查看: 41649|回复: 51
[进阶教程] 把遥控风扇的多个按键写成一个input_select
ABC 手机认证
论坛风云人物
发表于 2017-5-18 15:55:07 | 显示全部楼层 |阅读模式
用一个我的博联控制的射频吊扇作为例子
- platform: broadlink
  host: 192.168.1.168
  mac: '34:EA:3x:xx:xx:xx'
  switches:
    close:
      friendly_name: "close"
      command_on: 'sg8yAA4aHAsO7g4aHQscCxwLDhkcCw4ZHAwcCw4aHAsOGRwLDhkOGhwMHAscCw4ZDhoAAAAAAAA'
      command_off: 'sg8yAA4aHAsO7g4aHQscCxwLDhkcCw4ZHAwcCw4aHAsOGRwLDhkOGhwMHAscCw4ZDhoLAAAAAAAA'
    low:
      friendly_name: "low"
      command_on: 'sg8yAA0aDe8NGhsMGwwbDA0aDRobDA0bHAwNGhsMDRobDBsMHAwbDBsMHAwNGg0aDRoNGgAAAAAAAA'
      command_off: 'sg8yAA0aDe8NGhsMGwwbDA0aDRobDA0bHAwNGhsMDRobDBsMHAwbDBsMHAwNGg0aDRoNGgAAAAAAAA'
    middle:
      friendly_name: "middle"
      command_on: 'smcyABwMHAwcCw4aDRoNGhwMGwwNGg3vDRocCxwMHAwNGhwLHAwcDBwLDhocCw0aHAwNGhAAAAAAAA'
      command_off: 'smcyABwMHAwcCw4aDRoNGhwMGwwNGg3vDRocCxwMHAwNGhwLHAwcDBwLDhocCw0aHAwNGhAAAAAAAA'
    high:
      friendly_name: "high"
      command_on: 'slEyAA0aGwwNGg0aDRoNGhwMHAwbDA0aDRoOGg0aDRoOGhwMHAwcCxwMHAwNGg0aDRoc3vAAAAAAAA'
      command_off: 'slEyAA0aGwwNGg0aDRoNGhwMHAwbDA0aDRoOGg0aDRoOGhwMHAwcCxwMHAwNGg0aDRoc3vAAAAAAAA'
    one_hour:
      friendly_name: "one_hour"
      command_on: 'skwyAA0bDRoNGxsMDRobDA0aDRoNGg0aDRocDBsMDRoNGhwMHAwOGg0aDu8NGhwMHAwcwMAAAAAAAA'
      command_off: 'skwyAA0bDRoNGxsMDRobDA0aDRoNGg0aDRocDBsMDRoNGhwMHAwOGg0aDu8NGhwMHAwcwMAAAAAAAA'
    two_hours:
      friendly_name: "two_hours"
      command_on: 'sqUyAA8ZHQwdCw4ZHQsOGQ8ZDxkOGR0MHQsdCw4ZDhkdCx0LDhkcCw7vDhodCxwLHQsd4ZAAAAAAAA'
      command_off: 'sqUyAA8ZHQwdCw4ZHQsOGQ8ZDxkOGR0MHQsdCw4ZDhkdCx0LDhkcCw7vDhodCxwLHQsd4ZAAAAAAAA'
    four_hours:
      friendly_name: "four_hours"
      command_on: 'sm4yAA0aHAsNGhwLDhocCw4aDhocDA4aDhocCxwLDhoNGg0aHAscCxwLDRoNGhwLDhoN7vAAAAAAAA'
      command_off: 'sm4yAA0aHAsNGhwLDhocCw4aDhocDA4aDhocCxwLDhoNGg0aHAscCxwLDRoNGhwLDhoN7vAAAAAAAA'
    eight_hours:
      friendly_name: "eight_hours"
      command_on: 'snYyAA0aHAwNGhwMHAwNGg0aDRocDA0aDRocDA0aDRoNGg4aHAwcCxwMDRocDBwLDRoN7vAAAAAAAA'
      command_off: 'snYyAA0aHAwNGhwMHAwNGg0aDRocDA0aDRocDA0aDRoNGg4aHAwcCxwMDRocDBwLDRoN7vAAAAAAAA'
在input_select:写入
diaoshan:
  icon: mdi:fan
  initial: "关"
  options:
    - "关"
    - "低"
    - "中"
    - "高"
    - "一小时"
    - "两小时"
    - "四小时"
    - "八小时"
在自动化automation:写入
alias: 1
initial_state: true
hide_entity: true
trigger:
  - platform: state
    entity_id: input_select.diaoshan
action:
  - service: switch.toggle
    data_template:
      entity_id: >
        {% if is_state("input_select.diaoshan", "关") %} switch.close
        {% elif is_state("input_select.diaoshan", "低") %} switch.low
        {% elif is_state("input_select.diaoshan", "中") %} switch.middle
        {% elif is_state("input_select.diaoshan", "高") %} switch.high
        {% elif is_state("input_select.diaoshan", "一小时") %} switch.one_hour
        {% elif is_state("input_select.diaoshan", "两小时") %} switch.two_hours
        {% elif is_state("input_select.diaoshan", "四小时") %} switch.four_hours
        {% elif is_state("input_select.diaoshan", "八小时") %} switch.eight_hours
        {% endif %}
发表于 2017-5-18 16:07:28 | 显示全部楼层
,顶你顶你顶你
活跃会员
发表于 2017-5-18 16:40:23 | 显示全部楼层
谢谢分享
wqqs 手机认证
活跃会员
发表于 2017-5-18 16:46:02 | 显示全部楼层
谢谢分享
版主
教程狂人卓越贡献
发表于 2017-5-18 18:29:06 | 显示全部楼层
定时不错~
发表于 2017-5-19 19:33:03 来自手机 | 显示全部楼层
牛啊……
发表于 2017-5-21 04:27:42 | 显示全部楼层
学习了 ,感谢分享
发表于 2017-5-24 11:48:53 | 显示全部楼层
谢谢分享
发表于 2017-5-24 15:25:04 | 显示全部楼层
谢谢分享。。就是这个颜色太亮眼啦
发表于 2017-5-24 15:47:06 | 显示全部楼层
谢谢分享
GMT+8, 2025-9-14 03:17 , Processed in 1.187011 second(s), 14 queries , MemCached On.
