查看: 4821|回复: 6
[新奇玩法] 光猫温度,cpu,内存,光模块信息获取
发表于 2022-6-24 21:43:06 | 显示全部楼层 |阅读模式
RT,
路由器的信息获取,有现成的,但光猫信息的获取,资料很少。
今天分享一个获取华为光猫信息的方法。大家可以按照这个思路来获取其他类型的光猫信息。
以获取 ma5671,最新205 固件的 wanip、温度、光模块发射功率(其他信息类推)为例:
pycharm 调试
import os
import pickle
import requests
import re
import base64
import json
import urllib.parse
import codecs
DOMAIN = 'http://192.168.1.1/'
USERNAME = 'telecomadmin'
PASSWORD = 'nE7jA%5m'
HEADERS = {
    'user-agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.60 Safari/537.36',
    'Accept': 'text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9',
    'Accept-Encoding': 'gzip, deflate'
# get random
def get_random(session):
    cnt = session.post(url=DOMAIN+'asp/GetRandCount.asp').content.decode('utf-8-sig')
    return cnt
# get login cookie
def get_cookie(session, cnt):
   payload = {'x.X_HW_Token' : cnt}
   password_decode = base64.b64encode(str.encode(PASSWORD)).decode('ascii')
   cookies_dict = {'Cookie': 'Cookie=UserName:' + USERNAME + ':PassWord:' + password_decode + ':Language:english:id=-1' }
   session.post(url=DOMAIN+'login.cgi', data=payload, cookies=cookies_dict)
# get ont temperature
def get_opticinfo(session):
    x = session.get(url=DOMAIN+'html/amp/opticinfo/opticinfo.asp').content.decode('utf-8-sig')
    opticinfos = re.findall('var opticInfos = new Array\(new stOpticInfo\("InternetGatewayDevice.X_HW_DEBUG.AMP.Optic","(.*)","(.*)","(.*)","(.*)","(.*)","(.*)","(.*)"\),null\);',x)
    return opticinfos
# get pppoe wan ip
def get_wanip(session):
    x = session.get(url=DOMAIN + 'html/bbsp/common/wan_list.asp').content.decode('utf-8-sig')
    wanips = re.findall(
        'var PPPWanList = new Array\(new WanPPP\("InternetGatewayDevice.WANDevice.1.WANConnectionDevice.1.WANPPPConnection.1","(.*)","(.*)","(.*)","(.*)","(.*)","(.*)","your_adsl_account"',
        x)
    return wanips
# using session
session = requests.Session()
session.headers = HEADERS
# begin
get_cookie(session, get_random(session))
x = session.get(url=DOMAIN + 'frame.asp')
#y = session.get(url=DOMAIN + 'html/ssmp/deviceinfo/deviceinfo.asp')
#z = session.get(url=DOMAIN + 'html/ssmp/reset/reset.asp')
#u = session.get(url=DOMAIN + 'html/ssmp/common/StartFileLoad.asp')
#v = session.post(url=DOMAIN + 'html/ssmp/reset/set.cgi?x=InternetGatewayDevice.X_HW_DEBUG.SMP.DM.ResetBoard&RequestFile=html/ssmp/reset/reset.asp')
# opticinfo
opticinfo = get_opticinfo(session)
# wanip
wanip = get_wanip(session)
unescaped = urllib.parse.unquote(wanip[0][1])
raw_bytes = bytes(unescaped, "utf-8")
decoded = codecs.escape_decode(raw_bytes)[0].decode("utf-8")
# json out
js = {
    "Optical_Temperature" : opticinfo[0][3],
    "RX_Optical_Power": opticinfo[0][1],
    "wan_ip": decoded
print(json.dumps(js))
HA 里
  - platform: command_line
    command: "python /config/get_ont_info.py"
    value_template: "{{ value_json.Optical_Temperature}}"
    unit_of_measurement: "°C"
    scan_interval: 310
    name: Optical Rx Power
    value_template: "{{ value_json.RX_Optical_Power}}"
    unit_of_measurement: "dBm"
    scan_interval: 320
    value_template: "{{ value_json.wan_ip}}"
    scan_interval: 300
效果图:
参与人数 2金钱 +20 收起 理由
dscao + 10 感谢楼主分享!
jjcs + 10 感谢楼主分享!
jjcs 手机认证
57
发表于 2022-6-24 22:00:17 | 显示全部楼层
还有一个方法就是有些光猫有漏洞,可以获取web的数据,具体可以百度,请求这个页面就行了
 楼主| 发表于 2022-6-24 22:02:27 | 显示全部楼层
jjcs 发表于 2022-6-24 22:00
还有一个方法就是有些光猫有漏洞,可以获取web的数据,具体可以百度,请求这个页面就行了 ...
有漏洞,只是少了中间的python模拟登录部分。知道密码的情况下,意义不大。
jjcs 手机认证
57
发表于 2022-6-24 22:03:29 | 显示全部楼层
方便啊,有些漏洞的数据还是json格式,还不需要密码模拟登录,nr就行了
发表于 2022-6-25 08:58:27 | 显示全部楼层
收藏啦,感谢
发表于 2022-6-25 12:27:25 | 显示全部楼层
多谢分享
发表于 2023-3-6 12:06:05 | 显示全部楼层
麻烦问一下.这个怎么用,我保存到根目录执行后没有数据显示
GMT+8, 2025-9-16 03:02 , Processed in 0.144245 second(s), 12 queries , MemCached On.
