_158d0001b19931_power
    stroke_width: 2
    show:
      in_chart: true
    group_by:
      func: avg
      duration: 5min
  - entity: sensor.cabinet_meter_power
    stroke_width: 2
    show:
      in_chart: true
    group_by:
      func: avg
      duration: 5min
  - entity: sensor.server_power
    stroke_width: 2
    show:
      in_chart: true
      extremas: true
    group_by:
      func: avg
      duration: 5min
1-3
apex_config:
  chart:
    stacked: true
graph_span: 14d
span:
  end: day
show:
  last_updated: true
header:
  show: true
  show_states: true
  title: 每日电费
series:
  - entity: sensor.meter_energy_daily_money
    type: column
    color: darkviolet
    group_by:
      func: max
      duration: 1d
  - entity: sensor.relay_2053cd_daily_money
    type: column
    color: slateblue
    group_by:
      func: max
      duration: 1d
  - entity: sensor.relay_ecf998_daily_money
    type: column
    color: orangered
    group_by:
      func: max
      duration: 1d
  - entity: sensor.plug_158d0001b19931_energy_daily_money
    type: column
    color: orangered
    group_by:
      func: max
      duration: 1d
  - entity: sensor.cabinet_meter_energy_daily_money
    type: column
    color: orangered
    group_by:
      func: max
      duration: 1d
  - entity: sensor.server_powerusage_daily_money
    type: column
    color: orangered
    group_by:
      func: max
      duration: 1d
2-1
chart_type: pie
header:
  show: true
  show_states: true
  title: Monthly Energy consumption in kWh
series:
  - entity: sensor.relay_2053cd_monthly
  - entity: sensor.relay_ecf998_monthly
  - entity: sensor.plug_158d0001b19931_energy_monthly
  - entity: sensor.cabinet_meter_energy_monthly
  - entity: sensor.server_powerusage_monthly
2-2
experimental:
graph_span: 24h
show:
  last_updated: true
header:
  show: true
  show_states: true
  title: Dell PowerEdge R730xd
now:
  show: true
  color: red
  label: Now
series:
  - entity: sensor.server_fans_speed_avg
    type: line
    group_by:
      func: last
      duration: 5m
    stroke_width: 2
    show:
      extremas: true
    color_threshold:
      - value: 18
        color: steelblue
      - value: 21
        color: midnightblue
      - value: 22
        color: orange
      - value: 23
        color: orangered
      - value: 26
        color: red
  - entity: sensor.rawdellserverfan1
    stroke_width: 2
    show:
      in_chart: true
  - entity: sensor.rawdellserverfan2
    stroke_width: 2
    show:
      extremas: true
  - entity: sensor.rawdellserverfan3
    stroke_width: 2
    show:
      in_chart: true
  - entity: sensor.rawdellserverfan4
    stroke_width: 2
    show:
      in_chart: true
  - entity: sensor.rawdellserverfan5
    stroke_width: 2
    show:
      in_chart: true
  - entity: sensor.rawdellserverfan6
    stroke_width: 2
    show:
      in_chart: true
2-3
header:
  show: true
  title: R730XD Temperature Levels
  show_states: true
chart_type: radialBar
series:
  - entity: sensor.server_cpu1_temperature
  - entity: sensor.server_cpu2_temperature
  - entity: sensor.server_inlet_temperature
  - entity: sensor.server_exhaust_temperature
资源:
1.HACS:[color=var(--link-color)]HACS (github.com)
开源协议: 请遵循原作者的开源协议
参与人数 4金钱 +39 收起 理由
zhanzuoson + 5 论坛有你更精彩!
jjcs + 10 论坛有你更精彩!
zxyny1989 + 12 高手,这是高手!
咸味土豆 + 12 膜拜大神!
发表于 2022-7-25 09:57:53 | 显示全部楼层
真的是高大上啊,沙发一个
发表于 2022-7-25 10:15:37 | 显示全部楼层
这个可以,我也去整一个
发表于 2022-7-25 11:07:12 | 显示全部楼层
高端大气上档次
发表于 2022-7-25 11:19:24 | 显示全部楼层
高大上啊
我不生产技术,我只是技术的搬运工。
发表于 2022-7-25 13:02:59 | 显示全部楼层
太高端了,感觉我家里几个开关配不上这么漂亮的界面
发表于 2022-7-25 17:28:43 | 显示全部楼层
不错,漂亮
jjcs 手机认证
57
发表于 2022-7-25 17:37:03 | 显示全部楼层
感谢分享,对了我有个传感器刷新率3秒一次,用这个好卡咋办
 楼主| 发表于 2022-7-26 14:56:06 | 显示全部楼层
可以把曲线显示的点数改少点
jjcs 手机认证
57
发表于 2022-7-26 15:08:29 | 显示全部楼层
xingyuewang 发表于 2022-7-26 14:56
可以把曲线显示的点数改少点
请问咋改,对前端不太熟悉
GMT+8, 2025-9-15 03:09 , Processed in 1.179513 second(s), 15 queries , MemCached On.
