楼主:
hass.io安装habridge插件(方便!)
发表于 2018-5-7 09:38:12 | 显示全部楼层
具体配置你的帖子贴一下呀
发表于 2018-5-12 17:08:40 | 显示全部楼层
发表于 2018-8-6 10:33:41 | 显示全部楼层
感谢楼主
发表于 2018-8-27 10:59:23 | 显示全部楼层
用N1安装提示这个错误Addon 27e642c6_ha-bridge not supported on aarch64,是平台不行吗
发表于 2018-10-30 00:43:13 | 显示全部楼层
阿萨德飞洒发
发表于 2018-10-31 23:27:40 | 显示全部楼层
我安装后,总是打不开web ui 不知道什么原因
发表于 2018-11-15 11:40:45 | 显示全部楼层
学习了
发表于 2018-12-12 19:19:48 | 显示全部楼层
各种安装不上真着急 ha-bridge
发表于 2018-12-16 11:34:33 | 显示全部楼层
2018-12-16 11:22:35,779 [main] ERROR com.bwssystems.HABridge.upnp.UpnpListener - Upnp Discovery Port is in use, or restricted by admin (try running with sudo or admin privs): 1900 with message: Address already in use (Bind failed)
2018-12-16 11:22:35,787 [main] ERROR com.bwssystems.HABridge.HABridge - Could not initialize UpnpListener, exiting....
java.net.BindException: Address already in use (Bind failed)
discovery Port is in use,求解
发表于 2019-2-6 14:46:52 | 显示全部楼层
感谢楼主精彩好帖,学习一下
GMT+8, 2025-9-14 03:22 , Processed in 0.553898 second(s), 12 queries , MemCached On.
