查看: 2571|回复: 0
[智能音箱] 求助TTL 小爱同学无法开机转圈圈 ctrl+c 无法终止 求解答
发表于 2022-5-26 09:43:47 | 显示全部楼层 |阅读模式
MMC:
uboot env amlnf_env_read : ####
aml_nand_read_rsv_info:397,read nenv info to 310000
In:    serial
Out:   serial
Err:   serial
[store]To run cmd[amlnf dtb_read 0x1000000 0x20000]
sub cmd dtb
new argv[1] dtb_read
do_dtb_ops(): argc 4
arg 0: amlnf
arg 1: dtb_read
arg 2: 0x1000000
arg 3: 0x20000
do_dtb_ops() read
amlnf_dtb_read: ####
aml_nand_read_rsv_info:397,read ndtb info to 500000
do_dtb_ops(): 131072 bytes read : OK
      Amlogic multi-dtb tool
      GZIP format, decompress...
      Multi dtb detected
      Multi dtb tool version: v2 .
      Support 5 dtbs.
        aml_dt soc: xiaomi platform: s12a variant: v01
        dtb 0 soc: xiaomi   plat: s12   vari: v1
        dtb 1 soc: xiaomi   plat: s12a   vari: v01
        dtb 2 soc: xiaomi   plat: s12c   vari: v01
        dtb 3 soc: xiaomi   plat: s12c   vari: v02
        dtb 4 soc: xiaomi   plat: s12c   vari: v03
      Find match dtb: 1
amlkey_init() enter!
amlnf_key_read key data len too much
aml_nand_read_rsv_info:397,read nkey info to 400000
[EFUSE_MSG]keynum is 4
InUsbBurn
noSof
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
HAVE SN Code ...
Saving Environment to aml-storage...
uboot env amlnf_env_save : ####
aml_nand_save_rsv_info:656, nenv: valid=1, pages=32
release_free_node 61: bitmap=1fffff
release_free_node 74: bitmap=1ffff7
aml_nand_save_rsv_info:716,save info to 320000
aml_nand_write_rsv:520,write info to 320000
[burnup]Rd:Up sz 0x3a6440 to align 0x1000
save_power_post ...
## Booting Android Image at 0x01080000 ...
reloc_addr =f0348e0
copy done
load dtb from 0x1000000 ......
      Single dtb detected
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x017a7808
   Loading Ramdisk to 0eead000, end 0f004ce0 ... OK
   Loading Device Tree to 000000000eea2000, end 000000000eeac807 ... OK
Starting kernel ...
uboot time: 1825998 us
domain-0 init dvfs: 4
[    0.273093@2] ff803000.serial: clock gate not found
get key is 0x00 , curr_boot is boot1
Booting from boot1
/dev/mtdblock5 is ready now.
[    1.738093@3] i2c i2c-1: [aml_i2c_xfer] error ret = -5 (-EIO)
[    1.738219@3] i2c i2c-1: token 1, master_no(1) 300K addr 0x3c
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
Please press Enter to activate this console.
[    5.824298@1] cyttsp 0-0008: Failed to request firmware touch.cyacd
[    5.824931@1] cyttsp 0-0008: Failed to update firmware;
[    7.761998@0] UBIFS error (ubi0:0 pid 949): ubifs_recover_leb: corrupt empty        space LEB 1226:24576, corruption starts at 2048
[    7.767563@0] UBIFS error (ubi0:0 pid 949): ubifs_scanned_corruption: corrupt        ion at LEB 1226:26624
[    7.776437@0] UBIFS error (ubi0:0 pid 949): ubifs_scanned_corruption: first 8        192 bytes from LEB 1226:26624
[    7.788459@0] UBIFS error (ubi0:0 pid 949): ubifs_recover_leb: LEB 1226 scann        ing failed
[    8.447632@2] UBIFS error (ubi0:0 pid 962): ubifs_recover_leb: corrupt empty        space LEB 1226:24576, corruption starts at 2048
[    8.453200@2] UBIFS error (ubi0:0 pid 962): ubifs_scanned_corruption: corrupt        ion at LEB 1226:26624
[    8.462072@2] UBIFS error (ubi0:0 pid 962): ubifs_scanned_corruption: first 8        192 bytes from LEB 1226:26624
[    8.474102@2] UBIFS error (ubi0:0 pid 962): ubifs_recover_leb: LEB 1226 scann        ing failed
[    8.486956@1] name: deviceid, size 15
[    8.490343@0] name: didkey, size 38
[    8.503107@2] name: mac_wifi, size 17
[    8.506446@0] name: mac_bt, size 17
[    8.877541@2] name: mac_wifi, size 17
到这就不动了。。ctrl+c无法终止   不会玩了  求讲解
GMT+8, 2025-9-14 03:06 , Processed in 0.712329 second(s), 12 queries , MemCached On.
